Comptech Short Shifter Install/pics 3G Garage #A-086
Old 01-25-2011, 04:38 PM
  #241
Csmit176's Avatar
I see this is a popular mod. I have an 08 TL-s. What are the advantages of a short shifter? Should I consider?
Old 01-25-2011, 05:02 PM
  #242
myron's Avatar
advantage is in the name, SHORT SHIFTER. Meaning shifting throws are shorter. Advantages? Besides that shifting throws are shorter, none I think. It just changes the feel of the shifter. I am getting mine installed this weekend maybe. Or the next one.
Old 01-25-2011, 05:07 PM
  #243
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
It's night and day...I've gotten used to it now, but the day I did it I felt like the money was very well spent.
Old 02-12-2011, 10:14 AM
  #244
Ok guys/gals...thought I hit you all with a warning on this install.
Sooo...for the last few months since I put this on, I could swear I've been hearing tire noise, engine noise etc. My cupholders felt VERY warm AND I had a faint "whistle" sound. My fiance of course tells me I'm always looking for something wrong and it's in my head etc...
Soo...I say, well car is getting older, maybe I just didn't notice it before, that's why the road noise is more apparent...and maybe because I had the seat heater on or the the air coming thru the vents in the engine was my center console hot.
Last night, I decided to open up the center console and look around, see if I knocked something or forgot something.
For those of you following the direction to NOT undo the assembly to take the shifter assembly OUT of the car...pay attention to THIS grommet! Eureka, it was my problem...in twisting and maneuvering the shifter to keep from having to take it out...I managed to knock this grommet DOWN leaving a 4" by 2" opening to my heatshield/exhaust and the WORLD! lol...
So either be careful, take out the assembly, or just plan to pop this back in afterward. I tried from above with picks and screwdrivers and pliers but unless you're friggin Thumbelina, wasted an hour on this...good friggin luck. Decided to give it a try from under. Jacked up (AND USE JACKSTANDS), unbolt the four 10MM bolts that hold on the heatshield, slide it toward the rear of the car and in less than a minute you'll have the grommet back in.
ALSO: Thought that this my actually be a GREAT place to run your main positive line for your systems!
Take care,
J..
Top:
From the Bottom:
Old 03-11-2011, 03:36 PM
  #245
sven1277's Avatar
I just installed it this morning. Took about 2 hours. Nice difference. Very solid feeling. I like it.
Old 04-06-2011, 05:28 PM
  #246
Redwood Original
RU_JELLY's Avatar
just put mine in today, wow was that bushing a bitch to get off! but it feels amazing, i cant believe how much shorter it is between gears. favorite mod i have on my car
Old 05-30-2011, 02:33 AM
  #247
con5tant's Avatar
has these ever failed/broke and left anyone stranded?
Old 05-30-2011, 02:46 AM
  #248
con5tant's Avatar
Originally Posted by gt1
I've had a short shifter in my TL for 5 years- longer than this thread existed. Until today I had been very happy with the upgrade. Today my wife pulled from a garage. When she tried to shift in 1st she felt that the shifter was very loose. She managed to get the car back in the garage. When I got home, the shifter was moving freely and felt disconnected. When I took everything apart, I found that the factory shifter broke! The ball on it's end was stuck inside the short shifter. You can see it in photograph below.
I guess that short shifter creates an additional load on the factory shifter. I can't explain it otherwise. My wife isn't that strong handed. So now I need to get a replacement shifter- it comes assembled with that huge plastic housing. I will probably need a new short shifter. The broken part stuck inside is glued with Loctite and I might not be able to remove it.
The car will be out of service for a while, and I'll have to commute on a motorcycle. Of course the forecast is for some cold rain. We are still lucky that it happened on our driveway. Could be stuck who knows where.
is that a comptech SS?
Old 06-26-2011, 10:22 PM
  #249
www.colradodetail.com
Hondaforlife954's Avatar
I finally got my SS in the mail and installed it this morning. So far so good.
switching between gears is quick. it first felt like i needed to go farther...took about an 1hr to get use to and i love it.
The down side to this mod is it requires more force to change gears. It feels like a Formula SAE race car i built in college. Not that big of a deal but it is noticeable.
Other than that i would say i am happy with it 4.5/5stars. Next up i need to change the fluid to the GMMTFM and the shifter bushing and possibly remove the slave cylinder checkvalve.....
Old 07-15-2011, 02:10 PM
  #250
sockr1's Avatar
Received 1,158 Likes on 909 Posts
i found some old posts about where to buy the comptech ss, but wanted to get an update. which place is the cheapest to get it (I've found links to ebay, excelerate, and heeltoe auto) and has the quickest shipping?
any information is appreciated, sounds like this is a great mod for the 2008 tl type s!!
