What happens if you remove the CD changer?
Old 02-15-2012, 10:46 AM
4th Gear
HighwayStar's Avatar
Hello, first post here. I'm trying to find just the right CPO TSX, and I'm on the fence about whether or not to be picky about the tech package. Aside from the cost, the only real reason not to want it is that I have absolutely no use for an in-dash CD changer, but would really prefer the storage cubby from a non-tech model. Aside from obviously not being able to play CDs, are there any other consequences to pulling the CD changer and replacing it with the cubby from a non-tech TSX? Is this even possible? Do you lose bluetooth or anything like that? I seem to recall reading that there is a DVD drive in the trunk for nav maps, but I can't just run out and check yet. I searched and could not find an answer. Thanks!
Old 02-15-2012, 11:27 AM
7# werC 2uoYeeS
mrstak's Avatar
Yes the dvd drive for the navi disc is in the trunk. Top right when looking into the trunk. Not sure about removing that part of the system...it's possible that you can take it out but it might be hard to do and it might throw some errors messages.
Old 02-20-2012, 12:42 AM
4th Gear
Thanks for the reply. Haven't narrowed it down to a specific car yet, but if I end up with a tech model, I think I'll give it a try.
Old 02-20-2012, 12:57 AM
Op is too busy to care
KillerG's Avatar
Probably wont be of much consequence, though you should subscribe to Hondatech for 3 days for the tsx service manual and check the teardown of the center console to see how hard it is to remove and if the parts look like they are swappable
side note: ...maybe remove the navigation screen and have two storage cubbies?
Old 02-20-2012, 07:29 AM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
Isn't the dvd used for software updates? Is it tied into the diagnostic loop like the Audi/BMW radios?
Old 02-20-2012, 02:07 PM
4th Gear
I'm fine with leaving the nav screen and DVD drive in the trunk. In fact, I'd love to hack the system so my passengers could watch videos on it while we're driving (via iPod video line in, which I'd the only way, AFAIK).
In researching the answer to this question, I saw a changer at a pick-a-part, and it had 4 or 5 plugs on the back, which makes me think there's more to it than a simple player. Whether or not the car's various systems will freak out when you start pulling those plugs is the question I have.
Old 04-07-2012, 12:59 PM
Membered Register
drivedata's Avatar
Any idea if the hondatech service manuals have breakdowns for the pinouts for the tech/non-tech wire harnesses?
Old 12-16-2016, 03:32 PM
brocksolid's Avatar
Was this completed? I'd also like to remove my cd player and replace with storage because my CD player is broken.
Old 02-15-2017, 02:52 PM
msharifi's Avatar
I thought the TSX doesn't have a dvd drive in the trunk but in the front and the disc copies to the hard drive is that only 2011-2014 only?
Old 08-03-2017, 01:58 PM
plumpduck's Avatar
I want to do the same exact thing. Any updates on this? 2011 sportwagen (with tech, obviously). And I can confirm that the 2011 stores CDs on the hard drive automatically.
Old 08-03-2017, 02:14 PM
msharifi's Avatar
2011-2014 tech has 60GB of hard drive and only 15GB for music the rest are for Nav. From what I was told when you insert the nav DVD it takes a while to download to the hard drive and if you insert a music CD you can have it set on auto record to drive/selected or just listen.
Old 08-08-2017, 04:42 PM
evo9's Avatar
The DVD drive unit below the HVAC control is the actual radio in the tech package vehicles. If you remove this unit non of the display will work. The sub display MIGHT still display the HVAC info.
Old 08-08-2017, 05:05 PM
plumpduck's Avatar
Thanks, Evo9. I confirmed this earlier today in this thread: https://acurazine.com/forums/2g-tsx-...player-961144/ Check out the wiring diagram.
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
CL-S progression 01
01-26-2016 04:15 PM
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
lowgrowl
09-26-2015 05:18 PM
Quick Reply: What happens if you remove the CD changer?
