Need Advice: Is it really bad to run 60 degree lugs with stock tsx wheels?
Old 03-23-2012, 06:03 PM
floored4door's Avatar
Just picked up some black oem wheels for my TL from a TSX. Was looking to do a different color lug for the fun of it. Is it really a bad idea to do a 60 degree seat over the ball seat. I've looked all over for the ball seat in the color I want with little luck. Any help is greatly appreciated...
Old 03-23-2012, 11:24 PM
-Arsenic-
02type-s's Avatar
Not unless you use these:
http://www.vwparts.net/MB9508.html
Or your conical lugs will end up looking like this
They do not seat the OEM wheels properly, so without the adapters, yes its unsafe.
Old 03-24-2012, 10:53 AM
Flagship Aspec
tc5280's Avatar
Wish I would have known about these a long time ago, I have some bad ass open ended ones I wanted to use with the aspecs. They made that same wear mark that I wasn't comfortable with.
Do those adapters really work? I have never heard of them
Old 03-24-2012, 01:51 PM
You sir are the shit! I wondered if they made an adapter...
Old 03-24-2012, 01:55 PM
Flagship Aspec
tc5280's Avatar
Right! Already ordered some.
Old 03-25-2012, 12:23 AM
-Arsenic-
02type-s's Avatar
The VW crowd seems to like them
Old 03-27-2012, 12:21 AM
supapoopa's Avatar
Thank you 02type-s. That is exactly what I have been looking for so I can run my old spline drive lugs.
Old 03-27-2012, 12:49 AM
-Arsenic-
02type-s's Avatar
Old 04-07-2012, 10:14 AM
Flagship Aspec
tc5280's Avatar
Not sure if I am a fan of these, maybe it is the lugs I am trying to use. the first time I torqued them down they did not center to the lug to they made weird grooves in the "adapters". I lightly epoxied them straight though and they have not lost torque in 100 miles, so purpose wise great but use is a bit strange.
p.s.
my lugs do not have that small "shoulder" i guess right above the pitch, it just goes from angle to shaft of the lug
Old 04-07-2012, 04:35 PM
2G TLX-S
Edward'TLS's Avatar
Received 1,133 Likes on 813 Posts
OEM Honda/Acura rims must use ball-seat type lug nuts.
Ruining a set of aftermarket lug nuts is nothing when compared to ruining a set of OEM rims by destroying the lug nut seat areas.
02-25-2020 09:57 AM
lland
10-04-2015 04:47 PM
BlueAquarian
09-10-2015 02:18 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Need Advice: Is it really bad to run 60 degree lugs with stock tsx wheels?
