the lowdown on Mugen Sport Suspension
Old 06-21-2016, 01:58 PM
mt3c's Avatar
I'm dating myself by calling the Mugen Sport Suspension a "lowdown" kit. I guess this is carryover from the days when Mugen was marketing there non-adjustable spring/shock assembly as the Lowdown Kit for EK9 and DC2.
Anyhow, I wanted to post some technical information I've researched on the two version of the kit for 2nd gen TSX. Physically, they appear the same, but there are some differences. Both will lower there respective vehicles 20 mm all around.
For the sedan (I4), the part number is 50000-XLL-K0S0
source1 source2
For the sport wagon, the part number is 50000-XLLB-K0S0
source3
The front assemblies are the same for both kits.
The rear is what is different, looks like only the spring rate is different. Sedan has 32 N/mm (3.26kg/mm, 183 lb/in) VS the Wagons 35 N/mm (3.57kg/mm, 200 lb/in). Dampers are the same.
Makes sense to me, there is more weight over the rear of the wagon.
source4
Are the kits interchangeable? Yes, but the lowering amount will vary at the rear.
By how much? I haven't figured that out yet.
Pictures of said Sport Suspension on wagon? Google search! but to help you get started, not my car...
That being said, order the correct kit for your vehicle, or go with an adjustable coilover suspension where you can change the height or rear springs for the wagon (likewise for the fronts of V6)
The following 2 users liked this post by mt3c:
cu2wagon (06-22-2016), makakio (07-05-2016)
Old 06-22-2016, 04:20 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Interesting. The biggest takeaway I'm getting is that the Mugen spring rate is ~9.5% greater for the wagon vs. sedan. Which is a good bogey to keep in mind if trying to adapt a sedan set to the wagon (or vice-versa, I suppose).
Good info!
Old 07-06-2016, 08:58 AM
makakio's Avatar
Found this too. The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > TSX > > Re: Before/After photos of TSX Sportwagon with Mugen Suspension, 19" SSRs
11-17-2017 09:26 PM
mt3c
07-06-2016 12:55 AM
RLX-Sport Hybrid
3G RLX (2013+)
05-10-2016 06:25 PM
neuronbob
3G RLX (2013+)
11-27-2014 11:58 AM
Quick Reply: the lowdown on Mugen Sport Suspension
