Water leaks
Old 03-26-2012, 08:20 PM
8th Gear
Wildwildwes's Avatar
Water leaks
I was wondering if there are any 3.2 TL owners who have experienced trunk leak problems & water leak around the driver side carpet area. I cant seem to pinpoint the problem but I have replaced my taillights with new gaskets & nothing. I checked the trunk seal lining but it doesnt seem to have any cracks. Could it possibly be drain pipes? & by the way, I find water in the spare tire pit area & the carpet of the trunk.
Old 03-27-2012, 11:17 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
yes,,sounds like the drain tubes are clogged
dont forget the door and sunroof ones while you are fixing the problem
Old 03-27-2012, 11:58 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Driver side floor leak i have had (passenger side as well)
On the floor under the carpet, There is a rectangular plug (next to the round one) UNDER the sound material that is sprayed on. I had both sides leaking. The rubber-ish material just pealed away with a putty knife, then i just used some silicone on the plastic cap to seal it and when dried i sprayed rubber undercoating to cover the area
Wildwildwes (03-28-2012)
Old 03-28-2012, 12:58 PM
8th Gear
Thanks man, I'll try that then.
Old 03-28-2012, 01:01 PM
8th Gear
I ripped apart my trunk & then threw water over from above the car and down to the trunk and found water sneaking through a plug below the left taillight, inside the trunk. It goes right down to the pit area too. It looks like it needs to be sealed or replaced
Mike734
12-10-2021 01:25 PM
IBankMouse
06-13-2020 12:53 PM
Avenger411
10-11-2015 03:53 PM
steve
09-30-2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: Water leaks
