I can't find a base amp harness adapter...
Old 02-11-2012, 12:16 AM
9th Gear
wife's ride's Avatar
I've been scouring the net and google for two days looking for a harness that plugs into the amplifier output so i don't have to cut any wires. This is so I can install my line level converter. It has 8 channels.
Later, I will need a harness for the amp input because when i source an Audiocontrol DQXS, it will replace my converter and crossover.
But I can't find either harness. I don't want to run wire from all the speaker locations back to the trunk. Can you guys help?
2010 TSX base w/o navi.
Old 02-18-2012, 09:36 PM
ShawnAmin
shawnamin's Avatar
use a t-tap to tap into the speakers, i wouldnt try to plug directly into the stock amp. it looks like this http://www.700r4.com/tech/tcc/towing...stall_1_bg.jpg
AndrewS
19
03-14-2024 06:59 PM
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
Quick Reply: I can't find a base amp harness adapter...
