looking to buy these rims... 18x8 +42 5x114.3
im looking into these rims but not sure how the specs are
The wheels are Elbrus I06's in 18x8 +42, these wheels are discontinued. Overall I'd say wheels are 9/10 condition.
The tires are Continental ExtremeContact DW's in excellent condition. Staggered size (Front: 225/40/18) (Rear: 245/35/18)
Is the tires thick on these rims ?
what does staggered mean also?
thank you
Elbrus I06 18x8 +42 5x114.3
thank you
Received 7,772 Likes
Not sure what you mean by "thick". The front is stock width and the rear is 20mm wider than stock.
Staggered means the front and back are different widths, 225 vs 245. Typically people use "staggered" when talking about wheel offset differences front-to-back. But it sort of holds in this case as well.
They should fit.
I like the look too - a nice design.
No idea on that manufacturer though; never heard of them.
They should fit.
thanks guys, so is this close to stock?
thick meaning i didnt want low profile tires, because of shitty city streets...
so will i be good buying these with stock suspension set up?
what specs are stock tsx tires?
then input stock tsx tires into here:
http://www.1010tires.com/Tools/Tire-Size-Calculator
and then input aftermarket tires and hit compare
225/50r17
You know you can get new tires put on, right?
Ones that are closer to stock diameter?
Tires & Wheels | Car Tires & Wheels | SUV/Truck Tires & Wheels | Discount Tire Has everything you could possibly want to learn on the matter.
acuratl2006owner
03-05-2016 09:40 AM
