2014 MDX jerks at 40-50mph
Old 03-06-2017, 10:44 PM
Kmac2017's Avatar
I recently purchased a 2014 MDX with 44k miles on it. Around 40-50mph the car jerks badly. I either have to let my foot off the gas, or gun it to switch gears. I pretty much cannot cruise at that speed without the jerking issue. I brought it into the dealership and they said they couldn't find anything wrong. I feel as if it is getting worse and it is driving me nuts. Any idea what it could be?
Old 03-08-2017, 09:21 PM
Bluepill's Avatar
Need to determine if it is engine or transmission. Try locking the trans in 5th gear, and see if the problem goes away. Try the same test in 4th gear also.
Old 03-08-2017, 10:50 PM
NVAKeith's Avatar
Does the RPM fluctuate when this happens? If so it may be the torque converter. There is a TSB for it.
http://www.urvi.net/forumfiles/SB/B16-062.PDF
Kmac2017 (03-23-2017)
Old 03-23-2017, 10:00 AM
Kmac2017's Avatar
Yes, the RPM bounces up and down when this happens. Any idea what it will cost to replace the TC if that's what it is? (sounds like it from the service bulletin)
Old 03-23-2017, 02:56 PM
NVAKeith's Avatar
It should be covered under the 6 year/70,000 mile powertrain warranty.
Old 03-24-2017, 09:34 PM
2014 RDX AWD Tech
Comfy's Avatar
Looks like a trip to the dealer is warranted. Good luck.
Old 10-14-2019, 11:57 PM
autoperformance's Avatar
any news what was the problem?
Old 10-15-2019, 10:52 AM
Zestys1's Avatar
Yup change transmission fluid every other oil change only fix,that what I do with my 2014 only fix that I know of
Old 10-16-2019, 07:24 AM
Ok only un oil change and everything will be all right?
Nice to heard that. Don't want to paid for a new tranny.
Old 10-16-2019, 03:08 PM
NVAKeith's Avatar
Check out the TSB linked above in post 3. The “flush” procedure is on page 5. Also note there is an 8 year 80,000 warranty for this problem.
Old 10-16-2019, 04:20 PM
Zestys1's Avatar
Transmission shifts beautiful after flush my vehicle has 110,000 been flushing since 30000 miles
