2010 tsx stock tail light LED retrofit project
Old 11-16-2016, 07:53 PM
2snail's Avatar
Hello fellow aziners.
I have been toying with the idea of retrofitting the stock tail lights to use some LED's. While i am well aware of the spirior tails I like the look of the stock tails. my idea is to add some LED modules to the inner tails that mount to the trunk lid. I have attached a picture of the proposed area where i would like to add the LED modules.
These modules are backlit led and use an acrylic to diffuse the light evenly. I have measured the dimensions of the 4 recess slots marked in green and the module i found fits. I went ahead and ordered a set of inner tail assemblies from aliexpress and some modules. If i can open up these tails i can have a better idea of mounting them in.
Ill post more as i get progress on the project. So far this project isnt too pricey:
100 for the inner tails pair.
25 for the led modules
6 for the resistors.
Attached Thumbnails 2010 tsx stock tail light LED retrofit project-tail-light-retro.jpg   2010 tsx stock tail light LED retrofit project-backlight.jpg
The following 3 users liked this post by 2snail:
justnspace (11-17-2016), ssjoeboe9 (11-17-2016), xtcnrice (11-17-2016)
Old 11-17-2016, 12:46 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Good luck!
I love reading these types of diy. It's cool to see people take initiative and try something new. Even if you fail, you'll learn something from it.
Old 11-30-2016, 08:26 AM
2snail's Avatar
Status update,
I have received the LED modules and I should be receiving the light assemblies any day according to the tracking info.
Ill try and post up a youtube video once i get the remaining parts in.
Also I realized my circuit had a critical flaw. I was relying on reducing the 12-14v dc voltage from the tail light harness using some resistors which would be prone to failure due to heat. Instead I plan to utilize a DC/DC voltage regulator which uses a potentiometer to adjust the output voltage. The units I found are waterproof and utilize a heatsink on the casing. These can be mounted to the inside of the trunk lid.
VR1 (11-30-2016)
Old 12-05-2016, 08:35 PM
Acura Fanboy
knavekid's Avatar
Depending on the forward voltage of the LEDs, consider connecting them in series. The light output is generally proportional to current, not voltage, so a series connection will have them all be the same brightness. If this requires a voltage higher than 12V, you should be able to find a boost switching regulator. Good luck with your project.
Old 12-08-2016, 02:02 PM
2snail's Avatar
attached a video update.
Old 12-22-2016, 07:03 PM
2snail's Avatar
Update part 2,
tsxronald (02-23-2017)
Old 12-23-2016, 09:46 AM
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
How yellow do they look in real life?
Old 12-23-2016, 01:16 PM
2snail's Avatar
They look red orange, the camera makes them look more orange
ssjoeboe9 (12-23-2016)
Old 01-01-2017, 06:36 PM
2snail's Avatar
Final update, the project was a success. The DC dc converters I bought on amazon were a complete failure. Under testing the capacitor on the converter exploded. Luckily nothing hit me.
I originally was going to run both inner tails as a string of 4 leds with the parking lights and utilize the boost converter to push 14v from 12v.
I decided to avoid that when I discovered that I could tap into the license plate lights on each side. I tested the voltage with my multimeter and under Rpm load, ignition off with just parking light, and startup, the voltage never passed 13.8.
Also i tapped into the center brake light under the rear deck and ran both strings of leds for my brake signals.
I believe the multiplex unit regulates the voltage for each set of lights.
Finally here the pictures
I ran a 470ohm resistor to each string of 2 leds and everything is working. They are rated for 1w.
I sealed up the taillights by melting the top and bottom edges back together. The sides were too difficult so I ran a bead of ge silicone. I have used it before for my fogs lights and it worked well. I ran an additional bead along the top and bottom.
Finally here are the pictures.
Attached Thumbnails 2010 tsx stock tail light LED retrofit project-20170101_174448.jpg   2010 tsx stock tail light LED retrofit project-20170101_182206.jpg   2010 tsx stock tail light LED retrofit project-20170101_182329.jpg   2010 tsx stock tail light LED retrofit project-20170101_115535.jpg   2010 tsx stock tail light LED retrofit project-20170101_115457.jpg
Lewal (01-24-2017), ssjoeboe9 (01-03-2017), tsxronald (02-23-2017)
Old 01-01-2017, 07:03 PM
cu2wagon's Avatar
Looks nice!
I noticed the Texas plates. I'm not sure if I forgot or don't know... Where are you?
Old 01-01-2017, 07:13 PM
2snail's Avatar
Houston, just north of the heights.
shwanC92
10-12-2016 10:59 AM
knice
03-20-2016 08:45 PM
vpasla1
01-14-2016 07:47 PM
Quick Reply: 2010 tsx stock tail light LED retrofit project
