Car cassette player! Help!
Old 09-25-2015, 10:21 PM
8th Gear
Fool's Avatar
so my cassette player in my car takes the tape in and then the tape will stay in their for a little bit and then it starts making noises. After that, it changes to the radio station and then the tape would pop back out.. Can someone tell me how can I fix this problem.. I tried different tapes and i realized that it isn't the tapes problem.. BTW i'm using the monster icarplay cassette tape.
Old 09-27-2015, 06:58 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,651 Likes on 1,116 Posts
Not sure. Not many people around here still use cassette tapes. I would try to take it to the dealer and see what they say. Or better yet, try the AUX port or change to a different format.
Old 09-27-2015, 08:04 AM
WhyteLegend's Avatar
Blow compress air it , it u can reach the head use a Q-tip with alcohol to clean or get a cleaner from the store if they still exist.
Old 09-27-2015, 11:48 AM
Jackass's Avatar
You do realize most of us that use a cassette adapter don't have an AUX port right?
Old 09-27-2015, 01:48 PM
Life Connoisseur
MonkeyTrucker's Avatar
Classic!
The following 5 users liked this post by MonkeyTrucker:
Adobeman (09-29-2015), Azonics (10-07-2015), EvilVirus (09-28-2015), Jackass (09-27-2015), NBP04TL4ME (09-27-2015)
Old 09-27-2015, 02:26 PM
RDX-Rick's Avatar
It has been almost 2 decades since I last worked on a tape deck, but the most common point of failure was stretching or breakage of one of the rubber belts. These belts look similar to black rubber bands, but are somewhat less "stretchy".
There are optical sensors within the tape deck that determine if the tape is moving. If the tape is not moving due to belt slippage/breakage the tape will be rejected.
If you feel like you have the patience to open up your player, you could quickly determine if this is the problem, and it should be fairly easy to find a universal replacement belt. I have actually used rubber bands for a short term repair.
Old 09-28-2015, 12:59 AM
8th Gear
Fool's Avatar
oh damm... so i should just install a AUX into the car? do you guys know whats a good brand?
Old 09-28-2015, 09:04 AM
RDX-Rick's Avatar
If your vehicle doesn't have an AUX jack somewhere already, it is probably because your stereo does not have an AUX input.
If you feel comfortable removing the stereo from your dash to look for an AUX input, then it is only a couple of minutes more work to remove the cover from the stereo and examine the belts.
If you want an inexpensive fix, you might consider the purchase of an FM transmitter than can plug into the earphone jack of any device. You can listen to the output by tuning into the proper frequency on your FM radio. There are also similar devices that send the output as a BlueTooth signal if your existing stereo has that capability.
Old 09-28-2015, 05:04 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
IIRC 07-08 came with Aux located in the center glove box
Old 03-10-2016, 08:42 PM
3rd Gear
Jonah Peitz's Avatar
I also use monster icarplay and sometimes i run into your problem, it'll keep switching sides and clicking and then faster, then it spits it out, i dont run into this problem much any more but once in a while it will. It was doing it way more when i first got the car, the more you use it the better i think it gets
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
kuzdu
09-10-2015 08:42 PM
jordanboi
09-05-2015 01:33 AM
08-30-2015 02:39 PM
Quick Reply: Car cassette player! Help!