Old 07-15-2011, 03:41 PM
  #251
I just bought mine from Heeltoe. I had extra money in my paypal acc so it was easy. Took a week or two to get in bc they where out of stock. But i am sure they have them now. 69bucks i think
Old 07-20-2011, 08:52 PM
  #252
sockr1's Avatar
just got the ct ss kit and the skunk2 billet knob in the mail and can't wait to install them this weekend! also got a trim tool set on amazon for 10 bucks so i'm good to go. the skunk2 billet knob feels so solid and it looks great (very dark color)!!
Old 05-14-2012, 04:21 PM
  #253
ChairmanKaga809's Avatar
From the deadddddddd lol.
I'm looking to install the short shifter, but I noticed that HeelToe sells it in a package with the bushings.
I understand that the counter-sunk knob will help with the shifter throw, but what about the bushings? I'm a bit confused as to what these do, and if I DON'T get these, how would it feel?
Thanks in advance!
Old 05-14-2012, 04:32 PM
  #254
KN_TL's Avatar
Just helps tighten things up. It makes a difference in the feel. I've done both.
Old 05-18-2012, 05:31 PM
  #255
Former Sponsor
MrHeeltoe's Avatar
Check out the shifter package we offer which includes this short shifter and an intelligent combo of other items to round everything out : http://www.heeltoeauto.com/ht-spec-s...-01-03-cl.html
Originally Posted by heeltoeauto.com
This kit includes a CT-E Short shifter, Hybrid Racing Shifter Bushings, and a 1lb weighted Maven Shift Knob & Stainless Braided Clutch Hose from Fastline Performance!
Options include choosing your model year and shift knob finish.
The function of each item in this kit adds a significant advantage to the whole system, but without all the items working together the system is flawed. Many people purchase these items individually, looking for shifting nirvana. Many of these people find themselves completing this package to get the best function out of their shifter, and spending a lot more in the process! DO IT RIGHT. Get a HT-Spec Shifter Package to improve the overall function and feel of your manual-Honda/Acura's shifter!
SAVE THE MANUALS!
Read up on the benefits of each item, and how they work together to complete the shifter upgrade properly:
*CT-E Short Shifter: Shortens the throw of the shift lever, making the distance traveled shorter and the shift a bit faster.
*1 lb Maven Shift Knob: Adds weight to the shifter which increases momentum. This smooths out the notchy feeling that can come with the installation of the short shifter.
*Hybrid Racing Shifter Bushings: These aluminum bushings replace the rubber bushings on the shift cables that deflect under the force of shifting, which is exacerbated by the added weight of the Maven knob.
*OPTIONAL ADDITION:Fastline Performance Clutch Hose: With a faster smoother shift it is necessary to improve the smoothness and accuracy of clutch operation. This hose, along with the supplied fluid from Honda, will restore and improve the feel of the clutch pedal for more accurate friction-zone modulation and faster reactions you'll need with you revitalized shift system!
Astute readers will notice the HT-Spec Stage 1 Shifter Package does not include shifter base bushings, as replacing these will serve only to increase the level of vibration and discomfort of the driving experience, detracting from the high-end nature of your Honda/Acura.
Old 05-19-2012, 08:00 AM
  #256
I would suggest not going with a shorter Knob...makes it harder to shift...mine is still going strong though!
Old 05-26-2012, 03:03 PM
  #257
sourial84's Avatar
Oh my Oh my what a difference I recommend this to anyone that is thinking about this dont ponder anymore but DO IT!!!! I will not lie this is a pain in the ass but it is all worth it in the end I just finished now took me more than the recommended 2hrs but I was taking my time and triple check all my work b/c I am no handy man when I took the car around the block I was amazed
by the way OP thank you veryy very much this was very helpful I was following along on my cell which made my life easy lol dont know if you still own a TL anymore but thanks
If i may add a few pointers that did help me in the OP's description he mentioned something about a CT tool that help you put the bushing (little white circle) on the SS. I had no such tool and trying to force it on by hand isn't happening if you use a 14mm socket and push down on the bushing it will pop right in. LOL that's all I got other than that this DIY is rIght on the money with everything else
GOOD LUCK TO ALL WHO TRY THIS NEXT IF YOU HAVE ANY QUESTION FEEL FREE TO SHOOT ME A PM
Old 05-28-2012, 10:28 PM
  #258
BRB..Shifting!
VieTLover's Avatar
Just did this today as well and DAMN what a difference. I didn't even follow the instructions that came with it, just this DIY. What I did to get the bushing off was I used two hex keys and put it under the bushings and popped it out. This install was definitely a PITA tho lol but so happy afterwards! Night and Day difference like what everybody said. Feels like im shifting in an S2k lol
Old 05-29-2012, 08:55 AM
  #259
I think I forget how my car used to shift and take it for granted, I remember the day I did this and how much I loved it. You guys just reminded me!
Old 05-29-2012, 05:14 PM
  #260
vp55's Avatar
Do the bushings help with the "play" in 1st gear?
I really want to do this mod but wasn't sure if bushings are required or just recommended.
Old 07-18-2012, 05:40 PM
  #261
modoko's Avatar
Can't wait to have this installed!
