The LED drl/hi beam setup we've been waiting for
Old 08-10-2013, 11:14 AM
JR_Rider's Avatar
Yesterday, a brand new set of 5K white 1800 lumen LED bulbs arrived from VLEDS. This setup replaces our drl/high beam bulbs. According to VLEDs, these bulbs put out 30% more light than the traditional halogen bulbs. Prior to these bulbs I had VLEDS 28 led tower and the output difference is like night and day. These new bulbs are insanely bright and at night time provide terrific illumination. I don't have any night time shots yet but will post some later on.
DRL
High Beam
The following 4 users liked this post by JR_Rider:
MC MiYoung3269 (09-02-2013), MrTee12 (08-19-2013), speedracer_2020 (08-11-2013), tsxronald (02-15-2014)
Old 08-10-2013, 11:25 AM
Graphite Ghost
robpp's Avatar
i see some kind of plug in BOX; was it PnP ?
mind sharing the part number from vleds.
Old 08-10-2013, 11:52 AM
JR_Rider's Avatar
The box is part of the setup but yes, it was plug and play. Very sime installation. The part ID is CXA.
Old 08-10-2013, 06:48 PM
niebur3's Avatar
Sorry for the off-topic question, but where did you get that grill?
Old 08-10-2013, 07:34 PM
JR_Rider's Avatar
Heeltoe Auto. I have the ATLP grille.
Old 08-11-2013, 12:44 AM
Skiroy's Avatar
Are those the 9005 or the H11? I asked if they threw a code when changing them out, but they hadn't tried them on our cars specifically. Very nice, and I'm looking to do the same soon.
Old 08-11-2013, 12:16 PM
Chenw87's Avatar
9005. H11 are for fog lights.
Old 08-11-2013, 04:18 PM
speedracer_2020's Avatar
Looks great man! How does the high beam perform at night vs the standard highbeam?
Old 08-11-2013, 04:43 PM
JR_Rider's Avatar
These are 9005 bulbs. I previously purchased a resistor from VLeds for my previous led bulbs b/c they threw a code. I didn't try and plug these up without the resistors since they were already there.
Old 08-12-2013, 03:36 PM
JR_Rider's Avatar
High beam puts out significantly more light than the standard halogen bulbs. I now have great visibility at night and the drls are almost bright enough to drive with by themselves.
speedracer_2020 (08-12-2013)
Old 08-12-2013, 05:22 PM
Thanks JR, that sounds fantastic. Love the setup on your car. My last last question for you is this: Do the operate like the standard bulbs out of the box -- meaning -- when I turn on my regular low beam headlights, the VLEDs go off?
Greatly appreciate your input.
Thanks again, great find man!
Old 08-12-2013, 06:04 PM
VortexBlueTSX's Avatar
Awesome! I know what i am getting next! Thanks for the right up man!
Old 08-13-2013, 07:50 AM
JR_Rider's Avatar
Yup, they function the same as the current drls. When you turn on the low beams they cut off.
No problema.
Here are some night time shots for your viewing pleasure....
DRLs at night.
Hi beams
The following 2 users liked this post by JR_Rider:
MC MiYoung3269 (09-02-2013), speedracer_2020 (08-13-2013)
Old 08-13-2013, 08:05 AM
Chenw87's Avatar
Wow. It looks great!
Old 08-13-2013, 08:27 AM
djhtsx's Avatar
what color is the output? I know you said 5000k but it looks like it has a hint of yellow.
Old 08-13-2013, 12:41 PM
Cu2Suspect's Avatar
Are these plug n play? And did u find out if they throw a code with the resistors?
Old 08-13-2013, 10:48 PM
JR_Rider's Avatar
This is the very first batch of these 2nd generation bulbs VLEDs has shipped. Originally these were supposed to be 6000k, but when the set came in, they reclassified them as 5000k. They are extremely white in color in person, no blue hue. I bought them to match my 5000k V3 triton switch backs but these aren't quite as white.
Yup, they are plug and play. Installation was a breeze, took maybe 10 minutes for both sides. They don't throw a code with the resistors. I will try them without the resistors and let you know if what happens.
Old 08-19-2013, 07:58 PM
Nukebug's Avatar
These look really good.... I am just surprised by how much they cost!
Old 08-20-2013, 04:00 PM
JR_Rider's Avatar
VLeds prices are always pretty steep but the quality is usually top notch and the performance is second to none....
Old 09-02-2013, 04:55 AM
Silvaccordex01's Avatar
I just put in a set of these, and didn't know that i would need resistors. These will throw a code without them.
JR_Rider did you get the 9005 resistor kit from V-Leds? I've been reading a few other threads and some people say you need a relay as well, not just the resistor v-leds sells.
Old 09-02-2013, 10:14 PM
JR_Rider's Avatar
Yes, I purchased my resistors from V-Leds but about a year ago, when I purchased my old tower bulbs. You can purchase the correct resistor from autolumination for half the price of the V-Led resistor. I think I paid $20 for mine. As far as a relay, there's no need for anything else other than the resistor and what's included in the bulb setup from V-Leds.
