In need of stock amp connecter pins
I cut the pins the connect to the stock amp from their respective wires. The head unit will not funtion without being connected to the amp. Does anybody know of any where/body that i could get these pins from. I need the 14 pin black and the 20 pin grey.
I think a junk yard or salvage yard is your best bet. You can put a WTB thread in the black market but it's doubtful you will find these.
If you have no luck, you can still have a fully functioning audio system by tapping into 4 wires coming from the HU and going to a line driver or processor.
Could you tell me or post a thread that explains which wires to tap into and how to set up a processor or line drive. Currently my head unit does not work at all if i added a processor or line drive would that solve the problem? Im contemplating replacing the entire head unit. but I would much rather avoid spending the money and time for that if i can
Ive also thought about simply buying a new non nav head-unit with rca outputs and connecting that to my aftermarket amp then running my amp to each speaker. however i do not know how i would do this.
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
Medinak12
09-23-2015 07:11 PM
Pegon95
09-15-2015 01:54 PM
yahelou
09-06-2015 09:12 PM
