A-110(b): DIY Guide to replacing 3rd & 4th gear pressure switch for 3G TL (2007-2008)
Old 01-26-2012, 02:20 PM
  #41
Paul91's Avatar
FWIW, don't try to attempt this w/o having the 7/8 DEEP socket....it's not going to happen w/o it.
Old 01-26-2012, 02:46 PM
  #42
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ i used a 7/8" wrench and it worked just fine
Old 01-27-2012, 08:39 AM
  #43
RaviNJCLs's Avatar
You suck.
Old 01-27-2012, 08:49 AM
  #44
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
ordered my sensors/gaskets today...who want's to help me install these?
ravi...?
Old 01-27-2012, 10:18 AM
  #45
RaviNJCLs's Avatar
ravi...?
Sure. Take a drive up to Lancaster. I have a large enough garage.
SharksBreath (01-27-2012)
Old 01-27-2012, 11:38 AM
  #46
Paul91's Avatar
[QUOTE=swoosh;13510439]^^^ i used a 7/8" wrench and it worked just fine [/QUOTE
I highly doubt that, kind sir. There is no way that you can get your hand and a wrench through the wheel well to gain access, let alone around the sensor to turn it. Can't go under the cross member for access, either.
Old 01-27-2012, 11:39 AM
  #47
RaviNJCLs's Avatar
[quote=Paul91;13512398]
He's got an 05.
swoosh (01-27-2012)
Old 01-27-2012, 11:59 AM
  #48
Paul91's Avatar
[QUOTE=RaviNJCLs;13512405]
Originally Posted by Paul91
He's got an 05.
Gotcha. I didn't see that at first. Based on his response, I thought he was commenting on the same trans as me considering the point of the thread was for
07'-08'.
Old 01-27-2012, 12:47 PM
  #49
swoosh's Avatar
Originally Posted by RaviNJCLs
He's got an 05.
Thank you Ravi
Gotcha. I didn't see that at first. Based on his response, I thought he was commenting on the same trans as me considering the point of the thread was for 07'-08'.
Sorry about that dude....yeah i didnt check if the thread was 04-06/07-08....i just posted that the wrench worked just fine....
Old 02-01-2012, 05:23 PM
  #50
SOLD
LaJay007's Avatar
subscribed. Thanks!
Old 02-01-2012, 10:44 PM
  #51
jerzydevil609's Avatar
idk how good you are, but for the one under the airbox, i couldnt get it out without 2 short extensions and a lil joint to help out with the angle haah... besides that n the deep socket for sure, your good to go!!
the one between the tubes in teh back on the firewall side is a piece of cake if you remove the bar connecting the shocks on each side of the car. the socket slips right in between the two tubes and theres plenty of room to maneuver with just the deep socket.
the one in the driverside wheel well i took the wheel off and moved the plastic cover to the side. that one was the hardest to unplug but access was also easy with the wheel and plastic out of the way. i recommend pushing the release button on the plug and sticking a lil flat tip where the plug meets teh sensor and just twist it a lil and it should pop... pushing the button and just pulling with my hands was hard as hell and didnt wanna come out for NOTHING!!
i saved and combined the two diys for our years to a word file that i'll post tomorrow at work if i remember
... good luck bro!! hope everything turns out smoothly for ya
Jrad96TL (02-06-2017)
Old 02-05-2012, 02:46 PM
  #52
Rich
Rsoetidjo's Avatar
How often do I have to do this? Is it for all 3rd gen TL or just certain year?
Old 02-05-2012, 03:08 PM
  #53
RaviNJCLs's Avatar
I've read a few different comments on this. I think every 36K-48K miles will be good, or every 3-4 years.
Old 02-08-2012, 12:31 PM
  #54
Paul91's Avatar
Originally Posted by brewmyown
Id really like to find out for sure which one is for 3rd gear. This way I could change that one first and if there's a noticable change I will post my finding so that it may help others. It sounds logical tha the two same part numbers would be for th same gear but just because there are two of the same part numbers doesnt mean they have to be for the same gear does it?
Anyone know for sure?
Brew, thanks for getting back to me, but your PM is full. In case you see this, I posted about my MIL trans code and issue here: https://acurazine.com/forums/showthr...1#post13539411
JCash23 (06-25-2022)
Old 02-09-2012, 02:58 PM
  #55
TAZ1811's Avatar
Originally Posted by vtxcraziexboi
what does this do if you change it? im not a car guy and would like to learn why replacing it will help. i drive an auto so would i even tell the difference?
I am eagerly awaiting response to this question as well.
