2012 TSX Tech Bluetooth Module Location
Hey everyone.
I'd like to know where I can find the Bluetooth module for my 2012 TSX. It's starting to "crackle" and randomly disconnect more frequently and from what I read, a simple disconnect / cleaning / reconnect generally does the trick.
If you have any other BT related input I'm all ears as well.
Thanks in advance!
Jeff
Thanks in advance!
Jeff
It is under the glove compartment but you may try this first:
https://acurazine.com/forums/2g-tsx-...-ios10-954822/
Dude!! So far your fix worked! You likely saved me a ton of hassle.... I appreciate it!!
xtcnrice (02-16-2017)
https://acurazine.com/forums/2g-tsx-...ra-tsx-948724/
Like, comment and subscribe!
Welp, it's doing it again. I think the next step is to remove it, ensure connections are tight, etc. Or replace. I'm getting conflicting info online - is the replacement part 39770-TL2-A010 ?
xtcnrice (04-25-2017)
