Need help replacing wheel lug stud
Old 04-26-2011, 06:07 PM
Supreme's Avatar
I recently cracked one for my lug studs
Here is a picture of the rotor removed
Tried to bang the stud out but I got stuck right here. Anyone know how I could remove it to replace it with a new one?
Old 04-26-2011, 06:17 PM
Supreme's Avatar
Need quick responses if possible
Old 04-26-2011, 06:39 PM
MrOtocinclus's Avatar
A perfect guide, from the TL forums:
https://acurazine.com/forums/2g-tl-problems-fixes-117/replacing-broken-wheel-lug-stud-596439/
Old 04-26-2011, 06:55 PM
Supreme's Avatar
https://acurazine.com/forums/showthread.php?t=596439
Yes I used this exact thread I used to refer to. Unfortunately the hub isn't the same.
He was able to freely bang out the stud as pictured here:
I banged away but I'm stuck right here:
Old 04-26-2011, 07:00 PM
Man, that's a drag... if you need a quick answer I'd suggest forking over the $10 and getting 3-day access to the service manual online:
http://www.helminc.com/helm/search_s...lm&class_2=AHA
Old 04-26-2011, 07:02 PM
its rayden's Avatar
how did you break the stud anyway?
Old 04-26-2011, 07:14 PM
Received 16,260 Likes on 11,971 Posts
probably by changing the tire and stepping on the lug nut wrench wrong.
Old 04-26-2011, 07:19 PM
Supreme's Avatar
This is for the front btw
Old 04-26-2011, 07:23 PM
You see me, I CU2
Mr. NC's Avatar
Warning dumb comment*
Can't you just saw it on both sides then drill the core til it shatters? I mean its already broken...might as well break it fully
Old 04-26-2011, 08:53 PM
its rayden's Avatar
^^ what he said..
Old 04-26-2011, 09:17 PM
Supreme's Avatar
I could and that would shatter it. But I have to fit a new stub in there... I gotta figure how to get that in haha
Old 05-16-2011, 11:03 PM
Endika's Avatar
Gotta take the entire hub off cant just hammer them in n out. I gotta do the same also, how much did it cost for a new stud?
Old 05-16-2011, 11:07 PM
B A N N E D
friesm2000's Avatar
normally only $2 or 3 or so at the dealer
as far as getting it out, OP have you looked all the way around the hub for a little notch, for the studs to come out easily; icause i don't know so much if you wanna pull the hub out, good chance of screwing the bearing, if it is a pressed fir bearing
Old 05-23-2011, 11:47 AM
DJMcGee's Avatar
Right, there is either a notch somewhere around the hub or you will have to remove the wheel mounting hub.
Old 10-11-2011, 08:11 PM
7th Gear
raleightk's Avatar
What did you do to get the lug out?
I have the same problem and do not want to deal with the bearing issue. I was considering grinding down the lug head on the new one and using a Dremel tool to cut down the the bolt that is on the hub already. Cutting the one already on the car will be a bear, but the alternative is something that is beyond my capabilities.
Does anyone else have a better idea?
Old 10-11-2011, 08:47 PM
7th Gear
raleightk's Avatar
I going to try this: http://www.youtube.com/watch?v=JAcMw...ayer_embedded#!
Old 11-07-2011, 07:47 PM
7th Gear
raleightk's Avatar
Sorry for the typo before. It worked. We did not have to mess with the bearings.
Old 01-06-2018, 10:54 PM
dillonewilliams's Avatar
2g tsx Front Wheel Stud Replacement SOS
Hey guys, I tried looking for help through the forums but all the links did not work. I have a couple stripped wheel studs on the front passenger side that I'm trying to replace, but there is not enough room to bang them out. Does anybody have suggestions for replacing them without removing the hub???
Old 01-08-2018, 09:37 AM
TexasHonda's Avatar
Saber saw to cut the head and tail (if needed). Grind enough of head on one side to allow insertion from rear (some force req'd). See youtube for videos on your car (Accord, TSX, CRV, TL, etc)
good luck
nanos
11-12-2015 08:41 PM
lland
10-04-2015 04:47 PM
DUECE_DXJ
09-24-2015 04:54 PM
GhostTL09
09-19-2015 01:57 PM
mtl_ilx
09-03-2015 09:48 AM
Quick Reply: Need help replacing wheel lug stud
