DIY: S4Play Rear Replica Diffuser Install
Old 06-18-2016, 11:42 AM
DesertMistTL's Avatar
DIY: S4Play Rear Replica Diffuser Install-bo6nvku.jpg
Found this diffuser on the Lexus form and decided to give it a shot.
DIY - How to install a S4play Diffuser - Club Lexus Forums
I based this DIY off another DIY on the lexus forum but we will have a few changes.
First, the distance between muffler cutouts on the ASPEC Lip is about 35"+. This diffuser is about 32.75", so it fits! It should also fit base models and base aspecs.
My bumper is completely cut to fit the ASPEC, so I dont have this bumper flap http://i17.photobucket.com/albums/b6...2/IMG_3582.jpg
I was able to clip in my diffuser to OEM rear bumper mounting points with clips because I dont have this flap. You may need to use a bolt and washer. HIGHLY recommend taking off your bumper.
Materials Needed:
-Diffuser (For IS250 is350 isf Bolt on Unpainted Rear Bumper Diffuser Chin Lip Add on Kit | eBay) I believe it's just universal, I see it for camry and other cars--dimensions are th same
-Hex Screws + nuts (black)
-Paints tape
-Hack saw to trim
-Dremel/drill to drill holes
Step 1:
You need to drill out the existing holes to accommodate the larger hex screws. I didnt use the ones that came with it because they looked cheap and were shiny. Plus the black hex looks a lot cleaner and professional.
Here is a diagram of how I mounted mine. (4) OEM clips in the back, and 6 hex screws in front.
DIY: S4Play Rear Replica Diffuser Install-rgzmfkn.jpg
Step 2:
Trim the center fin, or 4th one to clear the tow hook.
DIY: S4Play Rear Replica Diffuser Install-kwuhc0v.jpg
Step 3:
Take off bumper--I'd recommend this unless you like shoving your hand behind your bumper to tighten nuts
Step 4:
Here is where taking off your bumper would have come in handy. You need to put the diffuser up against the bottom of the bumper. It should fit flush with this gas tank cover/It's the plastic trim that the rear bumper mounts on to. We need to mark on the diffuser where these holes for the OEMS clips are to drill. So you can either try to mark it from the top or take your bumper off and do it easier.
OR You can just drill directly through the diffuser into the bumper and not use the clips--probably easier. I dont have the bumper flap because I cut it out.
Try to center the holes as much as possible. Use the middle fin as a guide.
DIY: S4Play Rear Replica Diffuser Install-s3reigy.jpg
DIY: S4Play Rear Replica Diffuser Install-mecwydk.jpg
Step 5:
After you have found how to mount the rear of the diffuser, clip the diffuser in
DIY: S4Play Rear Replica Diffuser Install-hlouyev.jpg
DIY: S4Play Rear Replica Diffuser Install-8hy6bfi.jpg
Step 6
With the rear diffuser clipped in, use painter's tape to get the lip flush against the bumper--it should look close to how you want it because we are going to drill into the bumper in these locations.
DIY: S4Play Rear Replica Diffuser Install-ehuttfo.jpg
Step 7
Drill into the bumper holes for hex screws
DIY: S4Play Rear Replica Diffuser Install-k9ouzjv.jpg
Step 8
Tighten all hex bolts, will be very hard if you have your bumper off.
I highly recommend everyone take off their bumper and get 1/2" nut and bolts to mount to rear bumper mount location
DIY: S4Play Rear Replica Diffuser Install-rwv9odv.jpg
DIY: S4Play Rear Replica Diffuser Install-g4j31zz.jpg
The following 10 users liked this post by DesertMistTL:
ATN (06-18-2016), EvilVirus (07-15-2016), ggesq (06-18-2016), hannamand (07-01-2016), LoveMyTL-S (06-19-2019), rockstar143 (06-28-2016), rossv1 (06-19-2016), skd2k1 (07-22-2016), sockr1 (06-22-2016), Undying Dreams (08-29-2016) and 5 others liked this post. (Show less...)
Old 06-18-2016, 01:44 PM
ATN
ATN's Avatar
Looks real good.
Old 06-18-2016, 01:45 PM
peewizzle's Avatar
I like it, wonder how it would look on a regular A-spec rear lip I kinda want to pull the trigger and order one now
Old 06-18-2016, 08:00 PM
this person also did it on base aspec
The following 4 users liked this post by DesertMistTL:
EvilVirus (07-15-2016), LoveMyTL-S (06-19-2019), Murders23 (06-19-2016), sockr1 (06-20-2016)
Old 06-19-2016, 04:27 AM
Rev High; Drive Happy
o4Komodo's Avatar
Good to see other people go out and explore new things (as such, parts from other cars).
Old 06-19-2016, 11:36 AM
ryanfett's Avatar
I'm not usually one for diffusers but that looks really good. Great writeup man
Old 06-19-2016, 11:20 PM
rossv1's Avatar
Looks awesome. May have to follow suit and order one.
Old 06-20-2016, 12:06 AM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
let me know if you do I would like to see more pics on a wdp!
Old 06-20-2016, 11:39 PM
Gmo-S's Avatar
looks great!
Old 06-21-2016, 12:40 AM
peewizzle's Avatar
dangggg I really want now!