Old 05-14-2013, 04:31 PM
  #262
mynameisraj's Avatar
Finally installed this. Sorry to bump up an old thread, but I thought I'd add a few notes that I wish I had before I started:
- To get the white bushing off, use a blow drier. It will make your life 100x easier.
- I lost the retaining pin that attaches the white piece to the metal rod, and quickly panicked. I didn't end up finding it, so I fabricated my own out of an XL paperclip. I drove the car pretty hard after I put it in to see if it would hold up, and so far everything's good.
It took me significantly longer than most since I had a few odd bottlenecks (couldn't get a harness unplugged, the bushing took me 1.5 hours, and I wasted a lot of time making sure my paperclip was good), but this is definitely one of my favorite mods. I can get perfect shifts a lot easier now.
Old 02-05-2014, 08:28 PM
  #263
8th Gear
smo0f's Avatar
I thought I was smart by ordering the cosmo racing ss to save a few bucks since people who've used it said it's great. But i guess the difference in price meant no loctite 680 green provided, which it calls for in the instructions. I was about to start installing when I realized this and lost my excitement. I can't seem to find it on the pepboys/napa/home depot websites. Anyone know where I can pick this up locally in NJ or if there are any suitable alternatives that are readily available in stores?
Old 02-06-2014, 11:17 PM
  #264
8th Gear
smo0f's Avatar
best write up for the ssk out there. i was able to do it without removing the cover under the steering wheel. just had to pry it a bit on the right side so that i can get the left side panel out
Old 02-07-2014, 06:21 AM
  #265
Did you ever find the loctite?
I have yet to need to take the side panels off to get the center console out...I just pop out the side clips from under the radio.
Still love mine!
Old 11-23-2014, 08:02 AM
  #266
EM2typeflex's Avatar
Now this DIY I like. Thanks op for taking the time to guide us with some quality pics. Now I can prepare myself to change out my radio.
Old 12-27-2014, 04:36 PM
  #267
screaminz28's Avatar
I agree. Excellent write up. I just installed my Cosmo Racing short shifter and it was just like the Comptech. Shifter feels much better now.
Old 02-17-2015, 09:02 PM
  #268
aameghoo's Avatar
any links for some of the kits available? found this Street Tuning Auto Piece BMW Performance Parts - COSMO Racing but I want to make sure I'm ordering the right thing along with seeing what my other options are
Old 02-22-2015, 07:22 PM
  #269
6-SPEED LOVER
ABP_04TL's Avatar
Not sure about that brand, but Im sure heeltoe or xlr8 has it but i ordered mine for my 3rd TL from here -----> http://www.ebay.com/itm/131179633634?_trksid=p2060778.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Old 02-23-2015, 10:08 AM
  #270
that looks like it...
Old 11-09-2015, 09:11 PM
  #271
SidhuSaaB's Avatar
Pretty straight forward install. DIY came in super handy. Only thing I didnt do on mine was take out left shifter cable from the assembly since I couldn't get the metal piece holding it down, out. I ended up flipping it over (180 degrees) and used a big flathead on the rubber piece. I used my palm to hammer the flathead and the rubber popped right out after 5-7 tries. It was also 5*C while working outside which made it a bit harder to come out.
Shifter feels great combined with Maven Shift knob.
Old 03-13-2016, 02:09 PM
  #272
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
Installed the Comptech short shifter today using these instructions, took about an hour and a half. The throws feel much shorter and I'm happy with it so far. If you haven't done its a fairly cheap mod that you use everytime you drive the car.
Old 03-13-2016, 02:29 PM
  #273
3 2 GONE
ATLS_666's Avatar
How is winter shifting with this mod? I keep picturing cock stiff shifting on those crisp February mornings
Old 03-14-2016, 08:26 AM
  #274
SidhuSaaB's Avatar
No problems here, I didn't feel any change in shifting other than the ice cold Maven knob
Old 03-14-2016, 08:36 AM
  #275
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
^+1
My wife had these little footsie socks that have rubber 'tread' kind of glued on. I turned one inside out and put it over my knob for the winter. Lol
It rubs kinda hard but at least I don't have the need for blankets like J.
Old 03-14-2016, 09:59 PM
  #276
Old 03-15-2016, 07:39 AM
  #277
maharajamd's Avatar
I couldn't help it once I realized I typed putting a sock on my knob.
Old 03-15-2016, 09:20 AM
  #278
SidhuSaaB's Avatar
I have heard about the sock on the knob idea before. My only fear is hand slip when shifting since I shift fast (not race fast, but close).
Old 03-15-2016, 09:22 AM
  #279
maharajamd's Avatar
I felt the same. That's why I used that kind of sock.
Old 03-15-2016, 09:51 AM
  #280
I read your comment about wanting the hybrid racing bushings but doubting the short shifter...
trust me, Chad...having both at my disposal right now, you won't want no short shift again. Just a pleasure to shift through.
Quick Reply: Comptech Short Shifter Install/pics 3G Garage #A-086
