Exhaust Suggestions
Old 03-26-2012, 01:59 PM
Texass683's Avatar
Exhaust Suggestions
Hello all,
I am new here, and new to the TL lifestyle in general. I am looking into getting an exhaust system and have had trouble pinning down what I want. First off I do not want my car to come out sounding like a teenage ricer-mobile. If I had wanted that I would have bought something closer to that way of life. This is my daily driver, which I drive to my job at the courthouse, so as you can see I don't want an overpoweringly loud exhaust.
What I am essentially looking for is a freer flowing exhaust that brings out the original exhaust to a little louder, semi-beefer note. I don't want to be setting off alarms in parking garages, just something that when it's at full song stands out. Any help would be appreciated in an facet.
Thanks in advance and look forward to talking shop with y'all.
Old 03-26-2012, 02:02 PM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
well your options are the following...
XLR8 exhaust w/ resonator
ATLP exhaust w/ resonator
Comptech exhaust w/ resonator
there are other companies you can go with (greddy/rv6) but they are def not quiet. no matter what you do, make sure you get one with a resonator and don't change your catalytic converters or jpipe...because that's when the exhaust gets loud.
good luck.
Old 03-26-2012, 03:12 PM
Texass683's Avatar
Is there a cheaper route to take?? I would ultimately like to go with a full exhaust but money is tight right now ... What about a set of mufflers that will get the sound I want for now, with the ability to move up to a full exhaust later? I would also like something that would allow me to keep the stock tips ... I like the looks of the stockers in relation with the body
Again thanks in advance!
Old 03-26-2012, 03:23 PM
BANNED
sounds like you want to do an exhaust stage mod. here is the thread, and it's a cheap way to make your exhaust tone different.
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/removing-resonator-stock-exhaust-summary-post-1-1811-a-589747/
Old 03-26-2012, 04:33 PM
Texass683's Avatar
That is exactly what I am looking for! Thanks a ton for your help ... One last newb question on this topic - where might a good place be to get the angled straight pipe that replaces the mid-muffler??
Old 03-26-2012, 04:54 PM
VanyDotK's Avatar
Any muffler shop should have it in stock.
Old 03-26-2012, 06:16 PM
flappy paddles
Otacon's Avatar
Don't do the stage mods. Not worth hacking up your exhaust. Go with a Jpipe and PCDs, they will make your stock exhaust sound beefier
Old 03-26-2012, 06:21 PM
1st 3g Turbo TL-S
Xiomaro's Avatar
good luck.
So close but not...
OP listen up
Tanabe all the way for smooth not too loud
Old 03-26-2012, 06:25 PM
1st 3g Turbo TL-S
Xiomaro's Avatar
if you need further proof.
outside
and inside
Old 03-26-2012, 11:24 PM
hp1kw's Avatar
Unless XLR8 used a MUCH bigger resonator on their v2, I'd steer clear of that. My v1 was ridiculously loud, actually got pulled over by a cop because of it. I'm thinking of going the ATLP route personally as the tips look very nice and just look like they belong on the car. Currently running a Tsudo setup (was cheap) and it passed inspection in Cali by 12db. But it is a temporary thing.
Old 03-27-2012, 12:55 AM
k1x
rocking my vs-sexx!!!
k1x's Avatar
Originally Posted by Xiomaro
So close but not...
OP listen up
yup tanabe set up is legit! i had this on my 05nbp and its not "ricer loud"
it is under 93 db which is perfect for a sleeper set-up
Old 03-27-2012, 12:58 AM
One on the right for me
subinf's Avatar
Explore your options at a muffler shop. Most should be able to set you up with something that isn't very expensive.
Old 03-27-2012, 07:10 AM
BANNED
normally i'd agree with you...i hate stage mods just as much as the next guy, but i got the impression that OP didn't want to spend a lot of money.
So close but not...
OP listen up
tanabe is also a good choice for a semi-quiet exhaust...but again, the money thing gets in the way.
