2013 Model Transmission
Old 10-17-2016, 11:18 AM
chunkygoatmilk's Avatar
Just purchased the '13 TSX a month ago. When driving down steep hills or steady downhill, the transmission downshifts. Is this normal? I've never had an automatic do this before but again, the '13 TSX is the newest car I've ever purchased so I don't have anything comparable to compare it to. It was a little alarming at first but apart from the downhill drive, everything seems to be fine.
Thanks to all that reply.
Old 10-17-2016, 01:42 PM
RTM
RTM's Avatar
My 2012 does it if you are going downhill and hit the brakes. Never noticed if just coasting downhill
Sometimes it seems to hold the downshift too long
Old 10-17-2016, 02:00 PM
TSXV6Guy's Avatar
Honda call this "grade logic control". Is downshifts on downhills to benefit from engine braking.
Old 10-17-2016, 04:20 PM
Ok. So ultimately, this isn't likely a repair issue then, right?
Thanks.
Old 10-24-2016, 09:50 AM
wrayman's Avatar
As TSXV6 says, grade logic control. My TL auto did this as well, not an issue to worry about.
Cheers,Mike
Old 01-18-2017, 09:30 PM
EuroRspec's Avatar
This is completely normal. Most cars do this. The computer uses engine braking to help keep the speed in check and help the brakes. It actually helps MPG because it cuts fuel.
biker
Yesterday 09:02 PM
Ahmed Nomaw
07-20-2017 04:06 PM
Kolomango
3G MDX (2014-2020)
07-15-2016 08:55 PM
qwxilvr
5G TLX Problems & Fixes
05-07-2016 02:35 AM
Evilocity
04-22-2016 09:33 AM
Quick Reply: 2013 Model Transmission
