30,000 miles maintenance care.
Sup guys, my 2015 SHAWD MDX is hitting 30,000 miles. what fuild must be change, I.e, Rear differential, transfer, transmission flush/sweetening what else? Thank you very much.
Not entirely required, but I recommend engine oil (per your usual intervals), coolant and brake fluid as well. Air filter, cabin filter, rotate tires are also good to do. I don't recall there being much else outside of what you listed. Some people will say you're a bit early on the ATF and transfer, but I think 30k is a reasonable interval for such. Most people have burnt ATF by 60k anyway and the 6 speed is really easy to change.
