Radio won't reset with correct code after battery disconnect - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 12-12-2010, 07:40 PM   #1
New Member
Acura TL, 2002:
I changed the battery but couldn't reset the radio with the security code I had from when I bought the car. I read that there could be interference from the antenna and some one had suggested disconnecting the antenna as a solution, then enter the code. This was cumbersome and I could not remove all of the trim to get to the back of the radio. I read that some one drove down to an underground garage to get rid of all radio signals and then entered the code and it worked.
I was very skeptical, but had nothing to lose. I drove down to the 2nd underground level of our local hospital's parking garage and then entered the code. IT WORKED!
I don't know why it works, but if you're having this problem with an Acura, it definitely works. And, as long as you can get underground away from radio signals, it really works.
Hope this helps some one fix their radio.
gheacock is offline   Reply With Quote
Old 12-12-2010, 08:15 PM   #2
Registered Member
welcome to the forum
you will find all the radio tips in the DIY section
the underground parking is a great trick~
01tl4tl is offline   Reply With Quote
Old 12-12-2010, 09:52 PM   #3
Registered Member
totaledTL's Avatar
Don't see any radio tips there-
There is a link in there that describes how to remove the trim & console to get to the radio.
totaledTL is offline   Reply With Quote
Old 12-13-2010, 12:36 PM   #4
Registered Member
really? I know there is a section full of radio code tricks somewhere,,hmmmm
Old 12-23-2010, 01:46 AM   #5
Registered Member
Micheeellee's Avatar
Guess what! I went down a parking structure and i tried the radio code and it actually worked.
Micheeellee is offline   Reply With Quote
Old 12-23-2010, 02:36 AM   #6
Regional Coordinator (SoCal)
xtremex626's Avatar
^ lucky you. everytime my radio askes for a code, i always gotta take everything apart and disconnect the antenna from the back, reconnect, and put everything back together! such a hassle and you lose all your memory seat and mirror positions!
xtremex626 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 3G TL Problems & Fixes 50 01-19-2017 02:13 PM
DIY: Converting DBW to Mechanical Cable Throttle with Working A/C cycdaniel 1G TSX Performance Parts & Modifications 4 05-22-2016 07:50 PM
P0507 code - Big mo 4G TL Problems & Fixes 3 09-12-2015 08:22 AM
Did I install my brakes correctly!?! HOWELLiNC 3G TL Problems & Fixes 12 09-10-2015 02:39 PM
VSA/ABS/SH-AWD/E-Brake on dashboard Stu2414 4G TL Problems & Fixes 2 08-30-2015 08:30 PM
Tags
2002, 2006, acura, acurazine, battery, changed, code, codes, disconnect, disconnected, radio, reset, resetting, tl, trick, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
