HOW TO: Clutch delay valve removal for 6spd owners
Old 01-29-2013, 10:20 PM
CU2 Dan's Avatar
Please move this post to appropriate section if needed.
Here's how to remove the annoying clutch delay valve from 2009-2013 TSX's.
Caution: I AM NOT RESPONSIBLE IF YOU DAMAGE YOUR CAR. DO THIS AT YOUR OWN RISK.
Like every other newer Honda's, they added the delay valve in the clutch slave cylinder so you can't pop the clutch for aggressive shifting. Ever since I removed this valve, I am now able to pop into gears a lot faster.
I purchased a brand new slave cylinder to show you guys how its done (also as a backup in case I break something)
The following 5 users liked this post by CU2 Dan:
Jaheri_cbp (02-06-2014), MC MiYoung3269 (01-30-2013), optimusaccord (01-30-2013), tsxronald (03-08-2013), ttk5 (01-30-2013)
Old 01-29-2013, 11:27 PM
SeeYou2Crew #2
ed_423's Avatar
nice DIY!
Old 01-30-2013, 03:37 AM
BaoZZeR's Avatar
Nice DIY. Might give it a try lol
Old 01-30-2013, 08:57 AM
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
Lol this is cool. I will prolly never do it though.
Bao, have fun ripping out the slave cylinder. That will be a PIA. If you're gunna hold on to the car until she dies, might as well wait until you absolutely have to replace it then tell your mechanic you already bought a new (your modified) slave cylinder and have him install it.
Old 01-30-2013, 09:02 AM
Received 16,260 Likes on 11,971 Posts
its not necessary to put back the valve retainer.
I didnt put it back in; when I did my slave cylinder mod.
Old 01-30-2013, 09:29 AM
optimusaccord's Avatar
I may look into buying a second slave cylinder to do this to. I thought the feel of the clutch was always off compared to the prior Honda's... never went looking for a fix.
Very cool.
Old 01-30-2013, 12:41 PM
Vancouver B.C.
ttk5's Avatar
Thats awesome. How hard is it to remove the slave cylinder and how much is a brand new piece? Thanks a lot for this DIY guide.
Old 01-30-2013, 12:46 PM
to remove slave cylinder; just take off the mounting bolts...
theres like 3.
the hardest part is taking the little C-ring out.
Be careful not to pop the C-ring out, as it WILL go flying.
I learned the hard way.
also, when re-installing the slave cylinder, you will have to bleed the clutch
Old 01-30-2013, 01:52 PM
Is there a special tool to remove the c clip?
Old 01-30-2013, 01:58 PM
^no.
Just like CU2 Dan, I used a tiny pick.
if digging and finessing isnt your thing, you could grind a little slit into the top and get the c-ring out that way.
Old 01-30-2013, 02:55 PM
MC MiYoung3269's Avatar
Received 1,000 Likes on 712 Posts
Or you could just drape a rag over it and pop it off while covering it so it doesn't fly away O_o
Old 01-30-2013, 03:00 PM
Emmanuel did his at my house.
after I told him about it flying away, he pointed it down to the ground as he was picking. sure enough, it went flying but we were able to see where it went.
I dont think the rag idea would work so much.
the C-ring is tiny. the tool/pick is tiny. you need to see and have steady fingers to finesse the ring out.
Old 01-30-2013, 05:31 PM
Euronoob's Avatar
I don't even know where this is located, anyone care to point it out please? And is bleeding the clutch afterwards a must?
Old 01-30-2013, 10:14 PM
CU2 Dan's Avatar
Euronoob (02-04-2013)
Old 01-30-2013, 10:53 PM
Position tool in place
Get butt buddy to drape rag over
Pop that molly off and start sweatin
Old 01-31-2013, 01:09 AM
vietkid_2006's Avatar
I suggest anyone to do this mod if you like to slam gears, remove the stupid valve and don't have to worry about replacing a clutch and flywheel...
Old 01-31-2013, 03:05 AM
BaoZZeR's Avatar
Is it necessary to apply that much honda bond? Do you think you can get away with just putting it around the c-ring and snapping it back in place. (Just in case you have to take it back apart for any reason)
Old 01-31-2013, 07:29 AM
^the honda bond was used just for a "preventative"
the TL guise dont bother with sealing it.
we just put the cap back on and its good to go!
