DIY turbo idea for cheap? LOL
Old 04-18-2016, 06:00 PM
  #361
thisaznboi88's Avatar
Bought the heat shield wrap and new bezel for the boost and AFR gauge.
Old 04-18-2016, 10:13 PM
  #362
Looks like I will be using this to make the brackets
Shop Steelworks 8-ft x 1-1/2-in Aluminum Metal Flat Bar at Lowes.com
Old 04-21-2016, 01:34 PM
  #363
May 16 install date and may 18 is dyno tune date. Going to make a parts list to make sure I have all my basis covered.
Old 04-26-2016, 11:27 PM
  #364
Math equation for picking out air filter
1.Square inches of filter required for a motor = CID x Maximum RPM / 20839
2.CFM required for a 4 stroke motor = CID x Maximum RPM / 3456
3.CFM required for a 2 stroke motor = CID x Maximum RPM / 1728
4.CFM required for a turbocharged or supercharged motor = Pounds of Boost / 14.7
Add 1.0 to this answer. This relates to #2 and #3
Example: (CID x maximum RPM x #4 ) / 3456 or 1728
5.To find circumference of a circle multiply diameter by 3.1416
6. To find diameter of a circle multiply circumference by .31831
CFM Formulas for Filters
Round: Diameter x Height x 6 x 3.14
Flat Panel: Length x Width x 6
Universal Round Taper: (Base + Top) / 2 = A
Take A x Length x 6 x 3.14
Universal Round Straight: Diameter x Length x 6 x 3.14
borrowed from this website
http://www.gnttype.org/techarea/turbo/airfilter.html
Old 04-27-2016, 11:29 AM
  #365
Also how many turbo guys are running Oil cooler and catch can?
Old 04-27-2016, 12:20 PM
  #366
runnin a little boost
Hi speed's Avatar
Oil cooler, air oil separator and catch can. Don't know if I will do a catch can with the new engine since that was there more for the excessive blow by.
thisaznboi88 (04-27-2016)
Old 04-27-2016, 12:56 PM
  #367
how big of an oil cooler were you running? I am looking at a 7 row oil cooler.
Old 05-04-2016, 08:56 AM
  #368
bought an oil cooler and catch can.
I can't stop spending money lol
Old 05-05-2016, 03:47 PM
  #369
found out I have a ripped waste gate diaphragm... race car problems./
Old 05-05-2016, 05:42 PM
  #370
Here is a parts list
Turbo Kit (down pipe, turbo manifold, turbo)
Intercooler
oil pan
distribution block
oil filter and lines
battery box
dremel bits
turbo rebuild kit
turbo gasket
breather filter
steel zip tie
rdx injectors
waste gate spring
blow off valve tube
blow off valve
reducer coupler
waste gate
Vacuum line splitters block
Manual Boost controller
Rear O2 sensor
intercooler pipe
Paint
Brake cleaner
Boost Gauge
Slim Fan
2.5in flange
Hose for turbo
oil pan labor
Exhuast labor
silicon hose
51 inch oil feed line
npt adapter to 4an
bsp/npt adatper
Front sensor 02
3in flex pipe
Turbo 4 bolt to vband
2.5 to 2.5 4 bolt to vband
turbo housing
Amp wiring kit
crimper tool
3 to 2.5 in exahust adapter
K&N Air filter
spark plugs
J pipe gasket
Gauge bezel
Heat Wrap
Wastegate Gaskets
Battery Tray sold
Oil Catch can
oil cooler
exhaust hanger
Ik22 spark plugs
yeah don't expect to build a turbo kit for less than 3-4k, and plan on buying extra parts because stuff didn't fit right or stuff breaks
Old 05-06-2016, 01:33 PM
  #371
bought another CHRA just incase. Don't want any loose ends
Old 05-10-2016, 06:25 PM
  #372
the need CHRA spins a lot nicer than the rebuilt holset one. I am going to take that one apart tomorrow and see what is wrong with it.
Old 05-10-2016, 07:54 PM
  #373
Soo doesn't look like turbo cheap lol anymore. More like broke because of turbo build and I have spare parts everywhere
Old 05-11-2016, 07:50 PM
  #374
soo started decide to bitch out on me again. Starter #3.
Old 05-14-2016, 04:29 PM
  #375
Project boost is underway. Car is all packed up and ready to get all the parts installed Monday and tuning by weds
The following 2 users liked this post by thisaznboi88:
teh CL (05-14-2016), yungone501 (05-15-2016)
Old 05-14-2016, 04:32 PM
  #376
teh CL's Avatar
Old 05-14-2016, 04:45 PM
  #377
screaminz28's Avatar
Awwwww yeah...
thisaznboi88 (05-14-2016)
Old 05-14-2016, 07:13 PM
  #378
not sure if I posted this or not, but here it goes . Crafted gauge cluster
Old 05-15-2016, 02:55 PM
  #379
J-series addict
yungone501's Avatar
And so it begins. The transition to the dark side.
Old 05-15-2016, 05:22 PM
  #380
vroom psh
Old 05-16-2016, 05:31 AM
  #381
Install day pray for me . will update with pix later
The following 3 users liked this post by thisaznboi88:
flexer (05-16-2016), pohljm (05-16-2016), teh CL (05-16-2016)
Old 05-16-2016, 08:48 AM
  #382
9th Gear
rollaboy_95's Avatar
Positive vibes your way. Hope everything goes smoothly
  #383
Good luck! You doing it at home on jackstands, or have access to a lift?
Old 05-16-2016, 08:54 AM
  #384
3.5 psi
gnuts's Avatar
good luck! after last time, you deserve some good luck!
