'04 to '08 front lower control arm bushing failure - please read and look
Old 01-29-2010, 10:13 AM
  #401
ml3456's Avatar
Had my done under just before warranty expired. Mechanic said that Acura had a special tool to change these that made it easy.
Old 01-29-2010, 10:37 AM
  #402
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
I'm guessing a specialized spacer to press out the bushing.
Old 03-25-2010, 09:21 PM
  #403
fireman252525's Avatar
This thread has gone dead??? WTF?? anyone still looking into this?? I need feedback as I have gotten no where with the dealer??
Old 03-26-2010, 09:48 AM
  #404
mc_holla's Avatar
+2
Could any of you that have corrected any of theses issues (vibrations or the instabilty caused by car tracking road impefections) please provide your inputs. I have a 04 w/ close to 120K that at times feels like is a hazard to drive and am lookin for some guidance on where to start.
Mc
Old 03-26-2010, 10:16 AM
  #405
Schu's Avatar
the bushing needs to be clocked correctly in addition to being installed in the Z axis correctly. is the bushing available as a separate item from parts?
Old 03-30-2010, 02:37 AM
  #406
dr-who's Avatar
After over a year after my initial post with about 62k on the clock, my bushings are finally taken cared for by Acura. The final result was replacement of the bushings for $100 including an alignment for both our 2004 TLs.
My props to Roman at Santa Monica Acura. SM Acura is one of the best service dept for Acuras. their service is friendly and they seem to get better support from Acura. They are also offering $20 oil changes with car washes. Had my TL tranny flushed as well there..
Cush Acura and Cathy the service manager in San Diego blows. Not only did they claim the bushings cant be changed their "goodwill" price was $300 for the pair of arms replaced. useless, simply useless.. I have never spent a single cent with them since. I tihnk I have more equipment in my Garage than Cush. Seriously.. a service dept without a bushing press??? come on...
Old 03-30-2010, 08:36 AM
  #407
ml3456's Avatar
Just the bushings were replaced in my existing lower arms under warranty. They are available separately, and check to see if the left and right are different.
ML
Old 04-05-2010, 01:45 AM
  #408
NBP is a pain...
gotkilled's Avatar
i finished changing out my brake pads today and saw that both the driver and passenger side compliance bushing are torn.
i'm not really feeling any ill side effects like handling etc as you guys have mentioned. guess i'll take it to acura to check it out before my extended warranty expires.
are there any other ill effects aside from handling?
Old 04-09-2010, 12:28 PM
  #409
NBP is a pain...
gotkilled's Avatar
I just took my vehicle into the dealership because my bushings are torn. I am under warranty and they said they cannot repair my bushings because my car is lowered. What's my play? I lowered my car about a month or so ago.
Old 04-10-2010, 07:16 AM
  #410
DMZ
Head a da Family
DMZ's Avatar
When I discovered the driver's side bushing torn at only 11,000 miles, the dealer replaced both control arms because they said it's easier than popping out and installing new bushings in them and by the time you were done trying to just replace the bushings, the labor time would be much more than simply changing out the whole lower control arm itself.
Old 04-12-2010, 03:51 AM
  #411
dr-who's Avatar
If they have the right press fittings it only takes about an extra 15 to 20 min of labor. I'm finding out not all acura dealers have the right press.
New arms retail are about $150 each. Bushings are $20.
Orientation of bushings are important too.
--Kwun
Old 04-12-2010, 03:52 AM
  #412
NBP is a pain...
gotkilled's Avatar
was anyone able to get this repaired under warranty despite having a lowered ride on aftermarket suspension? i don't reallyhave any issues with handling except for a slight minor shimmy when i made a fast turn such as onto an onramp at high speed. at regular speeds, there is no shimmy in the steering.
Old 04-12-2010, 04:48 AM
  #413
dr-who's Avatar
You can argue that the damage cannot be caused by one month of lowering the car if the bushings are in bad shape.
If they don't want to hear it. I would put your stock suspension back in and get it fixed since its still under warranty. Then you can do whatever you want after that.
Old 04-12-2010, 08:28 AM
  #414
mc_holla's Avatar
For those of you that have changed out your bushings/arms, what differences have you noticed? Trying to determine how high up my list I should put this fix.
Old 04-12-2010, 05:31 PM
  #415
Tripnbeats's Avatar
mc put it high up on ur list..... u can see if its broken simply by looking and seeing the tear.....the way u recognize the parts are truly broken is by driving on ahighway and lets say ur going into a turn and u wanna change lanes in the turn and the car shimmys as your changing lanes (more so than what its supposed to) it feels as if the frame of the car is shifting away and the car starts to wobble,
in the manual it states that u should drop the car on the ground after installing the control arm with the bushing bolt loose. Once its on the ground tighten it to spec, it sucks to tighten it like that but the theory behind it is that the car naturally sits the way it sits in a certain position and if the bushings tightened in the air it has more stress than was intended because it wasnt in its natural position that honda intended it to be in the air.
