Hardwire using Fuse Tap into Fuse Box Problem
So I want to do a clean hardwiring where I have a 12 Volt Outlet where I cut the end of the wire where the positive wire is connected to the Fuse Tap and the other wire grounded on the the metal.
I connect the Fuse Tap on the Acc Fuse on the driver side fuse box. But once it is connected when I start the car, the screen will not work. When I unplug the Fuse Tap and just connect the 7.5 amp fuse direct to the fuse box the screen will work. Am I doing something wrong on connecting the Fuse Tap onto the fuse box? Is there another fuse where I can tap to?
