Hands Free Link - Bluetooth is stuck pairing. - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 04-14-2010, 09:32 PM   #1
Registered Member
louisville88's Avatar
I have a 2004 Acura TL. When I try to pair the phone with the HFL, it gets to pairing mode and gets stuck after I enter the 4 digit passcode. The display above the Navi just says "PHONE". The digital display on dash just shows the "PAIR CODE".
When it is stuck in pairing mode, you cannot play the radio CDs or use the GPS etc.
It usually remains in pairing mode (Stuck) for about three days!!
I searched the net and found a few others with this problem but noone knows a remedy for it.
I called HFL 1-800 number and they verified I was using a compatible phone (iPhone 3g) and that I was setting it up correctly. They said to take it to the dealer.
(FYI - I just finished setting up HFL on co-workers Range Rover and another friends Lexus with no problem at all.)
louisville88 is offline   Reply With Quote
Old 04-15-2010, 08:49 AM   #2
2004 Acura TL
Disconnect the batter, but be ready to plug in the radio code to get your radio working again.
btw 04-06 TLs are known for the HFL going bad. It needs to be replaced, last time I checked the moduel is $600+ at the dealer.
navarretg is offline   Reply With Quote
Old 04-15-2010, 09:46 AM   #3
Registered Member
Jesstzn's Avatar
You HFL unit has gone south ... mine did on my 06 ... it was even paired with 2 phones at the time and dropped the pairing .. and when I tried to redo either is did the same as yours is doing.
Jesstzn is offline   Reply With Quote
Old 04-15-2010, 12:33 PM   #4
Excels at nothing
svtmike's Avatar
I had mine replaced under my extended warranty when it was doing the same thing. There is a TSB for the issue -- I don't recall the exact number though.
svtmike is offline   Reply With Quote
Old 04-15-2010, 06:22 PM   #5
Registered Member
Basically other than paying bigbucks...I might as well forget about it?
Old 04-15-2010, 06:31 PM   #6
Registered Member
Jesstzn's Avatar
Quote:
Or get one from a wreck.
Old 04-15-2010, 07:18 PM   #7
Registered Member
Yeah good idea. Are they difficult to install?
Old 04-18-2010, 01:24 PM   #8
Registered Member
same shit on my 04 tl. $600+ at dealer damn. wondering how difficult to install? cheaper that way i guess or just forget about it hehe.
killarssm is offline   Reply With Quote
Old 04-18-2010, 01:51 PM   #9
Registered Member
Jesstzn's Avatar
Quote:
Its an easy install .. found the DIY somewhere here.
Old 04-20-2010, 08:56 AM   #10
New Member
My HFL just did the same thing. It got stuck in the pairing process and would not let me do anything. I had to disconnect the battery for about 15 seconds and then put in my radio code to get the radio working again. My radio code was on a sticker just to the left of glove box when you open the door. The dealer told me the HFL module is bad and would have to be replaced. Use the CD / preset keys to put in your radio code.
TLsmitty is offline   Reply With Quote
Old 09-02-2010, 08:08 PM   #11
Registered Member
Going to buy a used HFL out of junked car. I will let you know how it works.
Old 09-02-2010, 11:38 PM   #12
2008 Acura 3.2TL
ParaSurfer1979's Avatar
The only probem i have with my 07 tech is when connected to bt the touch sceen lags really bad. Example i press the letter A and it takes a sec before recognizing i pressed anything.
ParaSurfer1979 is offline   Reply With Quote
Old 10-18-2010, 09:37 PM   #13
Registered Member
where is the HFL module located?..i need to disable it because it is bad and draining my battery. My car will not start after sitting for 1 day!
stepuptata is offline   Reply With Quote
Old 10-19-2010, 06:51 PM   #14
Registered Member
Monty3497's Avatar
its located under the map light and sunroof switch, easy to pop out...if you can get one from an 05 + they are better than the 04...i changed mine....solved problem
Monty3497 is offline   Reply With Quote
Old 02-05-2011, 10:46 AM   #15
Registered Member
I am revisiting this thread to see if anyone has figured out a fix for this. I have been trying over the past few months to find a HFL from a TL in a junkyard locally but I can't seem to locate one.
Anyone have any other ideas?
Old 02-05-2011, 10:08 PM   #16
'08 TL NAVI - PMM / Ebony
Have you talked to your dealer? I remember reading a lot about issues with the HFL in the 04s. While I wouldn't exactly hold my breath expecting a warranty fix, you never know... And, it may also depend on your relationship with your dealer.
As far as getting it out of pairing mode - Have you tried holding the EXIT button for the HFL until it completely exits and goes into diag mode?
meburdick is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
CLOSED: 05 WDP Acura TL FULL PARTOUTNew thread will be posted for remaining parts BoricuaTL Car Parts for Sale 138 04-08-2016 02:08 PM
outgoing calls and hands free link not working 2013 MDX rmittal 1G & 2G MDX Discussion (2001-2013) 0 09-19-2015 09:41 PM
SOLD: 04-06 A-Spec Steering Wheel Acura TL IIDXholic Car Parts for Sale 9 09-19-2015 11:18 AM
Rental Review: 2016 Hyundai Sonata Hybrid PortlandRL Car Talk 2 09-14-2015 01:01 PM
Converting a Blitzsafe - HON/M-Link1 V.2X to Bluetooth! ivegotthenav 1G TSX Performance Parts & Modifications 0 09-11-2015 08:51 PM
Tags
2004, acura, battery, bluetooth, free, hands, hfl, links, mode, pair, pairing, problem, radio, stuck, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
