-- FAQ: wheel rim size "will they fit?" --
Old 06-18-2007, 01:43 PM
  #241
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Originally Posted by Gfaze
I'm interested in some rims I found on Tirerack. Would these specs be ok? Just want to make sure before I do anything.
Offset: +42mm
Bolt Pattern: 5-114
Rec. Tire Size:225/45-18
Your definitely going to have to trim bumper tabs. If lowered you will probably run into some rubbing
Old 06-18-2007, 02:38 PM
  #242
'12 & '13 AL West Champs!
Gfaze's Avatar
What if I went with a different tire size? Any recommendations? I do want to stay close to original diameter specs to avoid speedometer/odometer accuracy issues. I'm not planning on lowering the car. If I change my mind though, it would probably be only an inch. Thanks for the help.
Old 07-06-2007, 05:14 PM
  #243
Nosb18c's Avatar
I am willing to cut my tabs out and roll the fenders will this fit.
18x8.5+45 114.3 5h 18x9.5+45 114.3 5h
Old 07-11-2007, 09:52 PM
  #244
derrick's Avatar
9.5" rim is impossible fit without crazy negative camber for it to "tuck" in. You'll need custom fender widebody work for a 9.5" rim to fit. Try and find a different set of rims would be my advice.
You may also need hubcentric rings since it's "H" bolt pattern and ours is a "J" ... I don't know what the difference is to be honest with you.
Old 07-15-2007, 04:56 AM
  #245
New Project 02 IS300
UA5 Crazy's Avatar
Quick Question
Will a 19 X 8.5 rim with a +35 offset work on A 2nd gen?
Old 07-15-2007, 10:04 AM
  #246
fsttyms1's Avatar
No
Old 07-25-2007, 05:12 PM
  #247
DBpdx
deandre03's Avatar
Will 235/40/19 8.0 fit 03TL no type s?
Will it fit and does anyone have any pics? Not lowered and I honestly don't want too. If I did H-tech maybe?
offset of +42 right?
First TL.....2003 3.2TL Nav, no type s, Tan Leather, Sub, 6indash, 43k, wood grain, Blue
mods so far:
20% charcol all around.
Old 07-25-2007, 05:26 PM
  #248
nuahs's Avatar
mods so far:
well i have the same size but in 18's and had to cut the tabs on the back they were just a bit too wide when i hit bumps or took corners
Old 07-25-2007, 05:28 PM
  #249
fsttyms1's Avatar
mods so far:
offset to low, especially with that size tire. Try to find a wheel with a higher offset
Old 07-26-2007, 09:10 AM
  #250
UTacuraTL's Avatar
I am looking at 18x7.5 5-114 with a +45 for a 2000 TL-P.
This should work right?
Will this make the wheels appear to sit flush with the front and rear fenders, or will they sit slightly inside like most stock wheels?
Old 07-26-2007, 09:21 AM
  #251
fsttyms1's Avatar
that should work. You may need to trim your rear bumper tabs.
Old 07-26-2007, 11:57 AM
  #252
UTacuraTL's Avatar
okay thanks!
Old 07-26-2007, 11:01 PM
  #253
T-Swzy
Razzi's Avatar
kind of off topic, kinda on. just quick question about tires, i know that they come in sizes, but i dont get the middle number, what is that all about? 225 (width)/45 (?)/ 18(diameter)...it's not offset is it? O.o
Old 07-27-2007, 01:30 PM
  #254
T-Swzy
Razzi's Avatar
sorry about double posting, i dont know why it wont let me edit my post.
ayways, i found out what that number means "This number refers to the height of the sidewall, or the Aspect Ratio. It is a percentage of the section width. In this example, you would take 65 percent of 205 millimeters and this would give you the sidewall height."
so anyone know what i should be looking for if i want 225 width and 18 diameter?
Old 07-31-2007, 04:48 PM
  #255
4th Gear
decazoo's Avatar
i went to a shop today to see the price of the tenzo-r gt5(1000$/set) and the guy was looking for a set of tire 225/45-18 for my car 3.2tl 2003. Should it be 225/35-18, because I saw everyone here got thatin 35!?!?!?
