differential fluid
differential fluid
Does anyone know if in 2013 Acura TSX, the differential fluid needs to be replaced when you're replacing transmission fluid. Is it separate, or is it the same fluid? I was told by one independent mechanic that in some front wheel drive cars, the fluids are separate. So, it the fluid the same or separate in Acura TSX?
Welcome to the forums.
I moved your thread from 4G TL P&F to 2G TSX P&F.
I deleted your other thread since it was an exact duplicate of this one except for the title.
TheMuffinMan
12-31-2016 09:35 PM
