TL Diet 2.0/Track Car Build - Roll Cage Pg 51
Old 01-22-2011, 09:08 PM
  #41
Your Friendly Canadian
Aman's Avatar
Received 1,484 Likes on 1,048 Posts
You could probably sell the nav and get a gauge pod... just something to think about. What's your DD?
Old 01-22-2011, 09:20 PM
  #42
B A N N E D
friesm2000's Avatar
P/S delete , not only for the weight but also better feedback, since no assist will be there (and considering it is a track car, due you really need to do parking lot maneuvers)
but
  #43
AZ Track Whore
vill0169's Avatar
Yeah I might put some gauges in the center vent / hazard button area. My DD is an 02 TL.
Old 01-22-2011, 09:25 PM
  #44
AZ Track Whore
vill0169's Avatar
but
Well on and off the trailer could be tricky but it wouldn't hurt. It is still a big car to not have power steering in.
Old 01-22-2011, 09:30 PM
  #45
B A N N E D
friesm2000's Avatar
Originally Posted by apnorm
Totally agree. I love being the "underdog" at track events. A lot of people come up to me after a run group session asking me about the car. Is it the ideal track car? No. And that makes it that much more special.
It also doesn't make sense financially (at least for me) to sell my car for 13k(?) and pick up a used M3 for 20k+ and then make it into a track car. I'm confident that the TL can take the abuse and will be pretty reliable going forward. I don't have that same warm feeling with a used M3.
Anyways, enough of my "rant". How about some pics of the interior!
don't you mean meets for street cars (but yes i get the same kinda thing with my 2g though, in that most people are like WTF, when they see that it can actually move some (not quite sti or M3 territory though yet, but hopefully one day though )
and as far as being a reliable race car, sometimes that is what it takes, and not quite being the fastest out there (look at endurance racing)
Old 01-22-2011, 09:41 PM
  #46
B A N N E D
friesm2000's Avatar
so you line it up beforehand, not like you turn while going up onto the trailer (hopefully)
and i think with the car being way lighter then stock it should help ease some of the force needed to turn
also i have heard, that when you do connect the lines together on the rack, and run them to a reservoir (on a 98 accord V6 btw), it does ease up some of the steering effort, because you are no longer pushing fluid through the pump and such with the engine off
btw on the 2g TL DD; type-S at least?
edit: and considering that it is a track car, and probably would not care about it being tinny sounding inside, maybe cut out all the interior sheetmetal of the rear doors, and cover it with aluminum or CF sheet, so no sharp edges are exposed
Old 01-22-2011, 09:55 PM
  #47
Rev High; Drive Happy
o4Komodo's Avatar
Wow fantastic. Would love to see what else you have in store to share.
  #48
AZ Track Whore
vill0169's Avatar
Well I don't what experience you have with track paddock areas but some can be very full and hard to maneuver though. Overall I've thought about it before but for now it stays.
My 02 is just a nice comfy cold blowing AC base and its perfect for me.
Old 01-22-2011, 10:02 PM
  #49
B A N N E D
friesm2000's Avatar
but then again how often do you really pull off and on the trailer? (like once a day at the track itself?) just wondering really... cause i know my 03 type-S (full weight) is doable without P/S if needed (and that is with 245's on there too), not fun though, but it can be done though (so would the additional effort needed occasionally needed be worth the time gained on the track?)
and the base model , but then again you do have a track car, so you can get your thrills at the track instead...
also have you put a light weight clutch/flywheel in yet? there is once place to save some weight...
Old 01-22-2011, 10:15 PM
  #50
AZ Track Whore
vill0169's Avatar
I'm saying even a track car has to be comfortable with plenty of slow driving as well as fast so power steering isn't completely dead weight and I run at least 255's on the track as well.
And yes, I have no reason to get my jollies on the street anymore and the roads in Pensacola suck anyways.
Aftermarket clutches don't have a good track record so OEM for me. Just replaced it too.
Old 01-22-2011, 10:32 PM
  #51
B A N N E D
friesm2000's Avatar
ok so wide tires also then..., then maybe put on a toyota MR2 (like 92 to 95 or so...) PS pump then.... (it's electric over hydraulic, so you could flip it on when needed, and leave it off for the higher speeds....)(and mount it to the crossmember or something, so the weight of it is further back and lower then the stock pump, let alone not having to spin it when not needed...
so far having good luck with my CM stage 3; 9-puck design (i blew through the normal stage 3, full faced, in like 2-3k miles not treated the nicest though, but still should have lasted longer though)
and maybe just put on a light weight flywheel, and keep the disc and pressure plate stock for the time being...
Old 01-23-2011, 01:16 AM
  #52
csmeance's Avatar
Received 1,988 Likes on 1,412 Posts
Another weight savings Idea
I've read both your thread and Innacurates and must give both of you an applaud for your dedication!
