PCV Valve Question?
Old 06-11-2009, 09:47 AM
XxAfG786xX's Avatar
Post PCV Valve Question?
I was thinking about removing it from the car, but wanting to know from members, would this be beneficial or would it hurt the car?
lemmy28 (08-10-2020)
Old 06-11-2009, 10:50 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
positive crankcase ventilation is to pass partially and unburt fuel and oil vapors and ring blowbye, sends them to the TB inlet pipe to go thru the combustion process again
Reduces crud into the cat and air
If you remove it you must put a catch can with internal sponge to grab the oil/vapors and clean the thing often. (as seen on old chevy v8 oil caps)
Overpressure in the engine from a clogged PCV would be a disaster
If you are track racing every day- make the change
Street drivers leave it alone- its a smog device subject to fed laws against removal
nist7 (10-25-2016)
Old 06-11-2009, 10:54 AM
Tripnbeats's Avatar
how often do we replace it 01?
Old 06-11-2009, 11:31 AM
#ForcedInductionFamily
WRXtranceformed's Avatar
I replaced mine at my 60,000 mile service per dealer recommendation. The part was pretty cheap and it was a really easy job.
Old 06-11-2009, 01:58 PM
gerzand's Avatar
Does anyone have a pic of where its located? By the TB somewhere?
Old 06-11-2009, 02:11 PM
Tripnbeats's Avatar
valve cover. right side of car left side if ur staring at the motor.
Old 06-11-2009, 02:12 PM
Tripnbeats's Avatar
wow i havent even changed mine and im waaaaaaay over 60k
Old 06-11-2009, 02:13 PM
Tripnbeats's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
piece #9
Old 06-11-2009, 07:05 PM
Yeah that looks about right. Pretty easy job, just pop in and pop out with one bolt.
Old 06-11-2009, 07:27 PM
NE14RoxCJ's Avatar
Yep, on the 3G TL, its on the front valve cover on the pass side. Held on with one bolt then some o-rings. Mine didn't rattle anymore before I replaced it. I didn't notice any difference though. Maybe the intake will stay cleaner? Maybe not??
Old 06-11-2009, 08:47 PM
gerzand's Avatar
Originally Posted by Tripnbeats
thanks bud!
Old 06-12-2009, 09:47 AM
XxAfG786xX's Avatar
yea..i need to replace mine too..my intake tracts are pitch black
Old 06-13-2009, 12:54 PM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
It's very important over the life of the car to keep acids and crap reduced in the crank case. The ultimate solution is to install a filter/seperator and then routh it back into the stock location. At that point the intake tract is only seeing clean air and not oil/fuel vapors. You do need it for proper circulation of crancase vapors.
I don't run a PCV on my other car, just open breathers and I change the oil every 1,000 miles partially because of this.
For those of you with the black intake tract, what kind of oil are you running? I've been running the Amsoil ACD for most of the car's life which is a grp IV/V and my intake still looks new.
Old 06-13-2009, 03:34 PM
Green Machine
t0talacuratl's Avatar
Do we need to change the o-rings as well?
Old 06-14-2009, 02:55 PM
XxAfG786xX's Avatar
i run fully synthetic stuff...how would you do the filter or seperator?
Old 06-15-2009, 11:17 AM
Tripnbeats's Avatar
my intake tracts are red n yellow under the manifold cover...is that good or bad?
Old 06-15-2009, 12:29 PM
Google "catch can" or "oil separator". You can buy one or make your own. Some people use water separators for compressed air lines. It's the best of both worlds, you get the PCV action through the crankcase but only clean air gets into the intake. If you get a clear one, you will be able to see all of the water/fuel/oil/crud that it's stopping from going through the intake. This is something I've been meaning to do for a while now.
Old 06-15-2009, 09:28 PM
XxAfG786xX's Avatar
thanks for the help, i just need help on connecting everything together...as in which hose's disconnecting
Old 06-16-2009, 05:57 AM
Green Machine
Looks like the TSX guys had this same idea before. Can this work on our TL's as well?
https://acurazine.com/forums/1g-tsx-performance-parts-modifications-126/oil-catch-can-anyone-650649/
Old 06-16-2009, 10:27 AM
XxAfG786xX's Avatar
im pretty sure it can, but ours is in a different spot then the tsx's...im going to look for air compressors soon
Old 06-16-2009, 10:51 AM
Green Machine
Found this one on ebay; anyone knows if this will work?
http://rover.ebay.com/rover/1/711-67...d=120432861229
Old 06-16-2009, 12:58 PM
XxAfG786xX's Avatar
im pretty sure that works, seems kind of pricey though
Old 06-17-2009, 08:12 PM
Green Machine
I did it.....
I read the thread link below for the TSX guys oil catch can set up; and decided to do this. I got all the parts listed below with the exception of the hose; got that at Napa. It looks just like the one in the ebay link, but it only cost me less than $20 bucks. It seems to work just fine so far.
