3.80 final drive
#202
They are from the 2010 tl shawd. I came across some info yesterday about this. There actually wasn't any redrilling. In order to buy that gear from acura, you have to buy the entire differential. Tb was buying them, unbolting them from the unit, and selling them to us. I also found out that they are not in production anymore. When looking at the pic of the gear that I took, you can see where the bolts left markings on the gear. Crazy stuff
#203
#206
There's no doubt that the "3.80" FD gear set is actually the SH-AWD gear set, which is 3.842 to be exact. But I'm thinking that Liberty's Gears did the modification to the ring gear. Honda probably added bolts to the ring gear because the J37 has more torque and is used in an AWD car with more traction.
#212
Hold the ring gear with just your index finger and hit it with something metal... it has a nice ring to it.
Stock 3.286 FD gear set:
Countershaft on the right is for an 8th gen Accord (3.55). It's the same except for the gear portion. Although there is no doubt in my mind, I still have to get the differential/ring gear to confirm compatibility.
#213
#214
Originally Posted by screaminz28
Since the 2010 TL SH-AWD has an LSD, it seems like buying the diff and countershaft would be a cheap LSD replacement or upgrade for the Accord guys and auto TLs if the diff is compatible. I'd think since the only difference is the bolt pattern, everything else would be compatible.
#216
Well shucks. I hate when companies take a good hardware feature out and think that software "torque vectoring" makes up for it. Software is cheaper in the long run though. Oh well, another reason besides how ugly the 4G is that will keep me from getting one, lol.
#217
#218
Ok, I'm so confused. What's no longer in production? Is TB Motorworx no longer selling re-drilled 2010 TL-SHAWD rings/pinions, or are they NLA from Acura?
And is the 3.55 really worth it? Seems the gains would be pretty minimal over our factory 3.28
#219
Originally Posted by gerzand
good luck on that...national backorder till february for the differential assembly. I also called TB and he confirmed my suspicion since he "has no stock until at least early next year". Might as well go buy a full trans.
Atlas.46 (09-13-2014)
#220
hmm... now this is some good info.... time to play with transmission calculators.
3.55 or 3.842 hmmm
tire size: 215/50R17
redline: 6800 ---- 7300
TL 6MT (Final Drive: 3.285)
Gear/ Gear Ratio/ Redline mph
1 ------ 3.933 -------- 39.88 -------42.81
2 ------ 2.478 -------- 63.3 -------67.95
3 ------ 1.700 -------- 92.27 -------99.05
4 ------ 1.250 -------- 125.48 -------134.71
5 ------ 0.975 -------- 160.87 -------172.7
6 ------ 0.770 -------- 203.71 -------218.68
TL 6MT (Final Drive: 3.55)
1 ------ 3.933 -------- 36.9 -------39.62
2 ------ 2.478 -------- 58.57 -------62.88
3 ------ 1.700 -------- 85.38 -------91.66
4 ------ 1.250 -------- 116.12 -------124.65
5 ------ 0.975 -------- 148.87 -------159.81
6 ------ 0.770 -------- 188.5 -------202.36
TL 6MT (Final Drive: 3.8(3.842))
1 ------ 3.933 -------- 34.1 --------36.61
2 ------ 2.478 -------- 54.12 --------58.1
3 ------ 1.700 -------- 78.89 --------84.69
4 ------ 1.250 -------- 107.29 --------115.18
5 ------ 0.975 -------- 137.55 --------147.67
6 ------ 0.770 -------- 174.17 --------186.98
3.55 or 3.842 hmmm
Sonnick (09-13-2014)
#221
3.285 ~ turbo/sc cars
3.55 ~ sc/nitrous
3.842 ~ nitrous/all motor
i would probably go for the 3.55 and do nitrous :-) They 8th gen accords go mid 13s with minimal mods and full weight compared to the 7th gen accords. Though there is about 20-40hp difference(dont remember). Gearing is a big factor.
3.55 ~ sc/nitrous
#222
Also are these 3.8 final drives coming from the auto or manual trans sh-awd? I know the 3.55 is the accord 6mt
#223
#224
3.55 ~ sc/nitrous
3.55 ~ sc/nitrous
#225
I think the 3.55 is the best overall compromise. 3.80 is just too much for my taste and 115 in 4th just doesn't cut it. I'd love to see 120mph traps and 3.55 is perfect for that. Even on a nitrous car, if you can run 105 on motor, 120 on spray should be possible - I wouldn't want to have to make that shift into 5th if not neccessary.
#226
it will...it just needs redrilled. I've done the research. Cost is $825 for the parts alone to accomplish the 3.55 setup (plus online parts dealer shipping) or a tad more local to me. If someone wants one I can have one or more drilled by my machinists. Im over there every weekend working with them on various Acura and Nissan projects
#227
#228
3.7L Nitrous Breathing CL
#229
All motor
3.842 is by far the best for an all motor car. Unless you are making 320+ all motor (hardly anyone), you should be fine with the 3.842 with the right tire size. Those doing a 75 shot or less should be fine with the 3.842 as well. 100+ shot should stick with stock gearing or do the 3.55 (although this seems very costly).
Someone buy my J37 heads so I can go ahead and order some DRs and prove the 3.842 is the best FD for all motor
#231
I guess maybe if you can get the parts for under 1,000 and do the work yourself the 3.55 might be worth it, but if you're paying double that with labor, the return will be minimal. A TL-S and an 8G Accord have basically identical power to weight ratios and are too close to call in any type of race, so it's not like the Accord's 3.55 is its "ace in the hole".
#232
All motor
I'm running 26.3" tires as well, so my gears extend slightly longer than those posted. For my setup, it's:
1 - 37
2 - 59
3 - 87
4 - 117
Daily driving is GREATLY improved in terms of throttle response and torque due to the FD / LW Fly. I have my cutout so once it's installed I will be going to the track.
The fastest traps I've seen for a full bolt on / 3.7 IM/TB setup on a TL-s is 103. I've seen an 8G Accord go 105 with I/E/gutted cats only. I believe the 3.55 plays a factor, but in terms of how much exactly I can't say.
1 - 37
2 - 59
3 - 87
4 - 117
#234
You would want to shift to 4th before you get to the 1/8th? If you're running 95 in the 1/8th with an auto and want to get to 100, with the 3.80, you'd be well into 4th before the 1/8th and a good ways into 5th in the 1/4. Heck, a 100 in the 1/8th is probably 125 in the 1/4? If so, you'd be midway thru 5th right?
#236
All motor
#237
I am surprised that no one is interested in joining the list for an mfactory final drive. it would be cheaper, and mfactory is a proven company for honda final drives
#238
All motor
I emailed MFactory over a month ago and I posted the result here. I believe they said something like they needed 10 people and it would cost around $800. A list was started and was then forgot.
#240
I know volume brings pricing down, but I still think that is expensive. They should be no more than $600 and even that is pushing it. As said above, all they have to build is the ring gear - that should be a $300 part at most.