One thing I've found over the course of my time here is that the 2004-2006 TL has MUCH heavier intake manifold than the 2007+ TL. I remember reading somewhere that the 2007-2008 3.2L manifold is a Magnesium Alloy which is about 20lbs lighter than the stock Intake Manifold from the 2004-2006 3.2L. I'm not sure what the 2004-2006 one is made of, but it's worth a shot at trying to save some more weight, esp on the front of the car!
As far as gauges go, have you considered making a "trim" piece out of CF and plugging up the glovebox area or under the radio and putting your gauges in that? I'd be minimal weight and it would look nicer as well!
Old 01-23-2011, 03:26 AM
  #53
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
Great Job...
waiting on more pics
Old 01-23-2011, 07:08 AM
  #54
AZ Track Whore
vill0169's Avatar
Thank you sir!
I have read the same info on the intake manifolds although it does come at a hefty price! My other theory about weight over the front wheels is that you don't want it to be "too" light. Meaning that with FWD, for every pound of weight you lose over the front end, there is a proportional amount of front end grip lost as well. I know this would be an extremely small amount but I would like to get the car on a track first and see how crisp the turn in is and if it has any "push" through the corners and use that to determine if more weight can come off the front end.
But a great suggestion!
As far as gauges go, a track car is the definition of utililty. Yes, gauges would look nice beneath the radio or filling the glove box hole. However, having to look down or over that far while on the track wouldn't quite be ideal. This is why I plan to make a 2 or 3 gauge pod out of the center vent piece. Its useless to me now and is in a very convenient place to look while driving. Unlike the redonkulous A pillar gauges that just obstruct your forward view.
Thanks again for the compliment and suggestions
Old 01-23-2011, 11:03 AM
  #55
B A N N E D
friesm2000's Avatar
maybe mount the gauges where that center speaker goes up on the dash
Old 01-23-2011, 11:19 AM
  #56
Aman's Avatar
Have you done anything to the exterior as far as weight savings? It'd be cool if you replaced the factory mirrors with those tiny ones (forget the name), I think Accuratein has 'em on his TL. Just an idea
As far as the weight vs. turn in thing, wouldn't any weight lost more than make up for the grip "lost"?
Old 01-23-2011, 11:30 AM
  #57
B A N N E D
friesm2000's Avatar
thinking the same thing, but only with the suspension tweaked afterwards for the weight balance change
Old 01-23-2011, 12:39 PM
  #58
AZ Track Whore
vill0169's Avatar
Well I guess only time will tell. I was speaking from how the car felt the last time I was on a track in October and hadn't lost all the weight. It is certainly probable some suspension changes can fix any understeer I encounter was just saying I don't want FWDitis too bad lol
Old 01-23-2011, 02:31 PM
  #59
B A N N E D
friesm2000's Avatar
think about the SPEED world challenge, and those FWD cars, they have wings in the back to keep the back end planted (it just a matter of the suspension setup and how it is tweaked, basically VERY STIFF rear springs (or sway bar) to take some of the loads/forces off the front end (basically making the rear end due more work, so the front can turn harder)
Old 01-23-2011, 04:24 PM
  #60
I'm Craig
cjTL's Avatar
FWIW, removing the nav would save quite a bit of weight. I've taken it out of my car and that unit is heavy heavy.
Old 01-23-2011, 07:41 PM
  #61
B A N N E D
friesm2000's Avatar
also about your exhaust weight, how about a side exit, or even a turn down, basically not have any piping for the exhaust
Old 01-23-2011, 07:52 PM
  #62
I got the Shifts
phee's Avatar
im on a slight diet, i guess you can say my car is a vegan while yours is anorexic.
Innacurates will soon be bulimic with the nitrous
Old 01-23-2011, 08:08 PM
  #63
B A N N E D
friesm2000's Avatar
Old 01-24-2011, 04:00 PM
  #64
AZ Track Whore
vill0169's Avatar
Weight update
With a nearly empty gas tank and the front door panels out I weighed in today at 2820 lbs! Still unsure what's next on the chopping block but I'm sure I can find something to eliminate!
Old 01-24-2011, 04:01 PM
  #65
Received 16,260 Likes on 11,971 Posts
^nav.
Old 01-24-2011, 04:46 PM
  #66
myron's Avatar
Maybe you lose some weight too jk
Old 01-24-2011, 06:00 PM
  #67
AZ Track Whore
vill0169's Avatar
Some new pics for ya'll
Trunk area, Think it would be benefitical to put some extra cross bracing where those chassis braces are between the trunk area and the rear seat area?
Trunk shot, I do need to upgrade to a smaller battery but at least it's in the trunk for now.
