Spark Plugs for Comptech Supercharger
Old 09-28-2015, 10:10 AM
Joe Avesyan's Avatar
Hi guys,
Just picked up a supercharger for a Automatic 2005 Acura TL and wondering if I should stick with regular spark plugs or should I go with one step colder plugs. I also want to be able to drive my car without the supercharger if need be.
Thanks for any help
Old 09-28-2015, 10:18 AM
Received 16,260 Likes on 11,971 Posts
what?
if you want to drive without the supercharger, Dont install it.
Old 09-28-2015, 10:26 AM
ulrblitzer's Avatar
Not sure if OP understands how a SC works .. or if he's wanting to run colder plugs just for the heck of it while the SC becomes a paperweight on his garage floor.
Old 09-28-2015, 10:28 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
1) One step cooler is only detrimental to the spark plug if detrimental at all.
2) Without a proper tune and proper safeguards against knock, you're going to have a bad time.. mmmkay. S/C kit isn't slap on and go as many would like you to believe.
3) AT transmission..
The following 2 users liked this post by Majofo:
EvilVirus (09-28-2015), Vlad_Type_S (09-29-2015)
Received 8,575 Likes on 6,626 Posts
Old 09-28-2015, 10:29 AM
Majofo's Avatar
Member since 2007.. 5 posts..
He be lurkin'
Old 09-29-2015, 10:55 AM
No no no... apparently I wasn't clear. Let me rephrase
1 - If I install supercharger do I NEED to change the spark plugs that are currently in my car to colder plugs.
2- If I do need colder plugs and the supercharger breaks, stops working, needs maintenance etc, and I remove the supercharger, then do I also need to change the colder plugs back to regular plugs.
Thank ya
Old 09-29-2015, 11:03 AM
supporting mods; do you need them? no, but it helps support and provide power.
Old 09-29-2015, 11:37 AM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
The CT kit literally comes with spark plugs. That should answer your questions.
Old 09-29-2015, 03:57 PM
UTAH TSX's Avatar
Yes you must use colder plugs with SC or pre ignition is possible from the plug electrode or ground strap glowing red hot, no you do not need to take them out if you remove the SC they will just get dirty faster and possibly foul out,
The following 2 users liked this post by UTAH TSX:
Joe Avesyan (09-30-2015), zeta (10-04-2015)
Mike734
12-10-2021 01:25 PM
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
Quick Reply: Spark Plugs for Comptech Supercharger
