Wiring diagram to and from the stock amp
Old 03-02-2017, 11:10 AM
cipher9878's Avatar
i have a 2004 TL manual with navi and i've been searching for the wiring diagram but the threads that were supposed to have them either don't exist anymore or the people who used to email them are no longer active on acurazine anymore. i'm planning on removing the stock amp and running a preamp where the stock amp was to boost the signal to the 4 channel amps that i will be running under both seats but i cant find the harnesses that i can connect to the wires into the amp and the harness output of the amp. so my only option is to slide and attach rca cables but i need to know which wires are which. i've read many threads about this and my TL is heavily modified i know what i'm doing i just need the wiring diagram. if you have any suggestion or changes that can help it would really be appreciated as well. its a complete overhaul of the audio system while keeping the headunit!
Old 03-02-2017, 12:41 PM
The DVD-A Script Guy
Adobeman's Avatar
Here's what I have (they uploaded in reversed order)
Old 03-02-2017, 01:05 PM
cipher9878's Avatar
thank you i appreciate it