Interior
Plan on cutting this extra metal out that was used to hold up the glove box. Make it a little cleaner and make it easy for a passenger to get in and out.
Yes it's dirty but here's the absent AC compressor area.
Again dirty but engine bay shot.
With the plastic windshield cowl out you can really see where the air system took it's air in!!!
Parts, parts and more parts! And there's more out of shot too
I'm going to fiberglass over the duct here and put a battery kill switch here eventually.
Here are some shots from my last track day before leaving Minnesota. There are plenty of comments on these in my "TL Track Bound 2" thread so no need to fill up the thread with comments on these just posting them cuz I'm a nice guy!
Old 01-24-2011, 06:02 PM
  #68
AZ Track Whore
vill0169's Avatar
^nav.
Nah, have some great plans for the navi! Stay tuned
Old 01-24-2011, 09:24 PM
  #69
Inaccurate's Avatar
My favorite pic is the void under the dash where the AC duct was before.
Wow, that pic is really tempting but I know that I can't delete my AC. I did that with my Camaro and forever regretted it in the Houston heat. Even winters were a pain with the constant interior glass fogging from the lack of AC to dehumidify the damp Houston air.
Have you removed the bumper beams yet?
Old 01-24-2011, 09:36 PM
  #70
so, what are you planning to do?
Doms unit?
Av electronics unit?
Isimple?
did you get the back up cam?
you created two threads about the navi, but never told your plans
Old 01-24-2011, 09:41 PM
  #71
AZ Track Whore
vill0169's Avatar
Oh those have been gone for while! I weighed the windshield wiper motor assembly today and its about 8 pounds total so I put it back for now, not THAT desperate for weight loss.
Old 01-24-2011, 09:45 PM
  #72
AZ Track Whore
vill0169's Avatar
Doms unit?
Isimple?
Yeah doing the Dom's unit with the TV out app so I'll be displaying one of the data logging / performance gauge apps on my navigation screen. Will be a lil expensive but think it will be new, fun, and different so I wanna give it a shot.
Old 01-24-2011, 09:49 PM
  #73
the doms unit can be had for cheap. check the black market...ive seen some go for 160.
also check ebay.
Old 01-25-2011, 09:27 AM
  #74
J35 _ 5 Speed A/T
WHEEELMAN's Avatar
....Think it would be benefitical to put some extra cross bracing where those chassis braces are between the trunk area and the rear seat area?
for a sedan, it could help. However, Ultra Racing chassis braces would do more as far as handling/stiffening up the chassis.
Thanks or sharing man. This stuff crosses over to the 98-02 Accord Coupes.
Old 01-25-2011, 09:07 PM
  #75
B A N N E D
friesm2000's Avatar
heres the one issue though, is that it is a 3g TL, not a 2g TL, so it would crossover to a 7th gen accord (03-07) if anything
Old 01-25-2011, 09:12 PM
  #76
I got the Shifts
phee's Avatar
but it does crossover because the cars sit on the same frame anyway
Old 01-25-2011, 09:30 PM
  #77
B A N N E D
friesm2000's Avatar
what the 2g TL and 3g TL? or the Accords and the TLs?
Old 01-26-2011, 08:05 AM
  #78
AZ Track Whore
vill0169's Avatar
Ok ok this cross over stuff is better served elsewhere. Lets keep this 3g TL diet discussion plz!
I've been thinking and here is the plan to get her to 2700 lbs someday.
Current weight is 2820lbs
Windshield wipers : 10 lbs
navigation unit : 20 lbs
Lexan windows : 40 lbs
Track wheels : 40 lbs
And the last ten pounds could be done with two piece front rotors or the power steering plus what ever weight is lost with the steering wheel conversion. Not to mention I can always pull the passenger seat for and instant 15-25lbs right there.
Pretty sure that would be the TL Diet 3.0!
Old 01-26-2011, 09:32 AM
  #79
J35 _ 5 Speed A/T
WHEEELMAN's Avatar
Damn fine reduction.
We have a member over on V-6-P that has a 7th gen accord coupe. He made his car a dedicated Track car and the total weight was 2655 lbs., 2800lbs with driver.
**The weight reduction methods, including the sunroof plug, cross over to the 98-02 Accords based on both Inaccurate's and vill0169's TL-diet threads.
Old 01-26-2011, 09:34 AM
  #80
Comptechtl2367's Avatar
Just a question, but if you are going this drastic and in depth why not pull the nav, full dash and radio? Make a dash bar when you put a cage in and attach the cluster and what not to that?
And wipers are 10lbs?! Maybe the full system inc motor, linkage, and what not.
Quick Reply: TL Diet 2.0/Track Car Build - Roll Cage Pg 51
