Rattling noise when accelerating between 1 and 2 RPM?
Old 05-16-2009, 03:02 PM
TEAM_SONIC
Sondinh's Avatar
When driving today, I suddenly heard a rattling noise. During a stop the engine sounds normal, but when I am about to accelerate I heard a rattling noise (sounds like some is scratching in the front). The rattling only happens when the RPM is between 1 and 2 RPM. After that the engine performs normally. Does anyone know what the problem is? Thank you.
Old 05-16-2009, 03:11 PM
JnC
Former Sponsor
JnC's Avatar
It could be the belt tensioner, I have the same issue as well, if I recall correct there is a thread on it somewhere as well.
Old 05-16-2009, 07:21 PM
TEAM_SONIC
Sondinh's Avatar
Will this be safe to drive without fixing in about one month?
Old 05-16-2009, 07:34 PM
handsom-hustla's Avatar
i have the same problem. everytime i bring it into service all they do is tell me they tightened something that was loose.. but the problem continues. its like a rattle or vibration.and its only at early rpms no mater how fast im goin..
Old 05-16-2009, 10:46 PM
TEAM_SONIC
Sondinh's Avatar
I just want to note that the noise sounds like a rattling in a can. It only happen when it is between 1 and 2 RPM? Hope that will descriptive enough.
Old 05-17-2009, 07:34 AM
7th Gear
specter116's Avatar
well my friend i had the same issue and guess what it was for me.... my right side lower grill, in the front bumper...if that would help. mine got loose because every time i go in and out of a driveway i dont have enough clearance and my front would scrape
Old 05-17-2009, 11:27 AM
JnC
Former Sponsor
JnC's Avatar
Here is the thread with more info on the problem and the fix.
https://acurazine.com/forums/3g-tl-problems-fixes-114/2005-tl-chirping-noise-engine-626763/
and here is a my video (which I made for the exhaust) in which you can hear the rattling sound. You'd notice the sound in the beginning of the video when I roll next to the camera and come to a stop before revving the motor.
http://www.youtube.com/watch?v=nZcc2...e=channel_page
Old 05-21-2009, 06:35 PM
jdubub's Avatar
same damn problem here!! every time i go to pinpoint it or go to my mechanic it wont make the noise!? lol go figure but im sick of it!
Old 05-25-2009, 07:58 PM
davewhodavedunn's Avatar
I KNOW EXACTLY WHAT IT IS...I just bought my TL and I had that exact same thing. It sounds like a little metal ball in a tin can around 1-3000 rpm...it's a loose bolt under the front passenger side right by the heat shield. My mechanic tighted it up and GONE....
Old 05-25-2009, 10:10 PM
practicing nihilist
NedShneebly's Avatar
well, to add to the 'possible' rattle list: do you have a CAI? My CAI was vibrating against a jumper just under the pipe and I recently found it was contacting the frame just slightly after modifying the pipe for P2R throttle body spacer. I also noticed the radiator has a lot of play. I mean, they're supposed to be vibra-mounted and move a bit, but it's like 3/4" back and forth.
Old 07-15-2016, 12:58 PM
4th Gear
sober72's Avatar
Sondinh.....I was having the same issue with my 2007 X. Mine started doing it right after the engine was warm and would even do it when sitting still....if I revved the motor slightly. I had my daughter work the gas pedal while I searched. I found the culprit right under the front of the vehicle. There should be a couple of holes in the plastic underbelly in front of your vehicle. It's just a hair to the passenger side from the center of the engine. The exhaust comes straight down and I found the heat shield just below was the problem. There was a rusted area at one of the attach points for the two shields and an actual crack. I used a couple of large metal hose clamps together to have enough reach to go around both sides of the heat shield. It may be impossible to get to by the average guy. Luckily my arms are long and small enough to get to the area, barely. I was able to tighten it enough to stop the noise. Noise is gone.
I know this is an old post....just hoping to help anybody else in the future who may do a search like I did to try and solve this particular problem.
Old 07-17-2016, 11:48 AM
WDPanda's Avatar
This noise is almost always the catalytic converter heat shield. Large hose clamp can fix the noise.
Old 12-18-2017, 03:53 PM
mrphilipanderson's Avatar
Im glad im not the ONLY guy. So annoying!
Old 12-18-2017, 03:54 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
I'd be checking the heat shields.
Old 12-18-2017, 10:15 PM
stevemk07's Avatar
Agreed. On both my TLs the one under the car covering the cat was the problem.
Old 12-19-2017, 09:37 AM
The one under the car covering? What would be the best way to pinpoint to the mechanic to tighten?
Old 12-19-2017, 09:48 AM
Latent car nut
horseshoez's Avatar
I had a nasty vibration on a car a couple of years ago, I ended up creating a long "red-neck stethoscope" (a length of garden hose), and routing it to various areas where I suspected the noise was coming from; I even had to resort to running the hose and securing it so I could drive the car with the hose held to my ear. I finally localized the noise to the area between the rear cylinder bank and the firewall, and when I dug in there I found a single snapped off bolt head sitting in a concave depression on top of a heat shield. The thing was, it took me an hour of tearing stuff apart to get there, only to find/remove the bolt head out, throw it away, and then another hour to put everything back together.
Old 12-19-2017, 10:01 AM
Received 16,260 Likes on 11,971 Posts
if you tell the mechanic "catalytic converter heat shield"
he should be smart enough to figure out where it's at. it will also be very apparent as bolts will be coming undone.
Old 12-19-2017, 01:45 PM
stevemk07's Avatar
I could not tell anything wrong before clamping mine down... Seemed secure even when tapping it but sure enough it fixed the rattling.
justnspace (12-19-2017)
Old 12-19-2017, 01:49 PM
^good to know!
MrHeeltoe
20
02-23-2023 01:54 PM
Mike734
12-10-2021 01:25 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Rattling noise when accelerating between 1 and 2 RPM?
