Rim and tire size question
I have a 2000 acura Tl, I have recently purchased a set of ASA by BBS 18" in rims I have bought tires of size 225/45/18, will I have any problems?
Scroll down until you find the specs you wrote above...looks to be ok if stock set up...but offset could be an issue? I'm not the one to ask about that but the DIY on will they fit should help.
XXR551 wheels
I'm looking to get xxr551 wheels 17X8.25 +36mm offset, will this fit my 2001 acura tl? could i use wheel spacers to get proper offset or will that set me to far out past the fenders?
That's the recommended size but it's all based down to what your needs are and what the car is used for. My 03 Tl is 205/60r16 but I use a 215/45r17 because wanted more grip and responsiveness with the wider tired all around and have a comfortable ride with a small side wall for the sporty look I wanted. I can't say your going to have any problems but the tires your using.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
