DRL Error when leds are installed
is there a way to disable the DRL ERROR on my dash... i have conntected everything properly so i am looking for a fix to disable this error
I would imagine the DRL error is from not having high enough resistance in your LEDs. There is a post over on TSXclub about it working, but I don;t see how much resistor load he had to add, guessing 8ohm per side based on the label on the box.
white led DRL with NO error message! - Acura TSX Forum
This post says a 6ohm load will be sufficient to kill the message
Turn off daytime running lights - Acura TSX Forum