I started noticing these cars after getting some kinda work done to the suspension... the bushing tears. i think its because the bushing isnt tightened on the ground. my friends type s......never had suspension work done and hes had the car for 2 years i did the tranny flush the other day and did an overall visual inspection.....and the bushings are perfect..... i think that right from the factory the workers could be slacking as well......lol at this point who knows.
Old 04-13-2010, 01:23 AM
  #416
seoulja's Avatar
guys.. please keep in mind.. the 04 and up TL's were completley designed in USA. they just used japan parts... i work on cars all the time..and alot of Gm's parts such as interior cloth and other stuff is the same material. as for the bushing..its AGE + (OR) wear and tear.. REPLACE THE BUSHINGS ONLY.... dont believe the bullshit about the arm... i personally replaced these bushings ALL THE TIME! also keep in mind that your control arm Moves,vibrates ALL THE TIME..from the minute u get in the car,driving, and when u get out...the bushings WILL WEAR.. think about how many times your control arm moves while u drive.. DUH!
Old 04-13-2010, 09:34 AM
  #417
mc_holla's Avatar
That makes sense. Many of the parts on our cars were designed to wear out in an attempt to keep other, more expensive parts from wearing out. With that being said, I still think they specific bushings may be the casualty of a design flaw.
Trip,
What did you end up doing? Did you use the bushings that you designed or did you just go with the OEM ones? I'm thinking about just buying the bushings and finding a local ATL dealer to put them in for me. I know that I may not achieve the "new car feeling" but at this point any improvement would be welcomed.
Old 04-13-2010, 12:11 PM
  #418
npduncan73's Avatar
Just read this thread and sure enough my 04' with 57k has the same cracking in the bushings.. I guess it would explain some of the handling issues i have been experiencing. I would have expected these kind of things to happen to my Audi with it's extremely poor design, but not my TL...I smell a recall!!!
Old 04-13-2010, 03:11 PM
  #419
Former Sponsor
MrHeeltoe's Avatar
What is the demand for pre-filled or re-engineered bushings? A Fastline Performance part possibility?
Old 04-13-2010, 05:50 PM
  #420
-------Tim-------
Slpr04UA6's Avatar
It sounds like a good possibility! Looks like I should check these bushings out on my '04, before I lower it. Is there anyone that has had them replaced that is lowered and has had the reoccurence of the same issue?
Old 04-13-2010, 09:45 PM
  #421
Fresh23's Avatar
From an 11 page thread, people unsure and dealer run arounds, its possible.
Old 04-15-2010, 05:55 PM
  #422
Former Sponsor
MrHeeltoe's Avatar
Lowering does not make this issue better or worse. Well, theoretically it might be better because of the shorter stroke in the suspension.
Old 04-16-2010, 07:35 PM
  #423
Ryan's loving his ATLP TL
RJNN TL's Avatar
Yep. Got an 05 AT TL. And you guessed it. Ripped. Small tears. EXACTLY as the picture shows. This is complete bullshit. Acura better do something about this! :/
Old 04-17-2010, 11:07 AM
  #424
Tripnbeats's Avatar
I filled my bushings with poly and they stilll seem good....but im gonna fill some new ones with 3m window weld that i bought yesterday and give that a shot
Old 05-26-2010, 06:33 PM
  #425
I like to whistle in my
Meek32v6's Avatar
Interested. My 40 minute drive to work can be scary at times - actually just annoying. I use to enjoy it but the car just feels real sloppy now.
Old 05-26-2010, 09:17 PM
  #426
mc_holla's Avatar
Interested also. What other than these bushing could be causing this? My commute is also scary at times.
Old 05-26-2010, 09:24 PM
  #427
mc_holla's Avatar
Also, who here has actually had just their bushings pressed out and replaced? How much would you save doing that over replacing arms?