Old 07-31-2007, 05:44 PM
  #256
fsttyms1's Avatar
the middle number is a aspect ratio of the first number (sidewall height)
Old 07-31-2007, 05:45 PM
  #257
fsttyms1's Avatar
40 or 45 is the correct size for a 225 width tire on a 18
Old 08-01-2007, 01:48 PM
  #258
DBpdx
deandre03's Avatar
Will They Fit??? 03 TL (No S)
I have read all the posts about what can, should, and what will maybe fit. I just want to know what exactly will happen if I get 18x8 +40offset w/ 225/40/18? Will this rub? Will this stick out of the fender? Would cutting tabs resolve any issues I might have?
I found a brand new set someone bought off ebay and found it to be wrong for their vw. New chrome, tires still with stickers.......625.00?
Also, what springs would make this work? H-tech?
Old 08-01-2007, 02:01 PM
  #259
fsttyms1's Avatar
They will rub and stick out
Old 08-01-2007, 02:16 PM
  #260
DBpdx
deandre03's Avatar
I will take your advise but just one question......shouldn't it or is is false advertisement for Chrome Elements to print on their wheel application guide the 99-03TL? The size is 18x8 +40 and their chart says 99-03 TL....So this false? even though it's printed?
Thanks for the help by the way
Old 08-01-2007, 04:53 PM
  #261
fsttyms1's Avatar
not really. Technically they "fit" on the car. They will bolt right up no problem. But they will rub, especially when lowered. Most dont realize that the Tl requires a really high offset.
Old 08-02-2007, 01:25 PM
  #262
BaByBlAcKtYpE-s's Avatar
just wondering if these would fit?
18x7.5 offset says fwd
tires are: 215/40/18
i think it does but not sure and not planning on lowering
Old 08-02-2007, 05:28 PM
  #263
fsttyms1's Avatar
Offset needs to be a # before we can tell you if it will fit
Old 08-02-2007, 08:05 PM
  #264
chiarlei's Avatar
I had the same EXACT set up, I ended up selling them, they stuck out to far, and slung mud, dust, rocks, road crap/whatever all down the side of my car constantly. Everytime anyone was in the backseat and I hit a small bump or dip in the road it would chew up my tires. Believe me, use the offset that these guys recommend, they know what they are talking about.
Old 08-03-2007, 12:58 AM
  #265
ok thank u much
Old 08-03-2007, 01:09 AM
  #266
ok so i looked for something else and what about this
rim:
18X7.5 - 5x100/114.3 - 45
tire:
225-40-18 - H - 420
it sounds like it fits will this stick out though???
sorry for all the dumb questions just dont wanna waste money getting some rims that dont fit this is my first car and spent a year and half looking for a good 03 tl-s this was my first and only choice of car
Old 08-03-2007, 09:35 AM
  #267
fsttyms1's Avatar
thats better. You still may need to trim the rear bumper tabs but you should be ok.
Old 08-03-2007, 11:07 PM
  #268
ok thank you very much they wont stick out rite
Old 08-15-2007, 04:58 PM
  #269
DBpdx
deandre03's Avatar
Will 19x7.5 +48 work? If anyone is on and knows, please let me know quick because I am meeting the guy to buy them, or not buy them, in a hour and a half.
Also, will this look bad? I don't really want to lower it, but will I need to? Approx how big will the gap be?
I have a '03 TL, navi, 20% tint. Thats all so far, I bought it 3 weeks ago. 15,900 with 42,500 on the motor.
What springs, if any?
HTech?
Old 08-15-2007, 05:54 PM
  #270
fsttyms1's Avatar
Yes that will fit. The gap should be NO different that the gap you have now (granted the tire size is the correct size)
Old 08-24-2007, 09:29 PM
  #271
yosarian's Avatar
Swapping my 2nd gen OEM for TSX OEM?
