Where is the Speed Sensor located
Skeet Skeet Skeet
I have this diagram but i can really see exactly where it goes if anyone is familar with this let me know
[IMG][/IMG]
[IMG][/IMG]
I wanna say its part of #10. has to do with the speed sensitive steering
Skeet Skeet Skeet
its actually buy the power steering pump, not attached to the tranny
Hummm does pressure spin it?? i need to look into this more. (maybe someone with a helms wanna chime in)
its not attached to the tranny at all other than the 2 tranny coolant lines.
Originally Posted by honda_inspire99
still cant find it
Where this is?
drivers side close to the firewall not on the tranny. its near teh imput shaft on the ps rack. Ill try to take a pic of it in the AM for you since i have my tranny out
Skeet Skeet Skeet
Ok looks like i stand corected. I dont know what i was thinking when i said not on the tranny. It is on the tranny right in back where the half shafts go into it. Only thing is is this is confusing me now, is there are NO electrical conectors going to the part. (there isnt a conection like on top of the one shown) so there must be something else??
Skeet Skeet Skeet
[IMG][/IMG]
i got this diagram from a freind at the dealership so i'ma chekc on the powersteering rack itself tomarow or u could just look at yours and see if its on there for me
Those rubber hoses connect to the power steering. but i dont see any where near the output area any electrical conectors
Skeet Skeet Skeet
The 3rd pic down, the 2 sensors on top are the 2 closest sensors to the out put area. not sure what they are for though
If your car has Navi, it has the electrical sensor on it....it has something to do with tracking the speed of the car against gps....I just replace the unit on my car....if you don't have navi you don't have it...
Also, I have no clue why it goes through the ECM....but the plug melted on mine causing the fuse to blow to the ECM and putting the transmission in failmode....with a flashing D4 which made it take off in fourth gear...
Actually if the op was wondering where the vehicle speed sensor was located, then that is the magnetic pickup assembly on top of the trans near the end cover. I believe you have to take the battery tray off for easier access. The sensor reads the turning output of the secondary shaft and sends it back to the ecm, then the ecm sends it to the instrument panel.
