Handsfreelink fix for me. My issue may help others
Old 10-03-2013, 02:06 AM
bpowa's Avatar
I have a 2007 tls
I noticed the hfl did not work kept saying bootin up.
I took it put and unplugged it. And it still said booting up.
So. I read one of the possible fixes is to pop it I'm the oven and bake at 385* for 8 minutes. I let it cool down pop it back in still did not work.
As I wiggled the plug a bit the Bluetooth randomly work intermittently.
I took it out again and on closer inspection of the power plug to the pcb board. It looked like one of the prongs did not have as much sodder as the other connection prongs. I twisted the prong to the side a bit and the connection was established.
I think the board heats up quite a bit and loose its connectivity.
This was the last prong of the connector. I'm sure it holds power. I should have put a meter to it to confirm. But was happy it was working.
I hope this help others. It seems like a crappy thing to replace for a couple hundred bucks. Acura tech package my ass.
RX89014 (10-03-2013)
Old 10-03-2013, 09:52 AM
performace tl-s
rubenders's Avatar
thanks men my handfreelink dot work on a 07 type s tl
Old 10-03-2013, 06:44 PM
bpowa's Avatar
No problem. Update. It worked fine this morning. During lunch it was working intermittently again. I am going to take it out when i get a chance and add some soddar to the last pin.
Old 10-03-2013, 09:36 PM
RX89014's Avatar
Just popped my HFL into the oven too, and gained some function back. My phone was able to link up with HFL but whenever it connects its has a lot of static and will not accept any commands. Pressed both buttons to diagnose and it said HFL needs to be serviced. I'll pop it back into the oven tomorrow and check the solder too. Thanks!
Old 10-10-2013, 06:25 PM
Rita Gallion's Avatar
holy batman the oven thing worked!!!!! my car is talking away. GENIUS !!!!!
Old 10-15-2013, 04:50 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
(Generally speaking) LOL there is a lot of information in this forum. If people would just take the time to search properly (best use Google); you can learn a lot of new things plus something that may help you down the line.
Old 10-17-2013, 07:43 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
I don't understand why you guys are doing this the ghetto way and not just using a soldering iron to fix the loose solder joint, if that is indeed the problem. But btw summer heat in the car is nowhere near the temperature it takes to melt solder so I'm not sure where you are getting that theory from.
To do it right, I recommend just buying a new module, it's only about $160 and super easy to swap out at home.
Old 10-17-2013, 09:01 AM
-------Tim-------
Slpr04UA6's Avatar
^Very true! But, if you don't have the funds, and still want to try to see if it works, it's worth the effort! Mine has been working for over a couple months now! So I essentially saved the $160. I don't use it much, but still...
Old 10-17-2013, 02:13 PM
Registered but harmless
Will Y.'s Avatar
Received 1,102 Likes on 763 Posts
I think part of the issue is spotting where, and how many of, the solder joints are loose-- baking appears to close up the solder on all the small problematic joints, even those that are difficult to see.
IIRC, one of the members here tried soldering, but couldn't revive his HFL-- perhaps because he couldn't/didn't spot and repair all of the bad solder joints.
Old 09-29-2014, 08:45 AM
wales's Avatar
wales
I have Acura TL 2005 model with navigation but any time I start the car the navigation system only display Acura logo and after some time it will bring up where to input navigation code and after putting the code the screen return back to the Acura logo not displaying anything. But the radio work fine
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
justin7779
12-25-2015 10:33 PM
Aging-Hacker
10-05-2015 11:44 AM
carz0159
09-20-2015 06:11 PM
kuzdu
09-10-2015 08:42 PM
Quick Reply: Handsfreelink fix for me. My issue may help others
