2017 Bolt Pattern
Old 12-03-2016, 07:50 AM
Type-S RPh's Avatar
2017 Bolt Pattern
Sorry if this has been covered before but has anyone else noticed that the 2017 MDX bolt pattern is back to 5x120.
Old 12-03-2016, 09:03 AM
Received 16,260 Likes on 11,971 Posts
because Acura is confused AF!
Old 12-04-2016, 03:01 AM
2G TLX-S
Edward'TLS's Avatar
Received 1,133 Likes on 813 Posts
The 2017 MDX needs this wider 5x120 bolt pattern, because it starts using the big-ass 20" wheels as standard equipment.
Old 12-04-2016, 06:07 PM
tman's Avatar
These folks need to change the spec Im guess'n:
Acura MDX Wheel Bolt Pattern & Offset, Stock & Aftermarket Rims, Lug Pattern, All Rim Specs
Old 12-05-2016, 03:07 PM
neoshi's Avatar
Awww wtf. I was just going to get some takeoffs from a 2017 to put on my 16 since the 20s tires are cheaper than the 19s, but nevermind! Guess I'll get some aftermarket wheels after all.
Old 12-05-2016, 03:23 PM
neoshi's Avatar
Can't edit previous but looking at the part diagrams, the only things that changed are the hub assembly and the bolts, so if one ever wanted to, you COULD change to 5x120 pretty easily on the 2014-2016s. Not that most people ever would, but 5x120 wheel options tend to be much nicer.
Old 01-09-2017, 09:30 PM
Former Sponsor
rondog's Avatar
Much easier to convert the wheel to a 5 x 120, such an easy change without disassembling the vehicle, we actually do it with a CNC machine and press in new steel insert seats. Or you could just get some RJ wheels that are hubcentirc and built to fit perfectly. 18", 19" and 20" that are 20% lighter than factory.
Old 01-10-2017, 09:24 AM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
Does the 14-16 and +17 use ball or conical lug nuts?
I have RonJon rims on my 08 RDX (+6yrs) and 11 MDX(+2yrs) and they look way better than any factory rims. No messing around with hubcentric rings, zero issues with TPMS x-fer, final wheel finish limited to your imagination, and plenty of styles to pick from. The only two minor issues I had to do was:
- need to keep a set of the OEM ball lugs in the vehicles for the OEM spare since the RonJon rims use conical lugs.
- purchased a second set of wheel locks because the RonJon spline wheel locks with socket key are becoming more common. I have Gorilla wheel locks along with the RonJon locks.
Old 01-10-2017, 09:29 AM
Received 8,584 Likes on 6,630 Posts
Aren't all OEM wheels ball nut
Old 01-11-2017, 01:21 AM
2G TLX-S
Edward'TLS's Avatar
Yes.
Old 01-11-2017, 09:04 PM
Type-S RPh's Avatar
Ron good to see you back on Acurazine! What 5x120 20 inch wheel options do you have? I'm thinking of putting snow tires on my stocks and getting a set of summer wheels and tires.
Old 01-12-2017, 03:59 PM
Former Sponsor
rondog's Avatar
Thanks for the warm welcome. Right now, we have 18" and 19" Legacy 7 and the 20" Inspyre type II. All are available in 5 x 120, and there are discounts available.
Contact me for best deals. contact info is below.
Old 01-12-2017, 08:05 PM
Type-S RPh's Avatar
Anything new in the works?
Old 01-12-2017, 11:14 PM
Former Sponsor
rondog's Avatar
Sup, another 2001 OG!
Just running with the best sellers, the 18" & 19" Legacy-MC7 and the 18" Rev-GT5 wheels and I still have some 20" Inspyre type II in stock.. Also started production back up on the 4G TL grille and bodykits. Basically pretty busy with these products while trimming the fat so to speak and discontinuing some wheels like the Harrow, Stryfe and Legacy type II. Still some dwindling inventory of those wheels though. Once I get everything produced, we will see if there is any interest in a new product or wheel. Anything in mind that I could should briefed on?
Old 01-13-2017, 01:14 AM
2G TLX-S
Edward'TLS's Avatar
4G TL grille and bodykits -
Old 08-16-2017, 12:05 PM
3rd Gear
Danny Santuchi's Avatar
Hello lo how can I get. Contact w you abut CNC machine??
Old 08-29-2017, 11:31 PM
3rd Gear
Please can u give me your info of this company to get this job done I got 2017 wheels that need CNC machine and new steel inserts
Old 09-19-2017, 10:13 PM
J37A5
HondaOwnerForLife's Avatar
Hi Ron,
I'm looking for 20 X 10's for my 2010 ZDX.