Old 05-16-2016, 01:37 PM
  #385
UTAH TSX's Avatar
Trunk full of gold LOL good luck bet you are ecxited
and where did you get that gauge cluster ?
Old 05-16-2016, 07:39 PM
  #386
J-series addict
yungone501's Avatar
I forgot, are you doing this on a stock motor? You should plan on running e85 on this beast regardless of boost pressure. And also, the heat greatly affects the engines resistance (or there of) to knock. I generally don't suggest low temp thermostats but if it's tuned for using FP, I'd definitely consider it. It's a known fact that the monoport heads were designed to pull heat from the exhaust to keep the EGT's down which means it's then absorbed and transferred to the coolant. Higher temps come along with increased power which will put a tremendous stress on the cooling system. Low temp thermostat and a lower closed loop threshold will keep detonation at bay. Combine this with the e85 and you will see reliability that nobody else has seen yet...I assure you.
Old 05-16-2016, 09:13 PM
  #387
Bad day. Tons of shit had to be fabricated and it wasn't direct plug and play. I am soo pissed right now.
need to add new SS clutch line because the turbo was hitting the hard lines. Also had to pull the stock vacuum line.
oil pan went off easy and had the new bung welded
Oil cooler won't work because it hangs a little too low.
Oil Feed line install.
Paul suggest to use this intercooler
chop my intercool to make it fit
Oil pan finally work!
turbo Test mounted
Old 05-16-2016, 09:41 PM
  #388
We still need to do the intercooler, oil return line, figure out how to mount the damn wastegate and dump tube, maybe move the radaiator hose so that it does not touch the waste gate and melt, wire tuck everything so that the turbo doesn't NOM NON NOM shit up, and then.... then do the down pipe and then actually bolt it up. Yeah I hate life right now.
Old 05-16-2016, 10:07 PM
  #389
J-series addict
yungone501's Avatar
Get use to it. The pain never stops even after its installed too. Lmao
Are you doing the install still?
Old 05-16-2016, 10:11 PM
  #390
I think I am just going to keep going. I have access to a lift for the time being and my fabricator/mechanic is try to help me out the best he can. So yeah I am glad I did not do it alone. I would be crying. Tons of new parts being fabs that I have not posted pics yet.
I can only run 93 oct. WV hates e85 rolling coal no love for that corn. So yeah I am kinda in a bind right now... Either push forward leave the car with the mechanic and have him complete it while I go on vacation again. lol Everything I can't fix shit I go on vacation.
Old 05-17-2016, 12:45 PM
  #391
Round 2
Old 05-18-2016, 02:29 AM
  #392
Major setback today...
The down pipe will not work on my car. It is hitting everything, heater core hose, engine harness, transmission counter weights, and basically everything in that corner... The only thing we got done was the intercooler piping, the intercooler is now mounted, and w.e we got done yesterday So turbo mounted with all feeds going in and out, wastegate, dump tube, and a few other things. But can't really do anything since without the down pipe everything is going to fry
I also missed my window to cancel the appointment with Innovative-motorworks. So I will probably lose my 100 deposit . Hopefully, Derek is willing to work something out with me, but I won't get my hopes up.
Took a few hours to machine this little thing to adapt to my turbo and weld on to the intercooler.
Size:  339.9 KBName:  20160517_135722_HDR_zpsqblz2ml1.jpg
Old 05-20-2016, 09:20 AM
  #393
Any new progress?
Old 05-20-2016, 10:16 AM
  #394
Left the car at my mechanic/fabricator Tuesday night. Had to take a rental home back to where since I have work Thursday and Friday and am leaving the country sunday. He should be getting the material in today and have it done by the end of this weekend. I will be in China for 3 weeks.
Sooo the bill racked up pretty fast. Was shooting for 3k at the beginning of the build and it looks like it is going to be around 5k. So yeah cheap + turbo doesn't work out too well.
Labor bill so far was 600. But that down pipe might be 300-500, and I lost 100 deposit at the dyno tuner for now showing up weds. So yeah do not attempt unless u have a spare car and deep pockets because anything that can go wrong will go wrong
Old 05-20-2016, 11:41 AM
  #395
Hi speed's Avatar
Don't feel bad, my bill for labor will be $5,000 for the current engine rebuild. Another $3,000 -$4,000 in parts for the rebuild. I have had a lot of bad luck with having installs done while I'm on vacation. Shit goes wrong, extra money needs to be spent and it messes up your vacation. I was in Italy last month during my build and told the shop not to call me just figure it out. Last 3 times I have been in Mexico was during work of some sort on the car and issue after issue comes up that cost money and delay the finish date.
It is nice to have it done when you get home but that never happens. Every build I have ever done or been a part of goes south at some point near the end that's what's hard to budget for. My car is all done on the dyno geting tuned and the fuel pump died, tuner busy for next two weeks. The build has been pretty smooth so I expected a bump in the road like a failed fuel pump and cracked tranny housing
Old 05-20-2016, 12:28 PM
  #396
Damn Jack that is nuts. Yeah I am hoping to get it done since it is just the down pipe and then it needs a tune.
Old 05-20-2016, 03:56 PM
  #397
KN_TL's Avatar
It's almost impossible to do something like this on a DD.
I don't think anything ever went as planned.
Old 05-20-2016, 06:15 PM
  #398
ill just leave this here
Old 05-21-2016, 06:06 PM
  #399
New down pipe, a new heater hose shielding, and larger flex pipe.
Old 05-21-2016, 06:15 PM
  #400
teh CL (05-21-2016)
Quick Reply: DIY turbo idea for cheap? LOL
