Stumped - Only left rear parking lights out
Old 11-24-2013, 07:16 AM
6th Gear
dwildey's Avatar
I can't figure out why only my rear left parking lights don't work!
Brake light and turn signal work but not left rear parking lamps. I have replaced bulbs and harness to rear tail lamp assembly. From what I have read, there is 1 fuse under hood? I think I have checked them all and can't find anything else wrong.
Any ideas or input on what to check?
Thanks in Advance!
Old 11-24-2013, 07:53 AM
3.2TLc's Avatar
If all the other parking lamps are working both front and the right rear, then the problem would'nt be with a fuse.....but more likely either a bad bulb or wiring connector, IMO. Have ya tried swapping the known good right rear side bulb with the bad side ? Check the bulb socket for power. Recheck the wiring harness or swap sides.
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
Ny1718
09-11-2015 09:21 AM
brjones9
09-03-2015 07:30 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: Stumped - Only left rear parking lights out
