45022-SEP-A61 vs 45022-SEP-A60
Old 05-19-2016, 11:29 AM
6th Gear
edeizie's Avatar
Question 45022-SEP-A61 vs 45022-SEP-A60
new user here i have a 2004 Acura TL 6MT that need new front brakes i know that the 6MT needs Brembo brakes but i have come across the two part numbers listed can be interchangeable but A60's are $70 and A61 are $170 seems like i can save $100 with the A60 but what am I giving up for the $100 has anyone else run into this issue. Thanks for helping me out...
Old 05-19-2016, 11:52 AM
#1 Super Guy!
94eg!'s Avatar
A60 has been replaced by A61. You can see at this link below. When searching for A60 on OEMAcuraParts.com, your only return is for A61 containing a note that says it replaces A50, A51, A52, A53 & A60.
Acura Parts | OEM Acura Parts | Factory Acura Parts
If you can get A60's for $70, then it must be old stock.
BTW: You can get the exact same pad material from Centric for only $50. Part number is 100.10010 and is part of their OE compound lineup. Their 100 series pads use OEM/Brembo friction material on Centrics own backing plate (with their crimped on shims). Centric is also the makers of Stoptech.
The following 4 users liked this post by 94eg!:
EvilVirus (05-19-2016), Legend2TL (05-20-2016), maharajamd (05-19-2016), Ron A (05-19-2016)
Old 05-19-2016, 11:55 AM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
+1 listen to this guy. Save the cash and buy the Centrics.
Amazon.com: Centric Parts 100.10010 100 Series Brake Pad: Automotive Amazon.com: Centric Parts 100.10010 100 Series Brake Pad: Automotive
ChristianRE (09-27-2019)
Old 05-19-2016, 12:08 PM
6th Gear
edeizie's Avatar
thank you for the quick resonse
Old 05-19-2016, 12:47 PM
6th Gear
edeizie's Avatar
i ordered the Centric pads based on 94EG! recommendation i will keep you updated on install
Old 05-19-2016, 01:08 PM
maharajamd's Avatar
I have to admit swapping pads is pretty damn easy. Good luck!
Old 05-19-2016, 03:39 PM
Turbonut's Avatar
FYI-Rock Auto sells CENTRIC 10010010 for $40.79
Use code 4319826139083105 for 5% discount. Good 'til end of month.
The following 3 users liked this post by Turbonut:
EvilVirus (05-19-2016), gatrhumpy (08-23-2016), maharajamd (05-19-2016)
Old 05-19-2016, 08:34 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
I had those same centric brake pads on my TL. they were great!
Old 05-20-2016, 06:55 AM
DMZ
Head a da Family
DMZ's Avatar
Or you can now buy the OEM Brembo branded pads without the Honda name on the package from Tirerack. I myself like the Wagner Thermo Quiet replacements from rockauto, part # MX1049. More than adequate stopping power and NONE of the dust for a mere $25. My biggest complaint about the original pads was the insane amount of dusting whereby the wheels turned black only a few days after washing the car.
Old 05-20-2016, 09:54 AM
#1 Super Guy!
94eg!'s Avatar
Originally Posted by DMZ
Or you can now buy the OEM Brembo branded pads without the Honda name on the package from Tirerack....
Those Brembo pads on TireRack with the red shims for $70 are NOT the same thing as OEM/Brembo. They are a cheaper ceramic compound. The original Brembo compound is a max performance street pad that puts response above everything else. This is why they dust so much.
Stoptechs are another alternative that balance response with high-temp fade resistance. They too dust quite a bit.
This is normal.
The following 2 users liked this post by 94eg!:
DMZ (05-21-2016), freddiemercury1 (08-19-2016)
Old 05-20-2016, 12:05 PM
beanertypes's Avatar
Awesome, on my way to order the Centric pads. Love ACURAZINE !
Old 05-20-2016, 03:14 PM
AZ Community Team
Legend2TL's Avatar
Received 4,036 Likes on 2,511 Posts
^ let us know how they work on your TL
Old 08-19-2016, 01:52 PM
freddiemercury1's Avatar
This is normal.
Do you know the centric equivalent to the rear brake pads?
Old 08-19-2016, 05:41 PM
#1 Super Guy!
94eg!'s Avatar
For the Stoptech it's 309.05360
For the OEM compounds is 100.05360
Personally if I could do it all over, I would try the Nissin rear pads. Nissin is the company that manufacturers most of Honda's brake systems. The Nissin rear pads have a higher coefficient of friction than the OEM Honda pads (GG instead of FF). In theory this should make the brake bias a bit more aggressive. Also they are OEM quality so you definitely can't go wrong.
Old 08-22-2016, 02:31 PM
Yvuru's Avatar
using the akebono street performance pads and absolutely love them. they too are GG rated
OEM has the best brake feeling though