Old 02-09-2012, 03:08 PM
  #56
BANNED
good god...i can see why people like IHC get tired of saying the same thing over and over again.
Old 02-09-2012, 03:18 PM
  #57
swoosh's Avatar
^^^ good edit Sharky LOL....but gotta help the newbie....you remember we all asked the same questions around 8K post back LOL (not really but you see my point ?)
To explain about the siwtches:
The pressure switches, come into play when you switch from a gear to another....these switches are activated at a certain PSI (pressure)....so when that pressure is reached, the gear changes....I think the 3rd gear was like 28psi....
Example: so if you driving in "D" and you cross say 25mph on 1/2 throttle the line pressure reaches 28mph and hence the gear changes from 3rd to 4th....sometimes there is "gear hang"...which is one gear hangs in there for tooo long....this is due to old pressure switches....
I tried to use the simplest words possible for you newbies.....read couple pages of this thread for a more technical understanding
https://acurazine.com/forums/3g-tl-2004-2008-93/very-interesting-conversation-my-transmission-builder-tl-721508/
The following 2 users liked this post by swoosh:
dezymond (05-18-2015), TAZ1811 (02-09-2012)
Old 02-10-2012, 10:53 AM
  #58
Paul91's Avatar
I've been lurking around the site for a while now. Tons of great information. If this is true about only one (1) 3rd gear switch I assume its the one behind the tire since its the part number that only one (1) is required. Anyone else confirm this?
I have a 2007 TLS with 97,000 miles on it and I don't think the fluid was ever changed. It was a company car that I drove since it had 29,000 miles on it. They took care of all maintenance on the car but I don't ever remember them doing the trans fluid. I got laid off and ended up buying the car from the company for a great deal $10,000. The car seems to shift fine but 2nd to 3rd is a slightly different feel (split second lag) than 1st to 2nd and 3rd to 4th. Truthfully I'm not sure if it hasn't shifted this way since I had it but after reading hundreds of trans threads it got me thinking. I was going to just change the 3rd gear switch and fluid change to see if it makes a difference.
Thanks for all the info
Brew- I confirmed yesterday that the two sensors accessed through the engine bay are for 4th gear (#28600-RKE-004), and the one below that is accessed through the drivers' side wheel well is pn# 28610-RKE-004. They are also color coded. The two up top for 4th gear are white, and the one below for 3rd gear is black. I know for a fact that these had never been changed before on my car, so the originals that I pulled out matched in color.
Old 02-10-2012, 11:40 AM
  #59
Need an OEM lip kit on my
JRhodes88's Avatar
Where is the DIY for the 04-06 Tranny?
Old 02-10-2012, 11:52 AM
  #60
BANNED
here you go.
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
JRhodes88 (02-10-2012)
Old 02-13-2012, 06:28 PM
  #61
2007 Type S WDP 5AT
wojo1988's Avatar
Got my parts. going to tackle this on my 07 type s soon. I noticed 3rd and 4th hang a little and are a little slow. I hope instead of sitting at 50mph while cruising at higher rpms it will shift quicker
Old 02-21-2012, 01:58 PM
  #62
AMSMiTH's Avatar
Originally Posted by KaMLuNg
apparently the code isn't stored after the light turns off...
is this b/s? i may go hit up my friend at advanced to see if he can pull something with their reader...
I think thats b/s.. when I was shopping for a TL I brought one into my shop for a pre-sale inspection that had no CEL lights on and they found 3 stored. The car came from an auto broker so I wasn't surprised.
So due to your confirmation we should be ordering...
1 x 28600-RKE-004
2 x 28610-RKE-004
3 x 90471-PW7-A00
Is that correct then? If so maybe Ravin should update first post...
Old 02-22-2012, 04:55 AM
  #63
9th Gear
Kidhova84's Avatar
Im about to do this same job to my 08 Type-s, just so im clear there are 3 switches, one under car by Vin plate, one under air box, and one behind wheel well???
Old 02-22-2012, 08:20 AM
  #64
RaviNJCLs's Avatar
No. The one near the VIN plate is accessed through the wheel well.
There is one under the air box.
The third one is accessed through the back side of the engine between the engine and firewall. That one is the toughest to photograph but probably the easiest to replace.
JCash23 (09-04-2022)
Old 02-22-2012, 01:43 PM
  #65
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
1 x 28600-RKE-004
2 x 28610-RKE-004
3 x 90471-PW7-A00
here is a pic of my parts... Ravi's post is right... the debate was no one knows which part is the 3rd or 4th gear switch... i still think there are two 4th gear switches which is the 28610...