Old 09-06-2013, 01:39 PM
Graphite Ghost
robpp's Avatar
Angry
Can you be more specific on the resistors....maybe link to vleds or autolumination
Old 09-08-2013, 05:07 PM
JR_Rider's Avatar
Sure. http://www.vleds.com/turn-signal-resistors.html
LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX | 1 PAIR
robpp (09-09-2013)
Old 09-08-2013, 06:35 PM
Op is too busy to care
KillerG's Avatar
hey JR, im gonna try to get my switchbacks replaced for the gen2, what did you mention to them was the issue with them? I havent even used mine but id like to make sure i have a set before i through with the install since it will probably be a pain in the ass
ordered a set of these as well
Old 09-09-2013, 11:03 AM
Graphite Ghost
robpp's Avatar
These say turn signal but they worked on your DRL/HI ?
Last question 3 or 6 ohm?
Old 09-10-2013, 02:15 PM
Mryank9's Avatar
also want to know the answer to this
Old 09-10-2013, 08:13 PM
JR_Rider's Avatar
Just tell them the bulbs go in and out intermittently. They are well aware of all the issues with the gen 1s. They will have you purchase the gen 2s and return the gen 1s.
Old 09-10-2013, 08:18 PM
JR_Rider's Avatar
I couldn't find any order info from VLEDs on the resistors so I will check what's written on them tomorrow.
robpp (09-11-2013)
Old 09-15-2013, 11:11 AM
JR_Rider's Avatar
Sorry for taking so long to figure this out. I couldn't find an order thru VLEDs but I remembered they were sold out at the time so I just purchased these off ebay. They are 100W 6 ohm load equalizers with the 9005 plug. They can be purchased from ebay or here from VLEDs http://www.vleds.com/resistors/in-li...05-1-pair.html
robpp (09-15-2013)
Old 09-20-2013, 10:05 AM
Graphite Ghost
robpp's Avatar
THESE ARE BRIGHT.....
Install is a bit difficult in that the resistors get smoking hot.
Old 09-20-2013, 12:09 PM
KillerG's Avatar
mine are on the way ^_^ will report back shortly. not sure what resistors from ebay i have lol. thanks for the helo JR. i have gen2s on backorder as well
Old 09-20-2013, 01:15 PM
Graphite Ghost
robpp's Avatar
You need a 6 ohm for each side.
Agreed....THX JR
Old 09-20-2013, 02:40 PM
Hey Robpp, do you have pictures of the light setup on your car (exterior)?
Old 09-20-2013, 05:25 PM
Graphite Ghost
robpp's Avatar
Pics with lights on?
I will get some.
Also some pics of resistor placement.
Old 09-23-2013, 11:58 AM
Graphite Ghost
robpp's Avatar
pass side resistor
used a open threaded hole with allen head bolt.
drivers side.....i used a plastic rivet to mount it to rad support open hole........when i get a few minutes i will pull out battery and mount it to the plastic thing in front of the battery.
here is a shot of the rear of the bulb installed, thats the fan sticking off the end.
color match DRL with 5K LED fogs
DRL: whats different is that these ONLY have 2 leds and they project towards the reflector. when you look dead on, just drls, you can see a black sopt in the center. once you out the HB on that goes away due to brightness.
to show the brightness i took some shots out of my garage. the houses across the street are a good 80-100 feet from the front of my car.
DRL only
low beam no DRL
add LED high beams.......
the resistors i had from my JLC kit are 10ohm per side. vleds sells PNP 6ohm. i had some vleds with the plates and also the covers and used 6ohm since thats what I had to mount on the plate.
if you can do wiring you could make a small order from autolumination and buy all you need to make it PNP. or you can order them from vleds for 18 bucks for the pair.
and the drivers side will be moved to the plastic battery box shortly.
work facebook for coupons from vleds. most holidays get 20%. mine was from labor day coupon.
Old 09-26-2013, 03:00 PM
kickarsmann's Avatar
These look fantastic! Thanks for the info guys. I'm thinking of doing this setup for my 09 TL to replace my fog lights. Would I need any resistors or simply plug and play?
Thanks in advance!
Old 09-26-2013, 03:45 PM
Graphite Ghost
robpp's Avatar
The resistors make sure the bulb out warning does not come up......the lights will work without the resistors but will give the bulb out warnings.
Old 09-26-2013, 05:21 PM
JR_Rider's Avatar
Thanks in advance!
For fog lights I would go with tradition
Hids if I were you. They are cheaper and have a much higher lumen output.
Old 09-27-2013, 02:08 PM
Thanks JR!
I thought about HID's for fogs but its too bright in my opinion and seems like everyone here already has them in their cheap civics. I want to match something similar to my low beams and I'm sure everyone knows that fog lights don't really do anything, I think its mostly for aesthetics.
Regular halogens produce about 800-1000 lumens and these LED's produce about 1800 which is perfectly suited for my taste. Just want to see what I need to buy in order to make it work.
Old 09-27-2013, 03:04 PM
One last thing I forgot. Are these bigger than the OEM bulbs? Do I need to retrofit the housing or will it fit without modification?
Quick Reply: The LED drl/hi beam setup we've been waiting for