Old 06-21-2016, 01:01 AM
Received 8,584 Likes on 6,630 Posts
Dangggg looks mean!
How many Hpees should I expect?
Old 06-21-2016, 06:35 AM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
It helps keep you planted in the corner, noob
Old 06-21-2016, 07:29 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
That looks outstanding.
Old 06-22-2016, 09:37 AM
sockr1's Avatar
Materials Needed:
-Paints tape
-Hack saw to trim
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6
Step 7
Step 8
so i can't tell from your writing for sure, but sounds like you did this without removing the bumper? I'm thinking about doing this, but i'm trying to avoid taking off my bumper because i was a victim of a hit and run and i'm afraid to take my bumper off and not be able to get it back on (i was hit in the rear left corner where the bumper curves around to the side and i had to use silicone sealant to keep the side of the bumper from flaring out where it normal clips in).
long story short, is there anything that can't be done with the bumper on and in short summary, what are the hardest parts about installing this with the bumper on?
thanks again for the DIY! i think this adds a nice aggressive looking touch even though it's fake haha
Old 06-22-2016, 02:23 PM
GOOSEej's Avatar
dang! I was actually thinking of doing this for a while now. diffuser been sitting in my garage for a bit now. Glad to see someone with tl did it.. Maybe ill come around to finally installing it.
Old 06-22-2016, 03:28 PM
BreezyTL's Avatar
not sure if I like it, but I do like how unique it is. you don't see many, if any, diffusers on these cars.
Old 06-23-2016, 01:28 AM
you can do it with the bumper on, it's just when you get to threading the nut and bolt in the front, might have a hard time reaching in that far.
I was able to do it easily because I dont have the bottom part of my bumper--i cut this off when I installed my aspec lip on my 05
bumper off would be good so you can measure the distance between the oem clips so you can mark where to drill on your diffuser.
Old 06-23-2016, 01:32 AM
sockr1's Avatar
^^ thanks! did you dip your diffuser or does it come black like that? seems like it blends in pretty well with the small balck area on the aspec lip
Old 06-23-2016, 01:50 AM
it comes that way, i was going to paint it but ran out of time. It'll probably fade over time but i'll just spray it next time.
Surprisingly this is as far back the diffuser goes to be able to clip into the back and it fits flush against the lip coincidentally.
Old 06-28-2016, 11:56 AM
hannamand's Avatar
Thanks for the write up, looks badass!
Does anyone have any data on if this improves aerodynamics?
Old 06-28-2016, 05:19 PM
You mean track times at buttonwillow? I highly doubt it.
Old 06-28-2016, 10:02 PM
my butt dyno felt like the car moved .00000019 faster as I pulled up to Mcdonalds.
Old 06-29-2016, 07:55 AM
hannamand's Avatar
"Butt Dyno"!!!! ROFLMAO.
Old 06-29-2016, 08:00 AM
Received 16,260 Likes on 11,971 Posts
Holy crap, I thought this was a DeathMetal DIY!
which means desertmist, that your write up is on par with some of the best on here! Good job!
also looks super fresh! might want to try on my car
Old 06-30-2016, 03:32 PM
dookie320's Avatar
Looks great, might be in my future!
Old 06-30-2016, 07:13 PM
I just want to watch Justin install it on his car.
Old 07-13-2016, 11:57 AM
GOOSEej's Avatar
This thread inspired me to put on my diffuser
Old 07-13-2016, 12:59 PM
sockr1's Avatar
^ can you put up some more pics from other angles and further away? Also did you take off the bumper to install it or have any other tips?
Dion Rodella (03-03-2020)
Old 07-13-2016, 07:42 PM
Looks great.
Old 07-16-2016, 09:27 AM
llllBULLSEYE's Avatar
looks great need more pics please
Old 07-16-2016, 11:34 AM
TrujilloMedia's Avatar
Looks amazing I would want to do this to my car.
Where can you find a front diffuser for the TL's?
Old 07-21-2016, 11:54 AM
prove_it's Avatar
I want more pics and angles. Really hard to tell the looks.
Old 07-22-2016, 01:39 AM
here are some more pics, i think all the pics in this thread give a good idea what it looks like
DIY: S4Play Rear Replica Diffuser Install-6dtzukbr.jpg
DIY: S4Play Rear Replica Diffuser Install-y9x715m.jpg
llllBULLSEYE (07-22-2016)
Old 07-22-2016, 09:20 AM
Thanks for the pics and yeah I want it asap
Old 07-23-2016, 02:05 PM
The Acura Noob
tlbase04's Avatar
Is there any benefits to adding this on, or just more for aesthetics?
Old 07-23-2016, 06:50 PM
i shaved 1000th of a second off my quarter mile.
Old 07-25-2016, 08:43 PM
Congrats!
Old 07-28-2016, 11:45 AM
now on a KBP! Looks a lot better here
DIY: S4Play Rear Replica Diffuser Install-hlb4dnp.jpg
Old 07-28-2016, 11:59 AM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
What the hell? Is that a lip spoiler on a lip spoiler?
And those rear side lips....double
*You know they're affordable when....*
Old 07-28-2016, 12:17 PM
Did he hit a curb? wheels look funny
Q_ShipTL (01-09-2017)
Quick Reply: DIY: S4Play Rear Replica Diffuser Install
