Brembo brake conversion requirements
Old 04-14-2009, 08:50 PM
SN_04TL's Avatar
Got a 04 TL auto. Have a pair of brembo calipers from a manual 04 tl. What other parts do i need to complete the install?
Old 04-14-2009, 09:00 PM
Anarchy919's Avatar
You will need this most of all and the most costley. #2&3 Left and Right KNUCKLE.
Old 04-14-2009, 09:01 PM
hata_61's Avatar
i have a thread in 3G garage,it has the full list of what you need. but some stuff can be replaced with aftermarket goodies
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/d-103-tl-s-brembo-swap-parts-list-716463/
Old 04-14-2009, 11:42 PM
mista.huynh's Avatar
^ Holy, your car is modded up the ying yang!!
Old 04-15-2009, 12:47 AM
hata_61's Avatar
Thanks man! there's alot guys on here that are more intense. i have most of the good bolt on's. if i didnt have a auto, i would have Supercharged this thing.=)
Old 04-15-2009, 07:02 AM
Anarchy919's Avatar
https://acurazine.com/forums/showthread.php?t=716463
I'm about to do the 08 TL-S Brake Calipers found a set for $175 to my door.
Old 04-15-2009, 05:28 PM
hata_61's Avatar
175 for the calipers is a pretty good deal. If you get lucky you might not need the bearings cause you can press the bearing and hub out as a assembly, but you'll need a 90 degree snap ring pliers to take the snap ring out. For sure you are gonna need Knuckles,rotors,pads,flex hoses,rotor backing plate,shim between knuckle and caliper. And a 50% chance you'll need the ABS sensors cause they might be rusted into the knuckle.If you do get new ones make sure you use some dielectric(tune up)grease and lube the sensor up before putting it in the knuckle.
Old 04-15-2009, 06:38 PM
2009 g37s 6mt
ssmtl2nv's Avatar
hata61 said it all... he is 100% correct, as we both had the same install done...
Old 04-15-2009, 07:12 PM
Anarchy919's Avatar
It’s not to bad we have an account with an Acura dealer so I get 40% off anything I’ll need so as long as I can get the Brembos cheep the rest should not be bad. I’m going to buy the Calipers and Knuckle’s used I’ll buy the rest new.
Old 04-16-2009, 08:39 PM
hata_61's Avatar
sounds like a good plan. If you work at a shop and have all the tools then it shouldnt take more than an hour each side. Good luck!!
Old 04-17-2009, 02:15 AM
SN_04TL's Avatar
Thumbs up
Thnx alot for the input AZINE
Old 08-20-2016, 05:07 PM
Hebrew Hamma's Avatar
hate to restart an old thread, but im actually looking to do the opposite, i have a 04 6MT tl i just picked up it has a automatic knuckle on one side and a MT knuckle on the other side that grinds my wheel and it drives me crazy, not the grinding the fact that they are different lol but the grinding occurred only when i tried to put a different caliper on and realized i could not, when i put the old brembo caliper on it started grinding, If i get a new knuckle for the side from a AT 04 TL will i be able to switch the whole set up, i already have new rotors and pads as well as a AT caliper for that side it just didnt fit.
Old 08-25-2016, 08:43 AM
Received 8,582 Likes on 6,629 Posts
Old 08-26-2016, 03:07 PM
already solved the problem
Old 10-04-2016, 08:39 AM
Former Sponsor
ExcelerateRep's Avatar
We've got all your Brembo Needs. We can give instant quotes as well.
Brembo Gran Turismo Big Brake Kit - Excelerate's Honda & Acura Store - Japanese Performance Specialist
GWEEDOspeedo
01-15-2016 10:39 PM
rockyboy
10-02-2015 10:45 PM
polish_pat
09-30-2015 12:22 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Brembo brake conversion requirements