I am planning on upgrading my stock 16" OEM rims to 17" rims when I get new tires in a few weeks. I was thinking of getting some 17" TSX OEM rims.
After reading through the posts explaining the numbers, I still cannot make heads or tails of it, so I hope someone can help me out. I have not and do not plan on lowering my car, so I don't think the issues of rubbing will come up with my TL.
The spec on the TSX rims are as follows:
Specification ..Sidewall ..Radius ..Diameter ..Circumference ..Revs/Mile ..Difference
215/50-17 .....4.2in .......12.7in ....25.5in ......80.0in ..............792 ..........0.0%
Old 08-24-2007, 11:20 PM
  #272
fsttyms1's Avatar
None of those specs are what we really look for. We look for rim width and offset. BUT the TSX wheel fits no problem
Old 08-25-2007, 12:16 AM
  #273
yosarian's Avatar
Great, thanks. Now to find some clean ones cheap.
Old 08-31-2007, 01:46 AM
  #274
Kang Ho
SupaRookie's Avatar
Looking at some used rims. If I get 17x7 +43, what tire size should I get for optimal performance? I dont plan on dropping (at least anytime soon...)
Old 09-02-2007, 12:21 AM
  #275
Broke college grad
BlackuraTL's Avatar
18"x7.5 with 225/40/18 tires and offset is umm well I dont see it but heres the link if anybody doesn't mind taking a peek.
http://www.victoriatire.com/wheels.h...=18&&pkg_tire=[PKGTIRE]&cart=11513235994668324&brand=GT&PICNUM=3803b&&che ckAvailable=F&name=GT%201%20BLACK&make=ACURA&model =TL%203.2%2099-03&size=18
But do they fit is my question.
Old 09-02-2007, 12:22 AM
  #276
Broke college grad
BlackuraTL's Avatar
http://www.victoriatire.com/wheels....e=18&&pkg_tire=[PKGTIRE]&cart=11513235994668324&brand=GT&PICNUM=3803b&&che ckAvailable=F&name=GT%201%20BLACK&make=ACURA&model =TL%203.2%2099-03&size=18
Old 09-02-2007, 11:00 AM
  #277
5th Gear
skhangwp's Avatar
Volks LE37 18X7.5 Offset 40mm 5X114.3
Help guys!!! For sale is some Volks LE37 18X7.5 Offset 40mm 5X114.3 for $1000. Now my question is... Is there any way to make this fit my 03 Type-S?
Got about one inch gap from wheel to fender right now with my stocks. I know, I've read all the above stuff, but is there anybody out there that has been able to make this work. I don't want to pass up on these rims, but don't want it if it won't fit.
Would it possibly fit if I went with some 225/35/18 tires? and maybe with some Tokico gas shocks?
Please help... any help is greatly appreciated.
Old 09-02-2007, 05:07 PM
  #278
Broke college grad
BlackuraTL's Avatar
18X7.5 5X100 48MM OFFSET
18X7.5 5X114.3 48MM OFFSET
18X7.5 5X114.3 38MM OFFSET
18X7.5 5X100 38MM OFFSET
18X7.5 4X100 38MM OFFSET
The site gives me the option of these also comes in 18x8.5 but I think thats too big, tell me if I am wrong. But out of these which one is my best bet?
From what I've read it looks like one of these are going to be it.
Just wanted to get an expert opinion thanks.
Old 09-04-2007, 09:34 PM
  #279
B A N N E D
VeEzy's Avatar
not an acura but can someone tell me if some Enkei J10s 18x7.5 38mm offset w 225/40 fit on a lowered (2 finger gap) 99 honda accord? thanks
Old 09-05-2007, 03:18 PM
  #280
calvin_m19's Avatar
HEY !!! NEED SOME opinions .... um i went on this site put in all the info for what kinda car is mine 1999 Acura TL 3.2 and chose to see the collection of black rims they got - i like these ... http://www.discountedwheelwarehouse....ShowLarge=True - wat u guys think this will fit or 8.5 too much?
Quick Reply: -- FAQ: wheel rim size "will they fit?" --
