Pulled Code P1676 & P0420 - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 05-20-2006, 11:15 AM   #1
Registered Member
Exclamation Pulled Code P1676 & P0420
Hey guys,
I got these codes pulled @ Autozone today. I'm don't know much about cars, so I was hoping you all could give me advice on what I should do next?
Thanks all!
Dumbgunji is offline   Reply With Quote
Old 05-20-2006, 11:35 AM   #2
I=X - optomos
optomos's Avatar
DTC P0420: CATALYST SYSTEM - EFFICIENCY BELOW THRESHOLD
NOTE: Trouble shoot DTC P0137, P0138 or P0141, if set, before
proceeding.
1) Perform PCM reset procedure. See PCM RESET
PROCEDURE/CLEARING CODES under SELF-DIAGNOSTIC SYSTEM. Start engine
and run at 3000 RPM, with no load and transmission in Park or Neutral,
until radiator fan comes on.
2) Connect scan tool to vehicle. Test drive vehicle at 40-55
MPH for at least 2 minutes. Decelerate with throttle completely closed
for at least 3 seconds. Reduce speed to 35 MPH and try to hold until
scan tool indicates FAIL or PASS as TWC test result. If test result
fails, check TWC and repair as necessary. If test result does not
fail, problem is intermittent. System is okay at this time.
DTC P1676: FRAME-TO-POWERTRAIN TORQUE DOWN REQUEST (FPTDR)
SIGNAL LINE FAILURE
PROCEDURE/CLEARING CODES under SELF-DIAGNOSTIC SYSTEM. If DTC P1676 is
set, go to next step. If DTC P1676 is not set, problem is
2) Turn ignition off. Disconnect PCM 12-pin connector and
ABS/TCS control unit 16-pin connector. ABS/TCS control unit is located
to right of battery. Measure continuity between ground and PCM 12-pin
connector terminal No. 1 (Pink wire). If continuity is not present, go
to next step. If continuity is present, repair short circuit in wiring
between ABS/TCS control unit and PCM.
3) Measure continuity of Pink wire between ABS/TCS control
unit 16-pin connector terminal No. 1 and PCM 12-pin connector terminal
No. 1. If continuity is present, go to next step. If continuity is not
present, repair open circuit in Pink wire.
4) Reconnect PCM 12-pin connector. Connect jumper wire
between PCM 12-pin connector terminal No. 1 (Pink wire) and PCM 31-pin
connector terminal No. 28 (Yellow/Blue wire). Perform PCM reset
procedure. See PCM RESET PROCEDURE/CLEARING CODES under SELFDIAGNOSTIC
SYSTEM. Start engine and wait 60 seconds. If DTC P1678
sets, replace ABS/TCS control unit. If DTC P1678 does not set, replace
PCM.
optomos is offline   Reply With Quote
Old 05-20-2006, 11:38 AM   #3
I=X - optomos
optomos's Avatar
NOTE: Before disconnecting battery or removing fuse, obtain anti
-theft code for radio. After battery is reconnected, CODE will
appear on radio display. Enter 5-digit code to restore radio
operation. If code is entered wrong 3 times, leave radio on
at least one hour, then enter code correctly. Any time radio
power is lost, pre-selected radio stations will have to be
set. For more information, see owner’s manual.
Without Scan Tool
To clear PCM memory without using a scan tool, remove CLOCK
BACKUP fuse No. 13 (7.5-amp) from underhood fuse/relay box for 10
seconds.
Using OBD-II Scan Tool
Clear codes with OBD-II scan tool. Connect and operate scan
tool in accordance with manufacturer’s instructions.
Old 05-20-2006, 12:21 PM   #4
Registered Member
Thanks Optomos!
I called the dealer...they said they wont' trust the codes that I gave them. They want $94 to pull the codes and I can put that $94 towards the charge to fix this. IS this normal for a dealer to do? This is my first car, so I'm not familiar with what the behavior of service guys is.
Also..Do you guys think this is something i coudl fix myself or definately have to go to the dealer?
'99 3.2 TL
Old 05-20-2006, 12:54 PM   #5
'99 Acura 3.2TL
@cUr@-TL's Avatar
they wont trust the codes?? wtf tell them to fuck off.