Ive been check valve free for over 30k miles.
Old 01-31-2013, 09:58 AM
So, pulling that check valve thing will give a more "direct" feel to the clutch pedal correct??
Old 01-31-2013, 10:05 AM
the valve limits fluid when shifting.
without the valve in place, you're able to shift better, because there isnt anything limiting fluid travel.
Just a heads up; the valve is in place in order to limit SHOCK to drive train components. Or this is what the engineers tell us.
Old 01-31-2013, 10:51 AM
SeeYou2Crew #2
ed_423's Avatar
so valve in place = better for tranny components, but the feel of shifting decreases.
valve removed = better shifting (feel? or actually better shifting), but tranny might take a harsher useage
Old 01-31-2013, 10:57 AM
exactly.
Banging gears = shock to drive train components.
But this did not stop me from taking out the check valve.
Old 01-31-2013, 12:33 PM
Old honda slave cylinders did not look like that. I think after I get the project off the ground, I'm going to pick one up and modify it.... Maybe swap it out the same time I swap out the clutch and flywheel....
justnspace (01-31-2013)
Old 01-31-2013, 12:35 PM
that would be ideal since you're already in there and will and have to bleed clutch
Old 07-08-2013, 05:23 PM
BattleofXs's Avatar
Any long term reports?
Old 08-21-2013, 01:30 AM
#172CR's Avatar
I took the delay valve out of my s2000 transmission in the first few months. It now has 53,000 miles on it and is as good as the day I bought it...Long term effects? better enjoyment over the past 4 years.
Old 02-01-2014, 06:26 PM
tsxronald's Avatar
Someone needs to do this mod for me...lol I'll pay for it too..
Old 01-18-2016, 01:49 PM
avarela86's Avatar
Came across this link this is a common change in the AP2 to get rid of. Loaded this page on PC and phone and the HOW TO images do not appear. No luck using search so if anyone knows where there is another HOT TO please share!
Old 02-08-2016, 08:22 AM
I like cars.
Username 0's Avatar
Yeah what he said. The pictures aren't coming up. Can it be fixed? Pleaaaase.
Old 02-08-2016, 09:44 AM
avarela86's Avatar
I did a search and this link unfortunately not the same forum but same part should help out. It was even the same setup on my buddies V6 Accord. Hope it helps.
http://9thcivic.com/forum/threads/clutch-delay-valve-removal.8624/
Old 02-08-2016, 10:07 AM
I like cars.
Username 0's Avatar
I found the same link but I didn't want to post something from another forum. It's pretty much the same procedure if anyone is looking to do this on their manual cu2. I know I will, delays annoy me.
Old 02-08-2016, 10:13 AM
avarela86's Avatar
The way I see it, may be from another forum but it helps the community. :-)
The next thing I have to tackle after this mod is the darn rev hang. That makes driving the car a bit more complicated unless you drive grandpa style when you shift through the gears.
Old 02-08-2016, 10:57 AM
I like cars.
Username 0's Avatar
I got rid of my rev hang. Drives like a throttle cable now.
I think im going to put in a steel braided clutch line as well. Im sure it will compliment this mod nicely.
Old 02-08-2016, 11:10 AM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
https://acurazine.com/forums/perform...-valve-734300/
Old 02-08-2016, 12:00 PM
I like cars.
Username 0's Avatar
That guy had to grind his slave cylinder. sucks.
Old 02-08-2016, 01:03 PM
so did i...there are no adverse effects, just makes it easier to get the clip out.
Old 02-08-2016, 02:42 PM
avarela86's Avatar
I did two of them without grinding down anything. A little patience and the right tools!
How did you get rid of the Rev Hang?
Old 02-08-2016, 05:09 PM
Jaheri_cbp's Avatar
Ditto
Old 02-08-2016, 06:45 PM
i am a brute...no finesse!
Old 02-08-2016, 11:46 PM
I like cars.
Username 0's Avatar
With the hondata flashpro.
Quick Reply: HOW TO: Clutch delay valve removal for 6spd owners