AMSMiTH (02-22-2012)
Old 02-22-2012, 06:57 PM
  #66
AMSMiTH's Avatar
Thank you for clarifying!
So after a few days and plenty of hours of reading on AZ I've bought plenty of Red Line ATF, gear pressure switches, and the fuel pump o-ring. That's a good start on preventive maintenance after only owning my TL for 10 days
Thanks to everyone who helped input all of this knowledge!
Old 02-22-2012, 07:01 PM
  #67
9th Gear
fdte320's Avatar
KamM, your pics show 2 x 28600-RKE-004
1 x 28610-RKE-004. Please verify.
Old 02-22-2012, 07:04 PM
  #68
AMSMiTH's Avatar
that's what he's saying is correct.
Old 02-22-2012, 07:06 PM
  #69
BANNED
^youre correct. his pic is correct.
Old 02-22-2012, 08:55 PM
  #70
9th Gear
Kidhova84's Avatar
How do I access the back side of the engine between the engine and firewall, from under the car?
Old 02-22-2012, 09:45 PM
  #71
BANNED
^its visible from the top of the engine. you reach straight down below the strut bar area. I found that that was actually one of the easier ones to access.
check out the pictures posted in the DIY. it'll show you what to move to get access to it.
Old 03-01-2012, 10:07 AM
  #72
RaviNJCLs's Avatar
Yeh....and don't drop anything back there. It's a bitch to get to.
Old 03-01-2012, 10:21 AM
  #73
BANNED
something like that HAD to happen. everything was going so smooth, it's only natural to hit a speed bump.
Old 04-24-2012, 09:17 PM
  #74
2007 Type S WDP 5AT
wojo1988's Avatar
I just finished my first 1x3 at 85,000 miles and replaced all 3 switches on my 2007 type s. Took about 45 minutes for all of it. Feels good to have done and thanks for this DIY!! I just used oem tranny fluid for my car from the dealer
The following 2 users liked this post by wojo1988:
JCash23 (06-25-2022), unlimited (05-06-2012)
Old 05-06-2012, 03:15 PM
  #75
unlimited's Avatar
How is the shift quality? Major improvement?
Old 05-07-2012, 08:08 AM
  #76
RaviNJCLs's Avatar
It shifts a lot better. I felt that as you accelerate you do not feel the shifts as much and I also felt that there was not any hesitation to shift. The best way I could describe it was that the transmission shifted cleaner.
Old 05-29-2012, 04:24 PM
  #77
VanyDotK's Avatar
Car details:
2008 Acura TL-S with 64xxx miles
Thanks for the DIY, I performed it this morning and here goes some tips and troubles I had.
1. It was a pain in the ASS to remove the connector from each one of the switches, I don't think I have girly weak fingers, but damn maybe I do! I had to use a flathead screw driver to leverage it out while pushing down on the release on the 4th gear switches.
2. I had to remove the strut bar in order to remove the connector from the back 4th gear switch, it gave me a lot of room and it was only 6 12mm bolts and 2 10mm bolts to remove the strut bar. The only thing is I lost one of the 12mm bolts in back of the engine, called the dealership's parts and they'll have one for me tomorrow.
3. When doing the side 4th gear switch I had to remove the ground wire, the bracket for the fuse box AND the 2 10mm nuts and move that plate aside, I have no idea how the hell OP was able to do this without removing those things, props to you!
Overall it was easy but time consuming. Thanks OP for the DIY, it was very helpful. I did not have to use a breaker bar for any of the switches. After I changed the switches I did a 1x3 with 2 bottles of Redline Racing ATF and 1 bottle of Redline D4. I previously had performed a 2x3 with 6 bottles of Redline Racing ATF a few months ago.
So far the shifts feel slightly better, down shifting is less jerky than it used to be and up shifting still has a little jerk to it but not as bad as it used to be. I'll drive some more and report back if anything changes.
Old 07-11-2012, 09:16 AM
  #78
07 WDP TL Type S
vmodi89's Avatar
are there any members in the Boston, MA area that wanna help me out with this? I would still have no idea what I was doing if i tried it. Can compensate with $$ or
Old 07-11-2012, 10:08 AM
  #79
umakemekissu's Avatar
hey Vinay Hondaa King quoted me $140 to change all 3 sensors... just another option for you to consider
Old 07-11-2012, 10:12 AM
  #80
swoosh's Avatar
^^^ if that includes the switches, that is an AWESOME deal
Quick Reply: A-110(b): DIY Guide to replacing 3rd & 4th gear pressure switch for 3G TL (2007-2008)