@cUr@-TL is offline   Reply With Quote
Old 05-20-2006, 02:27 PM   #6
Registered Member
Quote:
Haha!!! Yeah, I guess I should do that...this is the Valley Stream Acura Service Center in New York(Long Island) for your reference guys... I'll try some other dealers a bit away and see waht they say...
Old 01-06-2009, 10:11 PM   #7
Registered Member
just wondering-- what did happen with this case with your P0420 throttle code? the guy did the test to check and it passed-- so based on what was written here they said it was intermittent--
After two years-- just wondering was there any failure in the cat or did you need to have the dealer replace the cat?
any help is most appreciated.
CelestialRL05 is offline   Reply With Quote
Old 02-07-2009, 07:49 PM   #8
Registered Member
edesoto's Avatar
And what happenned to the p1676 code...I'm havin' the same issue
edesoto is offline   Reply With Quote
Old 02-08-2009, 11:40 PM   #9
Registered Member
thinhthan's Avatar
yea i got that p1676 code to
thinhthan is offline   Reply With Quote
Old 02-09-2009, 07:59 AM   #10
fsttyms1's Avatar
Did you guys follow the test procedure?
fsttyms1 is offline   Reply With Quote
Old 02-10-2009, 09:41 PM   #11
Registered Member
edesoto's Avatar
Pcm = ecu?
Old 02-10-2009, 09:58 PM   #12
fsttyms1's Avatar
Yes
Old 02-11-2009, 10:56 PM   #13
Registered Member
edesoto's Avatar
And where is our ecu located...99 tl non navi here...thanks in advance
Old 02-12-2009, 09:29 AM   #14
fsttyms1's Avatar
in front of the center console on the floor. you will have to remove the side panels for easier access.
Old 02-14-2009, 09:22 PM   #15
Registered Member
edesoto's Avatar
To the right of my battery all I see is the air filter housing...any help would be appreciated...thanks
Old 02-15-2009, 05:09 PM   #16
fsttyms1's Avatar
Our ABS/TCS plug is on the right side of car, opposite of battery.
Old 09-21-2009, 11:21 AM   #17
Registered Member
Quote:
SIGNAL LINE FAILURE
PCM.
I also have only code P1676. I followed the above testing procedure.
For step #2, I got a result of 11k Ohm with polarity one way, and infinite resistance with polarity the other way. I see no reason for this difference unless there is a diode in the cable, which seems strange to me. But I took the 11k Ohm as my result. I also wiggled the harness to see if I could change the result and could not. Since I do not know if this is considered a result of continuity or no continuity, I decided to go to step #3.
For step #3, I got a result of 22k Ohm. Since I do not know if this is considered a result of continuity or no continuity, I decided to stop. Main point is that I am hopeful that I do not need to replace the ABS/TCS unit or the PCM; therefore I did not even want to perform step #4 yet!
Regarding step #4, I am not sure whether or not to keep the jumper connected while performing the PCM reset and while starting/running the engine. The alternative would be to connect the jumper and then immediately remove it before proceeding with the PCM reset and engine starting.
Any conclusion about my final diagnosis from the above results? Any clarification regarding procedure of step #4?
Thx!!
lewis3000us
lewis3000us is offline   Reply With Quote
Old 10-08-2009, 11:57 AM   #18
Registered Member
I resolved this issue and reported on it here: link.
Old 08-20-2010, 06:21 PM   #19
Registered Member
spineman's Avatar
So besides the ignition switch ( I have a 2000) what has everyone else found out/fixed with this code? are you finding you have to replace the pcm and or is it just a short?
Thanks!
spineman is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Ready To Take the Plunge but With Questions 08KBP_VA Second Generation RL (2005-2012) 37 05-11-2016 09:51 AM
Help Please!!! ABS and VSA light with exclamation point ALL ON Jamus22 2G TL Problems & Fixes 19 05-05-2016 09:58 AM
P1457 = A gently Reminder to Check your Gas Cap Skirmich Second Generation TL (1999-2003) 4 10-01-2015 01:59 PM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
EGR Valve /Extended emissions warranty shawnafoxx First Generation RL (1996-2004) 2 09-28-2015 01:33 PM
Tags
1998, 2002, 32tl, 99, acura, catalyst, check, cl, code, engine, mdx, p0420, p1676, po138, system, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
