cd stuck inside cd changer, won't eject help.
i had this cd i wanted to test but i notice it had some scratches. it played did play well but while the cd was inside i tried to switch to a different cd but that did not work. Press the eject button and got cd error. now my cd are stuck inside and i cannot listen to any music cause it does not do anything. When i press Disc play it doesn't even go to disk mode, it just stay in xm, or fm wherever is on. i press the eject and I do hear a forcing eject sound but it doesn't eject the cd. press load cd and nothing. i disconnected and connected the battery, inserted the radio code and still same problem. The slot where you load the cd is close so i cannot even put a knife inside to help the cd changer eject the cd.
Any solution on this?
Proud Acura Owner
Same thing happened to me in my 04 cts-v worst $1000 mistake ever.......! Never put scratched CDs in your cd changer! Ill neveThat That in my type-s :-)
I had this happen multiple times on a Nissan. Found out about 2 years later that homemade CD labels were getting hot, peeling off and causing the jam.
Why would a scratched CD cause a jam? Seems like it would have to be a very severe scratch in order to produce a mechanical snag.
Proud Acura Owner
SidhuSaaB
05-30-2020 12:40 AM
xsilverhawkx
09-28-2015 06:51 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
