Clutch press solenoid valve A
Old 01-22-2017, 03:32 PM
6th Gear
islanddread0511's Avatar
Good day
I have a 2010 tsx, I recently changed my clutch pressure solenoid valve A because the connection plug in broke off from the solenoid.....purchased a new solenoid and installed.
Car worked fine for about 20 minuets.....then it stated "jurk" into gear when I get to about 20mph
Got a DTS check and the code read P0747 clutch pressure solenoid valve A stuck open
Removed the battery terminals to reset the computer, which i read may help the problem....That didn't work
Checked my fluids level it was good
The car works fine once it's above 20mph, but rpm stays at 3000 which I think is very high.
Any helpful suggestions that I can try, other than worst case buying a new transmission.
Thanks.
Old 01-23-2017, 09:58 AM
TexasHonda's Avatar
Enclosed are diagnostics for P0747. Looks like trash could be blocking the valve from closing or defective solenoid valve (have you tested w/ 12V directly applied?).
good luck
File Type: pdf
Old 01-23-2017, 12:46 PM
6th Gear
Thanks TexasHonda
will let you know how it went
also do you have step 4 on pages 14-209. draining ATF through strainer.
Old 01-23-2017, 03:06 PM
TexasHonda's Avatar
That's just remove drain plug and drain through strainer/funnel.
You need a shop manual. check automanualsource.com for $22.
good luck
Old 03-03-2017, 12:13 PM
6th Gear
Good day
well I drained the transmission, tested to make sure I was getting the 12v correctly and I was.
But am still getting the same issues while driving. A drag or lagging when driving, can't go faster than 40mph sometimes, high rpm before the car knocks into a higher gear.
Should I get my transmission rebuild or just spend the money for a new transmission.
The technician who was working on my car said it may be a internal problem causing the fault code to keep popping up and driving conditions .
Anymore helpful tips??
Old 03-03-2017, 03:03 PM
RTM
RTM's Avatar
Originally Posted by islanddread0511
Good day
When you drained it, did you verify the solenoid was working correctly. Pull it out, 12V on, 12V off, and verify clean movement of the actuator?
Peak into the hole while it was out, and make sure no debris in the hole it came out of?
Old 03-07-2017, 05:07 PM
6th Gear
Yes I was getting the correct 12v on 12v off
actuator was free movement, and no debris was in the solenoid hole
so idk what the problem could be....maybe a sensor
because if am driving with a speed keep my rpm up to like 3000 I don't feel the drag
but when am driving slow and hit 20mph I get the drag, but once above 20mph and constant speed I don't feel anything