Old 03-27-2012, 09:04 AM
3g-s's Avatar
my friend has the comptech his tl its pretty quiet and i like the note a little more then the tanabe
Old 03-27-2012, 09:32 AM
1st 3g Turbo TL-S
Xiomaro's Avatar
Just saw this
Unfortunately for the OP since we don't have a mass production parts car the demand to supply ratio makes the cost suffer. So in short if you want to make that kitten purrrrrrr, you gotta drop some dough
Old 03-27-2012, 09:39 AM
BANNED
don't i know it...
it's quite the monopoly out there.
seller : "oh you want this part for your car? well i'm the only one that makes it so i'm going to charge $xxxx.xx for it and you're going to pay me that, k? thx."
Old 03-27-2012, 10:02 AM
Texass683's Avatar
Just saw this
Yeah I am finding that out little by little ... I am moving over from a 2002 Camaro Z28 where everyone and their neighbor's dog has some sort of reproduced part for every little niche of the car so this is a little wake up call.
I think I am gonna go with removing the resonator and chopping up the exhaust pipe mainly because it gives me the flexibility later to add a cat-back once the funds get a little better. I appreciate everyone's help ... Nice to get quick responses here!
Old 03-27-2012, 10:04 AM
BANNED
if you get a catback like we mentioned, it'll replace your entire exhaust after the jpipe. your hacked up exhaust will be taken off completely.
Old 03-27-2012, 10:25 AM
Texass683's Avatar
Yeah exactly ... That is the main reason I am probably gonna go the hacked up route to begin with!! It'll give me the sound I am looking to get for now, with the ability to chunk the whole thing later one ... Great advice and thanks a ton!
Old 03-27-2012, 10:31 AM
Former Sponsor
Excelerate's Avatar
I'm not sure when you ordered your exhaust but we implemented Purge Resonance Technology into all our mufflers, which has significantly reduced drone as well as cut down on the exhaust note a bit. So, it is throaty at WOT but fairly civil while cruising. And just FYI the ATLP setup is generally louder than our XLR8 exhaust.
Old 03-28-2012, 09:05 AM
1st 3g Turbo TL-S
Xiomaro's Avatar
don't i know it...
Yea, but you got to remember who is making the parts too. None of these guys are running a huge operation where they can just add the TL parts into another order assembly to drive the price down. Take J and R for example. They operate about an hour from where i live, and there shop is not that big... No dyno, no mandrel bender, no crazy welder. So a lot of there stuff they have to outsource which drives up the price with every guy you gota go to
LOL, kind of a one sided plug
Old 04-02-2012, 04:53 PM
Philly 3gS's Avatar
The v2 is pretty loud but dunno how much more compaired to the v1. At low gears and around 2-4 rpm its pretty loud and sounds very nice especially the back fires but when it hits 5th gear cruising it's pretty quiet.
Old 04-02-2012, 05:43 PM
1qwik6's Avatar
i may be a little biased but i say RV6 all the way. I have pcd's, jpipe and true duals and its very cival while cruising and sounds nice and deep @ wot
Old 04-10-2012, 01:44 AM
8th Gear
ProjectAK's Avatar
If performance really isnt what your looking for, just a little more masculine sound, why not just just got with removing the mid muffler? or the end mufflers, but those muffler a lot more sound than people would think. im that teenager with a complete custom exhaust setup. My car sounds louder than a Ferrari, but thats what i like.
Old 04-10-2012, 06:34 PM
1st 3g Turbo TL-S
Xiomaro's Avatar
richie does make some nice stuff. when i was NA i was bias to him too.
OP, For a quick change you can do the stage mods, but i still say go straight for a catback... TANABE!
TypeS860
09-03-2021 06:42 PM
baelim
05-10-2018 09:53 AM
joflewbyu2
10-08-2015 11:16 AM
kb1rl
09-30-2015 10:17 AM
4drviper
09-23-2015 09:00 PM
Quick Reply: Exhaust Suggestions