Call me crazy, but my car feels like it has more pep. I did not expect that; maybe it's in my mind. But I know my car and it feels different. I even ordered a new PCV valve from a local acura store; I will install that tomorrow when it gets here. I will post up pics tomorrow (too dark now).
https://acurazine.com/forums/showthread.php?t=650649
Originally Posted by txathlete
The fuel line hose - part no. 301018 (3/8" I.D. X 2 ft.) - $3.49 @ Pep Boys.
NPT Attachment - UPC#: (0)4556420579(9) - 1/4" NPT male and 3/8" female - $1.19 @ Home Depot located in the air compressor/tools department.
Metal screw clamps - UPC#: (0)7857516306(2) - Size 06, 10-22mm - $0.89 @ Home Depot plumbing section.
Mini General Purpose Filter - USA SKU: 401-910, CAN SKU: 131-688 - Husky brand NDC #: (0)4556460664(0) - $11.97 @ Home Depot located in the air compressor/tools department.
How's that Xizor?
Old 06-18-2009, 02:04 PM
Green Machine
Ok; as promised. I do not have a mount for the separator, but found a nice spot in the corner with no problems. I also installed a new PCV valve. What do you guys think?
Old 06-18-2009, 02:25 PM
Former Whyner
RonJonTL757's Avatar
damn jeez another MOD but this one that will help me in the long run
looks great Adrian
Old 06-18-2009, 10:59 PM
XxAfG786xX's Avatar
damn that looks pretty good....
Old 06-18-2009, 11:10 PM
Very nice! Keep us updated on how much stuff accumulates in there. Makes me want to do one.
Old 06-19-2009, 06:32 AM
practicing nihilist
NedShneebly's Avatar
did the 2" IM spacer mod couple days ago. Pretty black in the EGR collection chamber, brownish yellow stain in the rest of the ports and runners and the small circle port under the EGR collection chamber were pretty gunked up.
I spit shined all the components and Seafoamed about 20K miles ago when I installed P2R spacers.
*note: most of the names for the IM chambers and such above are completely made up. Hope someone understands what the hell I meant.
Old 06-20-2009, 12:58 AM
Inaccurate's Avatar
Please post a pic of what has accumulated after one week of daily driving. Thanks
Old 06-20-2009, 07:53 AM
practicing nihilist
Its been about 15K miles since I last dug into my IM and cleaned it. The EGR chamber was black, runner were brown and gunky and the small, circilar EGR port was caked pretty bad around the edges. I freakin hate EGR systems. Having a ton of issues with that system on my wifes Pilot.
Old 06-20-2009, 11:45 AM
You should put a tank of nitrogen in the trunk and when the EGR valve opens, have it run nitrogen through the intake instead of exhaust...... kidding but it would work.
Old 06-20-2009, 11:47 AM
On a more serious note, intake manifold junk is where the new nitrogen enhanced Shell fuels are supposed to shine. Supposedly it was made to combat all the DI intake port carbon problems Porsche, Audi, and VW are having.
Old 06-20-2009, 08:56 PM
practicing nihilist
Interesting. I used shell until they built newer station on the other side of the street which was more convenient and a tad cheaper.
Old 06-21-2009, 10:58 PM
Green Machine
Update....
Almost 400 miles, and I only have a tiny bit of oil film on the inside of the collector. I don't know if that contributes to the new PCV valve or not. My car still feels pretty good since the install. Don't know if that is because of the separator, but I like it.
Old 06-22-2009, 09:00 AM
Tripnbeats's Avatar
wow u know.....i dont know if its me or the valve...i changed mine this weekend....after 90k and never changing it...and the car seems a tiny bit healthier....but im sure once the valves are tightened and the water pump n belt and tensioner are all changed thatll make a world of difference.
Old 06-25-2009, 05:50 PM
Green Machine
Update....
After 500 miles, this is all I got....
Old 06-25-2009, 07:11 PM
practicing nihilist
that's a good amount of potential sludge for 500 miles. I've been digging in my IM a lot lately and even after a couple K miles it needs to be scrubbed out again.
Old 06-25-2009, 07:17 PM
Green Machine
I will be doing that during my spacer install.
Old 06-25-2009, 08:47 PM
04' tl 6 spd
Joey tl's Avatar
Hi, TOTALACURATL
I installed the same husky filter just have a question? does this filter suppose to suck air into the filter because the one i have suck air from the bottom valve when engine is running?
thanks
Old 06-25-2009, 09:18 PM
Green Machine
Originally Posted by Joey tl
Hi, TOTALACURATL
thanks
To be honest, I don't know. Far as I can tell, it takes the oil out of the air that gets sucked into the intake manifold.
Quick Reply: PCV Valve Question?
