2006 Acura TL REAR rotors - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 02-18-2011, 10:41 PM   #1
Get Money
stiffdogg06's Avatar
Alright guys, I need your help BAD.
I am at my brothers house without a manual of any kind.
Front rotors and brake pads went fine.
We removed the caliper and the 2 screws from the rotors in the rear but the rotors will only come off about half an inch and not one inch more and we were pulling with our might... I personally never changed rear disc brakes (always had drums)
Made sure the e-brake was off, even pulled up and let off the ebrake to see if that helped. Nothing. Pounded it to hell with a rubber mallet. I didnt want to go to crazy and damage something since it is my brothers car.
My question is this:
How in the hell do you remove the REAR rotors from a 2006 Acura TL Automatic?
stiffdogg06 is offline   Reply With Quote
Old 02-18-2011, 10:56 PM   #2
Get Money
My apologies. My buddy called and told me you need to remove the rubber access plug and stick a flat head in the hole to loosen the tension on the shoes against the rotor...
Sorry guys....
Old 02-18-2011, 11:45 PM   #3
Bearcat94's Avatar
D-085: Front and rear Brake disc (rotor), knuckle, hub, and front wheel bearing replacement
http://tl.acurazine.com/forums/showthread.php?t=132940
Check SM page 18-30 steps 7, 8 & 9. Ignore the stuff about the spindle nut in earlier steps - you don't need to remove it for a rotor change.
You only need to remove the caliper then ONLY the steps 7, 8, & 9 on 18-30 to remove the rotor.
Bearcat94 is offline   Reply With Quote
Old 02-19-2011, 02:01 PM   #4
Get Money
Didnt really help. Thanks though. What I had to do was remove the rubber access plug on the rear rotors to access the ebrake shoe spring assembly which I turned to retract the shoes. I then was able to pull the rotor almost all the way off. Had to use a prybar at the end to finish the job to finally get them all the way off. I was just so use to just brake drums. Never messed with 4 wheel disc brakes. At least until yesterday.
Old 02-19-2011, 02:08 PM   #5
Bearcat94's Avatar
Quote:
Originally Posted by stiffdogg06 View Post
Didnt really help. Doesnt mention anything about how to remove the rear rotors. Thanks though. What I had to do was remove the rubber access plug on the rear rotors to access the ebrake shoe spring assembly which I turned to retract the shoes. I then was able to pull the rotor almost all the way off. Had to use a prybar at the end to finish the job to finally get them all the way off.....
It's the step with the 8 x 1.25 bolts that tells you how to back the rotor off the hub using the bolts - that would replace your need for a prybar. Step #9.
I'd think that simply releasing the e-brake would eliminate the need of backing the e-brake shoes off with the adjustment knob.
Regardless, glad you got 'em off and hopefully the thread and links will help someone else in the future.
The Following User Says Thank You to Bearcat94 For This Useful Post:
YeuEmMaiMai (07-19-2014)
Old 02-19-2011, 03:58 PM   #6
Registered Member
nothing more irritating then when something stupid like that completely screws up what should be a 30-60 min job
nickadamini is offline   Reply With Quote
Old 02-19-2011, 10:05 PM   #7
Registered Member
Rotors should come off fairly easy with the e-brake off without backing off the shoes unless you were pulling crooked. If that's the case the shoes are always dragging and you have issues.
I hate cars is offline   Reply With Quote
The Following User Says Thank You to I hate cars For This Useful Post:
Old 02-28-2014, 11:39 PM   #8
say wattt??
07_J35A8_noob's Avatar
hello,
I know this thread is old but the only thing that come close to my problem. I cannot get the rear rotor out no matter what i tried to do. it wiggle a little bit but does not slide out. I need help, i don't know what else to do.
Any other suggestion that would possibly help?
thanks in advance
07_J35A8_noob is offline   Reply With Quote
Old 03-01-2014, 09:33 AM   #9
Registered Member
Or try this. Put everything together take long drive. Come back home park the car WITHOUT using e-brake. And start to remove the rear brake.
Ccvn0 is offline   Reply With Quote
Old 03-01-2014, 09:51 AM   #10
Quote:
Originally Posted by 07_J35A8_noob View Post
hello,
thanks in advance
Did you get the rotor screws out?
the two little screws that are on the face of the rotor hub.
those screws are a bitch!
once those two screws are out, bang on the rotor itself with a soft mallet to loosen up the rust.
once you have banged on it pretty hard, rust will start to drop from the middle of the rotor and the spindle.
when loose, pull off rotor.
Do not do as the other poster above suggested and put everything back on. that is a big waste of time!!!!!
justnspace is offline   Reply With Quote
Old 03-01-2014, 09:59 AM   #11
say wattt??
yes, screws(2) are out. hammer (check), all rust are loose, i could wiggle the rotor but it would not slide out as if something is holding it from behind
Old 03-01-2014, 01:48 PM   #12
paperboy42190's Avatar
There should be nothing else holding it. Maybe just pull harder?
paperboy42190 is online now   Reply With Quote
The Following User Says Thank You to paperboy42190 For This Useful Post:
justnspace (03-01-2014)
Old 03-01-2014, 02:06 PM   #13
Registered Member
jkopuffs's Avatar
drench with brake cleaner, beat the shit out of it. if still not off repeat.
jkopuffs is offline   Reply With Quote
The Following User Says Thank You to jkopuffs For This Useful Post:
Old 03-01-2014, 08:36 PM   #14
Registered Member
Did you remove the plug and turn the star wheel to loosen the e brake shoes?
