Coincidence?
Coincidence?
Had to replace the passenger door speaker recently because, at certain volumes, it would make a crackling noise. Opened the door panel and noticed the speaker had cracks.
So I purchased some Polk DB651, and had a audio installer put them on. Long story short, now BOTH speakers (front driver door and passenger door) do not work. And to add insult to injury they told me that the rod for my driver door opening mechanism (from the inside) was loose/damaged. So now I cannot open the door from the inside (driver door only).
The installer told me that more than likely the amp went bad. Knowing that the speakers (OEM/stock) worked before, is that true? Came in with them needing to install speakers to fix one problem, and left with two new problems.
switched!?!?!??! tell me more!
yep, probably will never sell the TL. as they age and depreciate, it's worth MORE to me than I would ever get out of it, money wise. unless something catastrophic happens to it, it will be with me for a long long while .
and crackly speakers/sound is a tell tale sign the amp is cutting out. you can try junk yard amp/ebay used...
or you can grab the replacement amp that a vender was selling on here? it had better specs than OEM and still fit and bolted right up into OEM location. might be pricey tho.
There's a small clip that is extremely easy to break when taking off the door cards, and if it breaks the inside door latch won't work. I can almost guarantee that is what broke when they took your door out.
https://acurazine.com/forums/third-g...-cable-631638/
I was thinking about getting one from Marcus, but may end up purchasing a 2-channel or 4-channel and just get it done. Don't plan on getting an aftermarket sub since I do not drive the car much anymore.
