replacing rack and pinion - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 07-15-2010, 11:12 AM   #1
Registered Member
hey guys im new to the forum. really glad to find it! i was wondering if anyone has replaced their own rack and pinion without a lift. is it possible? how many hours? i need to swap mine asap but dont have the 700+ for the shop to throw at it right now. thanks guys
SKYWALKER9 is offline   Reply With Quote
Old 07-15-2010, 08:44 PM   #2
bringin lead
FirePR2002's Avatar
i did my dakota r/t a couple months back on jack stands, but it sits significantly higher than the TL. it would be tight - get it as high in the air as you can, but it is possible.
FirePR2002 is offline   Reply With Quote
Old 07-15-2010, 08:46 PM   #3
bringin lead
FirePR2002's Avatar
took about 3 hours to remove old, install new, install new tie rod ends. another 30 -45 to fill and bleed the system. this was my first time ever doing he job, so it could be done much quicker.
Old 07-15-2010, 09:43 PM   #4
Registered Member
thanks for the reply man. ill get it on the jackstands in the am hopefully ill get the old one off tomorrow and wait for parts to arrive. thanks alot
Old 07-15-2010, 10:36 PM   #5
fsttyms1's Avatar
I have pulled mine off before with nothing other than a set of jackstands. Its not terribly hard to do on the TL.
fsttyms1 is offline   Reply With Quote
The Following User Says Thank You to fsttyms1 For This Useful Post:
Vincent Rossi (10-20-2012)
Old 07-15-2010, 10:49 PM   #6
fsttyms1's Avatar
Old 07-15-2010, 10:50 PM   #7
fsttyms1's Avatar
Hope that helps
Old 07-16-2010, 12:09 AM   #8
Registered Member
thanks for the step by step. im feeling a lot more confident now for sure when it says remove the steering wheel does that mean from the rod of removing the whole unite out thru the fire wall? not sure if that makes sense... do i have to disconnect the airbag when doing this? thanks for all the help guys
Old 07-16-2010, 01:46 PM   #9
fsttyms1's Avatar
You dont have to remove the steering colum/wheel but it makes assembly and removal easier. I didnt, and just worked around it. And make sure to DISCONNECT the battery first so there is no possibility of setting the air bag off
Old 07-16-2010, 04:47 PM   #10
Registered Member
so i followed all the directions.. pretty straight forward untill u get to actually removing the POS from the car. ive pulled twisted cursed took a break cursed and twisted some more but no go. this thing will not come out. there seems to be a large piece at the top that will not allow the rack to come out. im about ready to use a hand grenade if i dont get it out soon. any ideas? theres a piece of metal blocking the whole thing from dropping out but theres no directions to remove it. i think its part of the frame.... so ready to be done!
Old 07-16-2010, 07:13 PM   #11
Registered Member
ah i took a break and some how i missed a step.. no problem everythings taken care of. thanks for the help fsttyms1
Old 07-16-2010, 09:40 PM   #12
fsttyms1's Avatar
Old 05-18-2015, 04:31 PM   #13
New Member
05 TSX rack removal, trick?
Quote:
Originally Posted by fsttyms1 View Post
I hope this message works. From long ago, you responded to Skywalker9 who was struggling to get his rack-and-pinion assembly out of the chassis. You responded back on 07-16-2010, 08:40 PM acurazine.com/forums/problems-fixes-117/replacing-rack-pinion-783790/.
I'm having the same problem. I have a 2005 TSX and followed a long sequence of steps to loosen the power steering rack-and-pinion (that leaks like a sieve now). The bolts are out, rubber freed up, lines are disconnected, and I can see down the tube and all along it. I can shift the rack a little bit but can't get it out. But there's a (welded?) brace on top of one of the bolts along the steering box that isn't mentioned anywhere but requires moving the rack forward or to the left well over an inch before lifting or rotating the assembly. But then I'm instantly up against brake lines, undercarriage braces, or restrictions under the rear motor mount. I've tried everything I've seen described and any approach I can imagine, but can't get the rack out. I can't get room to rotate it forward.
I removed the L & R mid-subframe brackets, loosened the L & R front subframe brackets, and loosened the L & R rear subframe brackets. I don't get the 1-3/16" clearance on the rear bracket - and maybe that's the problem. But I also don't want a subframe landing on my chest (theoretically I have the engine supported from above).
Do you know exactly how to move the rack so it will come out the wheel well? I'm thinking the '05 is different than the '04 or possibly later years, and definitely different than other models Honda & Acura.
ProjectMan is offline   Reply With Quote
Old 05-21-2015, 11:27 AM   #14
Registered Member
this is the 99-03 TL section, so not a surprise things are different and not part of our diy
Have you tried a google search?
or looked in the TSX forum on here? you need gurus of your model at this point
01tl4tl is offline   Reply With Quote
Old 05-22-2015, 04:52 PM   #15
New Member
Red face TSX, you say...
I guess I found this thread and site directly from Google, so didn't realize I was in a "TL" only section. I'll hunt up a TSX section. I eventually figured it out on my own. I've written up my approach and will post it over in the TSX section if appropriate, and, if I can, include the pictures (pix/illustrations are always helpful)
Thread Thread Starter Forum Replies Last Post
Blue Bolt tranny failure in < 15 minutes Yikes Second Generation TL (1999-2003) 28 10-09-2015 04:14 PM
Power steering rack and pinion replacement CaliBud916 3G TL Problems & Fixes 6 09-19-2015 02:56 PM
Thule vs. Rhino Rack FC2012RDX First Generation RDX (2007-2012) 0 09-04-2015 03:05 PM
Favorite Replacement Tire 17" fallacy Second Generation TSX Discussion (2009-2014) 10 09-04-2015 11:15 AM
Height of 2011 MDX with OEM rack Snafunk 1G & 2G MDX Discussion (2001-2013) 1 09-03-2015 09:01 PM
Tags
2000, 2002, accura, acura, cl, cost, integra, pinion, rack, removal, replace, replacing, rl, tl, tls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
