Remote Engine start Problem
Old 03-03-2016, 01:34 AM
  #81
tman's Avatar
Cannot believe a Dealer in good conscious charge an hour to program, unless the hourly rate is over $200/hr The TSB says the dealer flat rate charge is .6 hour. That is including remove old unit, install new unit, and then program remotes.
Old 03-07-2017, 11:22 AM
  #82
Maddad524's Avatar
As of Jan 1st there is a TSB that addresses this poor distance performance of remote start. TSB #16-001 the dealer will install a new module and 2 key fobs for free if your within the 4 year 50,000 mile factory warrantee, after that is out, I'm not sure what the process is but you can wheel and deal with the dealer. Good luck, hope this helps someone
Old 02-08-2020, 09:29 PM
  #83
Superman
stanekfelix's Avatar
Question
Originally Posted by fun2drive
Alex,
[...] The remote start will ONLY start the MDX twice before you will have to go into the MDX and press the brakes/start button to essentially get it out of the remote start mode.
This seems to be either a bug, or a 100% useless feature or safety precaution. If not, I'm quite curious to learn the reasoning behind this design. It is however in line with the manual, which says: "Pess LOCK, then press and hold ENGINE. The amber LED blinks, and the green LED stays solid for one second when the engine starts. You can repeat this onceat any time within 10 minutes of the initial remote start for a 10-minute extension."
On the other hand, according to this official video at around 1m:25s,
"The engine may not start if: [...] Remote has been used twice in quick succession to start the engine", which is rather vague and likely inaccurate. What exactly is "quick succession"? I only ever tested with 2 hours, which the MDX thinks is "quick". Is it really the case that after 2 starts, there's simply no other way but physically go to the car?
idubbz
3G RDX DIY & FAQ
03-28-2019 10:04 AM
AliShibaz
1/2G MDX (2001-2013)
02-04-2019 05:56 PM
Tech
11-26-2017 08:44 AM
mdusk
01-22-2005 06:12 AM
fastcarz3
31
10-26-2002 09:03 AM
Quick Reply: Remote Engine start Problem
