Dash lit up like a christmas tree
To start off I will be calling my dealer in the morning, but on my way home tonight my dash lit up with 8 different error messages. All of a sudden the car wouldn't accelerate, the steering felt like it had no power steering and the acura messages just kept poping up on the nave screen. Here are a couple screen shots and a list of the errors.
LDW
FCW
VSA
EPS
SH-AWD
Trailer stability assist problem (yet I dont have trailering package)
Hill start assist problem
emissions system
Not sure if any of you have had this happen...I am not even sure I could drive it on the freeway if I wanted to. It takes a long time to get up to speed and the engine is very load like I am stuck in 2nd gear or something.
LDW
FCW
VSA
EPS
SH-AWD
emissions system
^^ there is a similar thread on the exact same issue, and in fact, I think he made reference to the xmas tree too. This is what worries me about the TLX coming out....too much tech these days
Forum Contributor
Received 1,391 Likes
DTC P2138: Accelerator Pedal Position (APP) Sensor A/B (Throttle Position (TP) Sensor D/E) Incorrect Voltage Correlation
Let us know if there are any other DTCs listed on the screen.
I will when I get home tonight...I didnt drive it today, but when I called the dealer they thought that I had a drop in voltage...seems weird though cause it happened when I had been driving for about 10 min. I started it up this morning and had all the same codes so I left it in the garage and took the Cadi to work.
A glitch that could get someone killed? What if you're making a left turn and the car goes into limp mode and a semi ready to T-bone you and you can't accelerate?
Jotas (03-30-2014)
2G TLX-S
Unfortunately, that's life.
As the electronic systems become more and more complex in today's hi-tech vehicles, the more likely non-reproducible glitches will come up randomly.
Not even top notch automakers in reliability, such as Toyota and Honda, are totally immune to "lemon cars" and computer glitches.
Unless that tens and hundreds of MDX owners are reporting this same glitch problem or that failure occurrence is reproducible at the dealership (like the current GM ignition switch problem), otherwise the dealership won't do a lot, other than simply resetting the car computer.
We've seen it a few times in new MDX's, and if I remember correctly, each time it was due to a crank position sensor not having been learned/programmed correctly from the factory, then throwing codes.
Each time, it was the same thing, and once diagnosed, didn't return.
I dont know...but they kept it over night and it reproduced...they said they have never seen anything like it before and have to call the techline or corprate...so at this point no idea still.
Blame GM.
So they said they reset it and it didn't come back...I went and picked it up today...drove 15 miles and same thing happened again...when I picked it up the service dept. Was closed, there was no paper work, guy just walked me out to the car, gave me the keys and said if it happens again let them know...looks like it will be heading back tomorrow.
^^ Grrr...I feel your pain and the joy of electrical gremlins!!
...and from what I heard from a reliable source, these are not as rare as people would think with these newer Acuras. Can't confirm this statement though....
They werent that rare before the new infotainment either. Just be happy that almost all the time they have no drivability impact. Mostly a temporary annoyance.
So this time they said they found a faulty accelerator pedal switch. They replaced it and test drove it for 11 miles and codes never came back....but 20 miles from the dealership all lights came back on...so now it is heading back to the dealership today...so far it has been there twice and they kept it for a week each time...looks like I will be withoit it for another week.
You have a gremlin which in my experience tend to be very hard to exorcise, since the codes are mostly red herrings. Sounds like you are heading to a lemon proceeding. After 5 trips if your dealer is smart and the thing doesn't go away he will offer you a new car prorating the miles driven. BTW, these things happen in all "families" hopefully in very low numbers.
Yeah I know...it just sucks...I really like the MDX...wife was really pushing for an Audi Q7 but I was like no way they have a ton of electrical issues and bad reliability...Acura is known for outstanding reliability...lol...now that one is biting me in the ass...lol
We've seen it more than once, and it's an odd occurrence, but does not mean the car is defective. Mention crank position sensor un-learned and see if that rings any bells. Each time this has happened, it seemed to be the same reason for us...but even so, is not overly common. Just enough to know how it was fixed each time for ours.
Yours might be different, but I would venture to say it likely is not.
[QUOTE]
We had the same problem except that the car kept operating fine. I took it to
the dealer and luckily the lights were still all on. They kept the car for a day
and went through all of the wiring connectors for each system, unplugging and
replugging. The codes and lights have not come back since. They though possibly
a wheele sensor connection was not made properly at the dealership. We love our
MDX.
MDX.
***Update****
They told me I had to disconnect the headrest monitors and radar detector and then they would check it again because they have done everything tech line told them to and nothing has worked. I then talked to the service manager and told him about the crank position sensor. He said they have talked to tech line and checked everything they said to check, but he would inform the tech of the crank sensor. My wife then picked up the car to get all the "aftermarket" electronics disconnected and the lights where on. I drove it the next day and she was back to normal, have been driving it everyday for 2 weeks and no lights have popped up. My guess is it was the sensor and they adjusted or reset it. As of now I am happy to have it back and will update if anything changes.
Here is what happened to me - 2014 MDX (tech package)
I've had the dashboard light up with every error message too
I brought it straight to my dealership - they took pictures of all the messages - then they kept it for 2 weeks and could not recreate the issue once.
Then the problem FOLLOWED me to my loaner 2014 MDX (non-tech package)
The common factor? It's my Samsung Note 3 phone.
Right now my key fob starts the car no issues - but when I backup in reverse the car screams at me that the KEY IS NOT DETECTED.
If I leave the cell phone in my house or office (not a realistic scenario) the issue goes away
I have no idea who is to blame here - Samsung or Acura - I am not sure what to do either at this point
Nixonride03 (10-31-2014)
2G TLX-S
Is this Samsung-phone-Acura-MDX interference always reproducible, or just a random event ?
Update: Been busy the past few months but thought I would update you guys with my experience...So I took it to a different dealership, the one I purchased the car from...they did all the tests and came back with the faulty accelerator pedal like the other dealership did...replaced it and it still did not work. They disconnected my ACC wiring for monitors, sub and radar detector and found that they where not the issue...then replaced the main engine harness...worked great for about a week and then the lights cam back on. So at this point the vehicle now has 14000 miles on it and over half its life has dealt with some electrical gremlin...I hate to say it but now 4+ trips into the shop for the same issue is crazy. I have to do some research on Lemon Laws in Washington State but looks like that is where I am headed.
Sounds like you are in the realm of the WA Lemon Law. Where did you purchase your MDX? Let us know of their customer service. Did they EVER check the crank position sensor? Good luck to you.
LDW
FCW
VSA
EPS
SH-AWD
emissions system
LDW
FCW
VSA
EPS
SH-AWD
emissions system
FYI, the dealer replaced the whole fuel system and it seems fixed after that.
the post by mkiwiet got me thinking, I had a Galaxy S4, I have since switched to an Iphone 6...Since the swap I have not had any problems. I am going to continue to watch it and update later on...I have however noticed that the text messages no longer come through on the dash.
Black is a ***** to Clean
1 Post
This just happened to me when I tried to start up my 2014 MDX. First time seeing something like this. Tried restarting car without luck. Dealer is closed for the day. Did this ever get resolved? Hoping to not have this live at the dealer on and off for the month.... :/
remove the battery terminal cables and then stomp on the brake pedal once/twice to consume any residual power the ABS system is holding - leave the terminals undone for ~10-30 minutes and attempt to restart.
no luck?
obtain a OBD reader ($20 at wallyworld these days) and see if there's any codes you can pull or clear. turn car off completely, then attempt to start.
that said, best option is take it to the dealer if you're still under warranty
Not the OP, but try:
no luck?
no luck?
