Both Front Passenger Window and Sunroof will not respond to ANY controls.
This above issue appeared at the same time. The Front Driver's Window also has some issues when I try to send auto up/auto down.
Have you checked your fuses?
Also what car do you have? Your user name and the subforum in which you've posted does not match.
thoiboi,
Sorry for the confusion. I'm a Newbie. I have a 2011 TSX 4 Cyl w/Tech Package. I have not done any trouble shooting as of yet. Just trying to gather some info first.
Gotcha,
we'll have it moved to the TSX forum. But it's going to be one of your fuses if i had to venture a guess. Check them all
2011TSXer (02-22-2017)
oo7spy (02-22-2017)
Hello, this is my first post! I just had a similar issue both front windows not working rears were fine. Didn't try the sun roof.. Anyways I was working on the car and the battery had run down to 10 volts. As soon as I put a charger on the windows all worked.
See if your battery is dying, or try them with the car running, if you haven't already.