Turbonut is offline   Reply With Quote
Old 03-01-2014, 08:42 PM   #15
make sure the E-brake isnt up!!
Old 03-01-2014, 09:08 PM   #16
Registered Member
I am going to do this tomorrow but why the hell they use this design? Would of made sense if they used a rear bbk with this.
cruc1a7 is offline   Reply With Quote
Old 03-01-2014, 11:32 PM   #17
Registered Member
AndrewA's Avatar
you shouldn't have to loosen the drum pads, but sometimes it's necessary. remove the rubber plug and turn the star wheel and also use the threads where you can screw in bolts to push on the hub to get the rotor off.
AndrewA is offline   Reply With Quote
Old 03-03-2014, 11:51 AM   #18
say wattt??
thanks for the tips guys.
so i finally got it out on saturday after i got super frustrated and banging it away. turns out, there was a thin lips inside the rotor that was locking on to the shoes.
anyone knows how the lips could have been form?
Old 03-03-2014, 12:49 PM   #19
Registered Member
AndrewA's Avatar
shoes were likely dragging because of improper adjustment
Old 05-13-2014, 07:27 AM   #20
Registered Member
HELP!!!!!!!
I am having the exact same problem...I even tried to losing the star wheel. It will not move!!!
Any Suggestion before I cause more problems for myself?
Jimflys is offline   Reply With Quote
Old 07-18-2014, 11:23 AM   #21
New Member
I really need help, i have acura TL 2008 when i am making full left turns i am hearing that clicking noise and its only on the left turns, it is really hard to find an honest machanic here, they told me to change the drive shaft right side so i did it but the noise is still there can someone please help me
Amirks is offline   Reply With Quote
Old 07-19-2014, 05:22 PM   #22
Registered Member
^ check your left and right axles for damage
YeuEmMaiMai is offline   Reply With Quote
Old 09-22-2014, 10:40 PM   #23
Quote:
Just to help out and simplify this for the less experienced, what he means is that the e-brake mechanism is located behind the rear brake rotor hub. The drum brake shoes push against the inside of the hub, using friction, causing the rear wheels to lock.
The problem results when the e-brake is not properly adjusted, causing one side to push more into the hub than the other, even when the e-brake is down. This over time can cause a groove on the inside of the hub, making it impossible to slide the rear rotor off. The only way to do it, as far as I know, is to loosen the e-brake mechanism.
How? Once you get everything disassembled to the point where only the rotor remains in place, you need to pull that little rubber nipple out located on the hub. Turn the rotor to the bottom so that nipple hole is at the bottom. Grab a flashlight and look through the hole. You'll see the star key gear in there (it's just off to one of the sides, a little ways past dead bottom- rotate the rotor a bit to eventually see it). You need to rotate that gear to loosen the mechanism. Not exactly easy but it is doable. Once you loosen that a bit, the rotor will slide off.
The tricky part is to readjust the mechanism so that it is adjusted evenly. This may take some trial and error.
TacoBello is offline   Reply With Quote
Old 10-07-2014, 03:50 PM   #24
New Member
Had issues removing rear rotors also. Ended up bending retaining/tension spring and finally came off. Replaced spring and it all went back on easy. Took a while to remove. Maybe loosening parking brake cable tension so it has slack in it would have helped.
thegrinch911 is offline   Reply With Quote
Old 07-17-2016, 09:26 PM   #25
New Member
Still having issue with rotor removal
if anyone is listening to this thread... I have battled and lost with removing rotors from TL 2006 6 spd manual. I have released e-brake and tried the star gear to loosen further the parking brake mechanism. Have tried the 8 MM bolts to push rotor from hub... on both left and right I get the same 1/2 inch from becoming free, but they will not come free. Since it is both sides with exact same issue, I am assuming I am just not completing a portion of the disassembly properly and now feel I have done some damage to whatever is behind the rotors... I am stuck and without transportion - if anyone has any advice it would truly be appreciated...
Thanks, Eric
ejbruner is offline   Reply With Quote
Old 07-18-2016, 12:00 PM   #26
Registered Member
AndrewA's Avatar
There's one last adjustment of the parking brake cable under the center console that might help. Check in here.
Brakes-caliper O/H,pad repl,hoses,bleed,disc specs,park brake adj 3G Garage #D-041
Old 07-19-2016, 07:54 AM   #27
New Member
Star Wheel was frozen
Quote:
Thanks, Eric
Turns out the star wheel adjustment mechanism for the parking brake was rusted/seized and despite my thinking it was turning, it was not. So I ended up with a small pry bar between the hub and inside of rotor to force the rotor to slide off... The parking brake shoes were applying enough friction that this was necessary. The parking brake retention pins had broken (the ones that hold the shoe flat against the rear lining) when using the 8 MM 'separator' bolts, so the parking brake shoes were winging out against the inside of the rotor... Replacing entire parking brake shoe mechanisms. As always acurazine community - excellent conversations and insights from some very conscientious acura owners!
Thread Thread Starter Forum Replies Last Post
My '04 NBP A Work In Progress HOWELLiNC 3G TL Photograph Gallery 24 10-08-2015 04:15 PM
Changing out front and rear brake rotors mav888 First Generation RDX (2007-2012) 10 09-08-2015 12:49 PM
FS: 2005 Acura TL Anthracite Metallic San Diego, CA asahrts Member Cars for Sale 0 09-04-2015 06:55 PM
Tags
06, 07, 2006, acura, acurazine, brake, brakes, break, change, pads, rear, replace, rotor, rotors, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