Old 05-27-2010, 09:15 AM
  #428
Tripnbeats's Avatar
i had mine replaced by the dealer before I did my poly ones... then i pressed my poly ones in..... last week i took the poly ones out which are still in good condition and while the car was at the dealer getting a major overhaul.....i had them press the ones i made with window weld on the car.... not a huge difference in control the only thing is.....bumps are so much more rigid and hard hitting like if i go over a speed bump you feel it more.....but cornering with the car now and having the type s rack n pump and all new PS lines in, feels amazing
Old 05-27-2010, 09:21 AM
  #429
Tripnbeats's Avatar
and i dont mean speed racer cornering....i mean like 30mph and taking a turn on a street or something it just feels great.... im gonna take it on a run one of these days and see how it feels at higher speeds but im not looking for tickets lol so that'll be later on in the summer
Old 06-14-2010, 08:49 PM
  #430
4th Gear
ord0nez's Avatar
For those of you that have replaced your lower control arms, where did you purchase them from? Is OEM the only option or does anyone make aftermarket. The lowest quote I got was $211 each for acura control arms...should I just go with those? Thanks
Old 07-05-2010, 12:52 PM
  #431
SHAWD 04TL is in
TRIOD3SIGNS's Avatar
Mine went in this morning for the bushing issue, I included a 13 page printout of this thread.... I'll keep ya guys updated. Its good news to see that corporate is keeping good to most of these issues.
Old 07-06-2010, 09:58 PM
  #432
NBP is a pain...
gotkilled's Avatar
Any aftermarket bushings available for the control arm? Is it possible to just use window weld and just repair it myself by squeezing some of the compound onto the bushing?
Old 07-07-2010, 01:02 AM
  #433
SHAWD 04TL is in
NO go for mine yet, it got denied by the ACURA rep that happened to be in the Dealership at the time. hmmmmmm?
Service Manager says hes going to submit to ACURA again.
Old 07-08-2010, 02:16 PM
  #434
daoism76's Avatar
when i got my oil change today at honda dealership they told me the driver and passenger lower control arm bushings are cracked. mine is 06 tl with 93k miles on it. i plan to keep it til about 150k or 2-3 years. do i need to get it fixed soon? what happens if i don't? thanks in advance
Old 07-09-2010, 07:34 AM
  #435
Danronian's Avatar
From reading this thread it seems the crack can develop as quickly as at 20k miles. Unless there is a small amount of rubber left "uncracked" I think it will be fine from what people are saying. Mine as about 90k miles and they are about 1/3 cracked. If they get more than half cracked, I'll think about replacing.
Old 07-11-2010, 02:15 PM
  #436
4th Gear
OCTLS's Avatar
08 TL-S w/ 40K miles and my front lower control arm bushing also have the small tears at the same location as shown in your photos. These bushings should have a design life of 200K miles and not 50K miles or less.
Old 07-11-2010, 02:20 PM
  #437
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
Mine were cracked by 20,000 miles. The driver's side tore so I replaced that one. I'm in a lawsuit with the bodyshop right now and Acura found my front toe out by nearly 5 degrees due to a torn passenger side bushing. So yes, they can make a huge difference in how the car handles.
Tripnbeats, did you make your own poly bushing or can we buy those somewhere. I'm in the market for one right now.
Old 07-13-2010, 12:03 PM
  #438
saetneta's Avatar
Well, I think I have a record... got a quote from our local dealer in 2 ways...
First - I supply the removed control arms and the bushings: $480 to press in the bushings. I confirmed that this is just to press in the bushings... guy said that his foreman confirmed that this is just to press them in.
Second - They do all the work with new bushings: $1,077
Amazing.
Oh yeah, the guy said he's been with acura for 12 years and has never heard of this.
Old 07-13-2010, 08:03 PM
  #439
'06 NBP TL 5AT NAV
Waveform's Avatar
01tl4tl please reply if you're out there...
I recently had my lower control arms replaced under warranty.
Well, almost under warranty.
I brought my '06 TL w/29,000 miles to the dealer for my final warranty service to have the sticky side mirrors, a loose drivers seat and the cracked control arm bushings (all known problems) repaired. I was put in a loaner and the next day was informed that my warranty had expired two days before I brought it in for service. The service writer explained that the warranty begins at the signing of the contract when the new car is ordered, not when delivery is made and it's driven off the lot.
I had a dissapointing discussion with the service writer where he refused to service any of my repairs under warranty. So I scheduled a meeting with the service manager for the next day who listened to my story and looked up my customer history. My history showed that I had purchased the TL form his dealership and that I had all my services done in his shop (oil changes, inspections, recalls and other warranty work). Based on that history he kept the car, put me in a loaner and said that he would see what he could do.
Two days later I picked up my TL with new control arms and new mirror actuators, but the seat repair was denied as it was deemed to be "within the normal specs of the TL".
I was also told that this was my "ONE TIME only customer goodwill" repair and that Acura and the dealership had fulfilled all obligations to me their customer.
I guess two out of three ain't bad and the seat is the easiest and least expensive repair to do yourself, but I still wonder about the one time thing. Is that true? Does Acura do you that way as a matter of policy?
Old 07-13-2010, 09:47 PM
  #440
Anyone know if the TL-S uses a stiffer compliance bushing like it does for the tophats?
Quick Reply: '04 to '08 front lower control arm bushing failure - please read and look
